BMW - Vehicle Identification Number (VIN) Decoder
BMW VIN-Decoder for all BMW Vehicles from 01/1928 to 02/2009
(including: Motorcycles, Mini, Rolls Royce)
Fahrgestellnummer/chassis no.: ..........
enter the last 7 digits of your chassis number and press Return
http://www.bmwarchiv.de/vin/bmw-vin-decoder.html
Important: Make sure that the complete model, engine, month and year of production is shown in your avatar/profile, otherwise it is difficult to help.
Those data are a must when you want to have a detailed reply from some experts. Because they have to check the correct wiring diagrams and if those data are missing, you cannot expect a reply.
Often it is also important to mention the engine. For example a E32 730 could have a V8 M60B30 engine, or a
M30B30 6-cylinder engine.
Automatic/manual? Of course that is also important. And if it is not U.S., spec., then mention that also, like U.K. right hand drive and so on.
So it could look like this:
E32 730iA M60B60 12/91 U.K. spec.
then we know it is a V8 engine, built 12/91, RHD version, automatic transmission version, and on the U.K. version we cannot ask to make a stomp test, as that only works on U.S. spec./versions.
and another one here
http://www.bmw-z1.com/VIN/VINdecode-e.cgi
more, other brands VIN decoder
http://www.mobilverzeichnis.de/vin-decoder.htm
Here`s a list
Free Online Vin Decoders
I think it has a new one for BMW
None from list works.
If still searching for BMW vin decoder https://www.mdecoder.com
Here is also for Mercedes https://www.mbdecoder.com
I just tried that one Tagra, it didn't work. Says error.
for me it also does not work, this one works http://www.bmwvin.com/ and this http://bimmer.work/
Hey that one worked!!
I seen the things under "order options"?
PREPARATION FOR CD CHANGER....I didnt know mine was set up for that???
SERVOTRONIC....Dont know what that is....
LIMITED SLIP DIFFERENTIAL (25%)...I knew I had posi...but 25%?
MAIN BATTERY SWITCH?
Theres a lot of info that came up. I should screen cap it and post it here.
Servotronic is speed sensitive steering.
______________________________
1992 750iL
MAIN BATTERY SWITCH? >>>only for transport from factory to US dealer, then removed and returned to the factory.
What is the preparation for the cd changer? Is there something hidden i am not aware of to hook up a cd player?
Maybe the wiring up to the trunk. On my car the CD changer is under the parcel shelf in the trunk on the left side, but not sure how that was done in the US.
I will take a look, just to see if its there. It will bother me now. LOL
