Results 1 to 25 of 48
Thread: .:Cut and raised my subframe 1" to lower car more
    Burlington, Vermont, USA
    '82 320i
    So I've got a little problem with my suspension in that I couldn't get it low enough to make my low profile 13" tires look right. As low as I dropped the coilovers, it didn't make a difference as the control arms bottomed out on the subframe. So I took an inch out of the subframe. This raises the control arm mounts and steering rack 1", while leaving the engine at OE height. This will help the make the suspension/steering better too. (I may need to put a half inch spacer on the motor mounts tho, as it doesn't touch the oil pain, but I might have issues when the engine torques.) I was originally concerned with the subframe being strong enough, but after taking it out of the car, and disassembling I have no worries, as it really is a pretty lightweight piece, and just spotwelded together. When I'm done it'll be fully welded and boxed in for more strength than stock.
    Put bolts into the subframe mount holes and tighted them down and welded the bolt heads to the bench and then welded a couple other braces to the subframe to keep things square.
    Then I proceeded to cut an inch out of the subframe using a sawzall and air disc cutter.
    I then used a spot weld drill and drilled out the remaining brackets and ground some rust off.
    I then lined things back up and welded it back together. It's welded enough to hold things in place and square, but I'm dropping it off at a place to get sandblasted, and then I'll finish welding it, and then I'll drop it off at the powdercoaters (and I'll have better pics).
    Mounted in the car, you can see it'll give more clearance. 2 of the bolts will still work fine, but the two longer bolts needed to be an inch shorter so I went and bought a couple new bolts.
    I'll take more pics after sandblasting and after the powercoater.
    '82 320i M10 Turbo with VEMS
    '95 525i with VEMS M50 PnP
    '99 528 Wagon
    Vancouver, Washington
    80 323i in pieces :-)
    Very interesting, we were actually discussing this last week at our local GtG.
    Are you going to cut the steering column one inch to compensate for the rack being raised? Not the column itself but the connector piece? IF you could find one from a car with power steering it might just be short enough.
    Definately keep us posted. Nice work!
    edit: why don't you just run 15's ? Weight or regulation or some kinda "authentic" thing going on
    Boston
    1979 323i BMW. 2003 GTI 20 V Turbo
    Nice work..you need some 15s....
    "..Horsepower is a measure of work done over time, or the rate at which work is done."
    http://www.cardomain.com/ride/579694/1
    Michigan
    Sexy E21
    i have the power steering connector from a power steering e21.. you can buy that off me cause you for sure need it or look for one out of a 1980 or so 635i the e24 cars.. that will fit there too.. good luck..
    VA
    E36 325i
    It's all about going low
    Ohio
    E21 320i, e39 540i/6
    epic win! This is why forums can be so valuable! This would give any of us who are lowered at all better suspension geometry. Even if you're not lowered an outrageous amount you will have a better roll center, less body roll and better handling. I spent a lot of time trying to figure out how to move the control arm pivot point upward an inch and decided it wasn't worth it if I couldn't move the steering rack as well since it would make bump steer much worse. I didn't think there was a good way to do it, you figured it out. I will absolutely be doing this sometime soon.
    As for the steering shaft, I've heard of GM guys getting rid of the rubber flex disc and installing spring steel plates for a crisper steering feel. doing this would cut about 1/4" out of the length of the shaft. I'll see if I can drum up some pics. Also, I have almost 1/2 to 3/4" of splined shaft that's not being used, so you could probably just slip the coller down further over the splined input shaft on the rack.
    As for motor clearance, can you fill your engine mounts with poly? I need to do this as well, the stockers are too soft and the motor rocks way too much.
    '81 320i turbo | t25, 931 CIS, 240hp, 13.92@100mph | 2.2L m10 Turbo Build | My E21 Videos |
    '82 320i
    This might seem complicated, but in actuality, I've only got like 2 hours of time into it so far, so it really isn't that complex of a thing. Just a matter of angleing the sawzall just right with long sawzall blades. And of course welding / bracketing the subframe to the bench ahead of time so you don't lose the proper alignment.
    I'm using that sway bar link upgrade from the FAQ's, and I do have poly in my motor mounts, although it didn't really stay very good. I might try to get some more poly today and redo them as much as possible. (I think I pulled my "mold" tape off too soon and didn't let the poly harden up enough).
    Although the steering rack has moved vertically up 1", the steering shaft is at an angle so the length that that changes is less than an inch. I haven't figured out exactly how much that is, and planned to just tackle it when I got to it.
    When I was doing my brake master replacement work, I buggered up my steering shaft a bit, so it is less than pretty, so I wouldn't mind getting another one.
    Charbel, how much for yours?
    Quote Originally Posted by jrcook320 View Post
    Another option is one of these like from Afco or another company. I've also got one from a VW lying out back in my shop. They use a U-Joint as well.
    '99 528 Wagon
    NY
    e30, e46, Super Duty
    Good stuff! Thanks for sharing, keep us posted :
    1991 e30 318is Slicktop - Gone
    1996 LS1 Z3 - Gone
    99 e46 323i - Gone
    2003 e46 xiT - Hers
    2014 F-250 CC- Mostly stock
    '82 320i
    Here's a better view of it now that it is sandblasted. Dropped it off to the powdercoater, hopefully have it done this afternoon.
    '99 528 Wagon
    Oct 2005
    Dubai
    e21 race 320i road
    Nice post
    I have been working on the same idea, now i just need to do it
    Jason
    '71 Bavaria
    Tigard, OR
    '81 323i, '87 325
    I couldn't have said it better myself. As Lance indicated, I've been thinking about this for quite a while and have been certain that there is a way to do it. I was just putting off really looking into it until I was ready to swap in the 2.7L, which will be a while.
    Subscribed to this thread! You are my hero of the day.
    However, if getting the car to sit a bit lower was the intended result, I think you may end up dissapointed on that front. The ride height shouldn't be affected by relocating the subframe, it will however greatly improve your roll center on a lowered car.
    e21: 1981 2.5L sleeper
    e21: 1982 323i Baur TC 1 # 4210
    e21: 1980 323i project or parts car, can't decide
    e21: track car project
    e46: 325XiT
    click here for the latest updates
    Jan 2003
    Mill Creekish WA
    97 M3/4/5 81 E21 72 Bav
    Quote Originally Posted by Jester323 View Post
    The collision with the control arm produces this much tuck on a 15" rim:
    Moving the whole assembly up will give more room.
    '82 320i
    Got the subframe back from the powdercoater:
    And compared to Nic's pic.
    '99 528 Wagon
    Ohio
    excellent results. How's engine block flange clearance (on teh low side) and oil pan clearance?
    This is such an improvement for suspension geometry in every way. My car isn't even super agressively low, but I'm sure I've bottomed out the control arms and the control arms are parallel with the ground. This means camber decrease (very slightly) as suspension compresses, poor roll center which means more body roll, etc.
    raising the control arm pivot point restores geometry to offer camber gain as suspension compresses, better roll center, and it even changes the angle of the sway bar (ie double acting as a radius rod or tension rod for us) to improve brake dive.
    '82 320i
    It's very close in clearance. It should fit, but that's why I want to add some more poly to the mounts just to make sure, and as I said, once I get some weight on those mounts and the engine torque'ing, I might need to raise the mounts a half inch or so.
    I originally thought I'd need to notch the center part of the frame to clear, but I think I can get away with it as is.
    '99 528 Wagon
    Jan 2003
    Mill Creekish WA
    I need to do this AND get my damn oilpan out of the way.
    Jun 2004
    San Jose, California
    90 325i 4dr
    Ftmfw!
    '82 320i
    Quote Originally Posted by jjgbmw323 View Post
    Got some. Gotta refinish them first, and order new lips and one barrel. 15" 3 piece Hayashi Racing Equip / HRE.
    '99 528 Wagon
    Boston
    HRE are great!
    Los Angeles
    M3, 911, NSX, DC5, AE86
    Feb 2009
    District Nine
    sold 78 BMW 320i
    Relating to the steering rack being closer to the steering column:
    Take a peek under your dash - you may be able to make two new little brackets to position the steering column where you need it to be? Or, you probably looked at that already?
    Nice work, Robert
    Tbd
    Apr 2009
    Los Angeles
    1982 320i
    DISCLAIMER: I may not be getting what's going on, but I did some math and drafting so I'm looking for criticism, or anyone who can clear up my possible misunderstanding.
    I don't think this will lower your car, nor do I think it will lower your roll center. In fact it should leave your car at the same height, and raise your roll center.
    Point 1. In a car with MacPherson Struts the car is "suspended" on the damper/spring system. The lower control arm has nothing to do with supporting the car, only locating the wheel during bump and droop.
    Point 2. Therefore when you cut your subframe 1" you are moving the lower control arm chassis mount up 1" in relationship to the tire contact patch at the road surface.
    The following is a drafting of the MacPherson Strut Roll Center calculation where you raise the control arm chassis mount 2" (to show exagerated effect). Not only does the roll center go up but because the length of the controll arm is static you have now tucked your front wheels into positive camber (you can't really see this in the resolution of the drafting but if you look at the two large circles at the top you get the point that if the lower arm chassis point moves up it must cause the whole upright system to rotate around the axis of the upper MacPherson strut mount and therefore move in towards the center of the chassis).
    The dark dot is the Roll Center
    I highly recomend reading Allan Staniforth's book "Competition Car Suspension" before doing any major suspension work on any car. Even if you don't follow the axiom that Roll Center location is the be all end all of suspension design, he still gives you a number of methods for desigining suspensions and modeling them.
    Milo
    Cincinnati, OH
    323i, 530i, '13 Cooper S
    I think the problem with e21's is that that control arm on lowered cars sits about parallel to the ground. When the car corners, the outside wheel will rise in relation to the body causing the control arm to move beyond parallel (higher on the strut side than the chassis-mount side). All kinds of funk is supposed to happen when the control arm gets like that. This mod would eliminate that and bring the control arm movement closer in line with that of a stock e21.
    Well, that's how I understand it anyway.
    Apr 2009
    Los Angeles
    1982 320i
    That's an interesting point Adam. It can certainly cause a problem in a double wishbone system if during bump or droop you get to a point where the control arms don't actually converge in the imaginary "vanishing point".
    I'll measure where the chassis pickups and strut mount actually are, then do some variations for lowered/raised, and introduced negative camber and see what happens. I should have some draftings up later this week if I can get measurements off my 320i.
    Anyone want to give me a balpark lowest lowered position with coilovers? I am going to have to make an arm that locates to the strut mount so that I can get a vertical measurement off of it (like a giant caliper) but I'd be interested in how much the car can be lowered. I'll then draft in increments that make sense.
    If anyone uses AutoCAD or the like I can post dwg or dxf files when I am done so you can run different suspension options through and see where you end up.
