Did this a month ago, just havnt had time to post it up.
I am going to start with this:
now i am going to show you why this is full of fail after 120k mi. . .
notice the fluid is hardly red anymore. . .
This is the "maybe if we put a large enough magnet in the pan we wont have to change the fluid, ever. " shot
front pan
Clean magnet and main pan.
what the trans looks like with out the pans on it.
very important that the car is level for refill
fuel filter at the same time.
over all the car shifts smoother and runs smoother after the changes.
That was A LOT of gunk on the magnet! Was that actual metal, or was it mostly just grim?
I can't believe the magnet... unbelievable.
I've replaced my transmission fluid (MT) twice now in 86k mi.
Good pics!
Why would they print "Warning" on the sticker? Is there any potential problem with changing the oil?
none that i can think of other then they dont want cheap trans fluid in the trans. there is a simular label on the manual trans as well its round and has either a red or green color to it. also remember that this is a GM built trans. BMW just removed the dip stick and built a new bell housing for it to mount to the 6cyl engine
zeecubed has several hundred miles on the change.
yep, every pan i have ever dropped has a degree of metal on the magnet. usually i wouldnt wait 100+ k to change it so in perspective to when i normally change auto trans fluid i would say its average. what is a concern is the fact that the fluid has lost its color (which is just a dye) but it takes high heat to take the color out and if you notice in one of the pics you see a heat gun. we had to use that to heat the front gasket so we could get it off the trans because it had essentually heat treated to the aluminum. last time i saw that was on a 500hp chevelle with a turbo 400 trans and no trans cooler. trans lasted 1500 mi. so you get the idea, the front pan is uber hot for what ever reason and it has less fluid sitting in it then the rear pan so it just cooks the fluid.
yis sir.
When the people that picked up the old transmission from my dads civic took it apart to inspect the gears, the magnet in the tranny was tiny, didn't look like it had that many shavings on it, but IIRC when we drained the fluid there were a bunch in it. I guess its better to have a bigger magnet than shavings floating around .
his was a manual, I'm assuming the manual transmission have the same thing?
3.73 | TCK S/A w/ H&R Sport | M50 manifold | IE Subframe Bushings, RSM, & SS brake lines | Shark Injector | UUC Evo3 SSK & DSSR | Cosmos Strut Brace | ASC, Resonator, CDV Delete
I get it. They recommend no changes so they don't have to do it under free maintenance programs. The tranny lasts just beyond the warranty, then you have to take it to them for replacement.
Well done, BMW, you sly devil.
It's funny. In one respect they've built a superior car by putting all these stop-gaps in place to prevent the need for frequent maintenance, which is really great! However, they should come come clean and simply say it needs less frequent maintenance, not none at all!
Face it. BMW is one of the few brands, possibly the only, that marries it's marketing folks and claims so well with the engineering folks and their products. Marketing says to Engineering; If you build a car that requires no maintenance for the warranty period, we can sell that as "we'll pay for all the maintenance".. You can't pick up the tab for what doesn't need to be done. Simply put, it's brilliant!
What type of fluid did you use? BMW stuff? DextronIII? or something else...I need to do this to my 2.3..It has 65k and I do not know if it was ever done, so I want to do it very soon....thanks
Hey! Everyone's talking about my car!
Anyway, I procrastinated about doing this for a while, finally got around to it. Yeah, I'd recommend doing it sooner.
As for fluid, it's Amsoil. My car is now a rolling Amsoil advertisement, even has Amsoil coolant.
How many qt's are required for a filter and both sumps fluid change?
Hey Bob....since we have essentially the same car and even the same color I will divulge that I waited to do this too until 102K. I tried to get another mechanic to do it but he said 'no don't mess with it....lifetime fill'. I won't wait that long the next time(30K tops) as the guys used dexron III not the BMW stuff. It is nice to know amsoil has ATF too....how's it working??? My mechanics ran a diagnostic on my tranny and said all was a-okay.....In response to what was posted earlier about BMW----that IMO is the current problem , BMW used to let the engineers run the show , now its the f%cking salesmen with their maintenance free BS.
I think it was like 9 for mine.
Amsoil ATF click the Amsoil logo in my sig, then click amsoil online store, transmission oil and it should be the first one in that list.
Automatic Transmission, 4L30-E Initial Fill..........3.2 quarts[2]
Automatic Transmission, Total Fill
4 speed 4L30-E..........9.3 quarts
PO on my 325 ended up replacing the auto trans fluid before I got it, which ended up wearing down and breaking a couple of gaskets and wore all the clutch packs to nothing. Let's just say the transmission did not like me drag racing it either after the fluid change. Either way, these things are piles made in France for GM and should not even be in a BMW. Manual > all when it comes to a BMW. Even BMW thought so.
Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
I know my local dealer now refuses to do auto tranny fluid changes even if the car is old and no longer under warranty. They had previously done the service on cars at a customer's request and several transmissions fail soon after some as soon as 500 miles later.
I know a couple of the guys in parts/service, one of whom is a club racer and none of them could explain the little phenomemon to me.
1991 e30 318is Slicktop - Gone
1996 LS1 Z3 - Gone
99 e46 323i - Gone
2003 e46 xiT - Hers
2014 F-250 CC- Mostly stock
