12v Electronics is now offering custom made speaker mounts for E39 BMW's.
These baffles will allow you to install speakers up to 6.75" into your vehicle without any cutting or drilling into the car. They use the stock speaker bracket mounting holes and can be custom made for the speaker of your choice.
Here are some pictures:
These replace the factory enclosures in the car. Here is a pic with them installed:
This picture is with a Hybrid Audio Technologies Clarus C61-2 speaker mounted. This is a 6.5" driver and no cutting is necessary.
This is how the 6.5" speaker is centered in the factory speaker opening:
Closed cell foam gasket material is included to seal the speaker to the door panel. The following picture is of a 6.75" speaker installed.
This makes installing aftermarket speakers into your car very simple. We can make the mounting hole any size to match your favorite speaker. There are some restrictions on size and depth, but most speakers up to 6.75" will fit in these mounts.
We are offering them for sale for $129.99 custom made to your speakers dimensions. We will ship custom made items in 1-3 days. Since we are offering custom sizes, you will have to contact us with your specifications.
They are also being produced as stock items for the Hybrid Audio Clarus C61-2 component set. They will be in stock and can ship with the speakers installed. (and boy do they sound great!!)
EDIT: This item is now available for purchase at www.12velectronics.com. Here is a link to purchase: E39 speaker mounts at www.12velectronics.com
How about making some baffles to fit the Legatia L6, I'll be one of the first to pick a pair up.
The L6's are 7.1" in diameter. They will not fit in these baffles. You would need to modify your door card to mount them.
One option to consider is to use the Clarus 6.5 woofer as shown and substitute a L1 pro tweeter as the Clarus drivers are available seperately.
These would make a great pair and save you the trouble of cutting up your door card.
Those look really nice. I really like the foam piece that is included with them.
It may be a good idea to post this in the E39 section also, as some of those folks may not wander into the audio section very often.
This looks nyceeeeeeeeeeeee you should of posted this long ago..... I wouldve bought it from you... I got a pair but....not made like yours... i got a pair of pener baffles, looks like first generation baffles, that is only 1 piece... yours look like... 3 pieces made to form 1 piece, I will need to do some modifications to make it fit my door like yours....
We had these made a while ago, but needed a volunteer E39 to do some real good test fitting. These really do fit great and seal well to the door.
There is very little "wiggle room" when installing a 6.5" driver. It took some time to get them just right to get them to fit without any cutting or modification to the car.
I will mention that this car ROCKS with the Clarus 6.5's in them and a decent amp. They have more bottom end than the factory sub that was in this car.
They look good Tom. What kind of depth can you squeeze in there?
Think 4" is possible? I want to try these guys:
http://www.parts-express.com/pe/show...number=264-874
So very tempting right now. I may have to get a set.
wish these were out when i got my 5.25's... especially since i had to pay way more for them opposed to if i got 6.5's.Maybe for my next system ill hit these up
Any e46 speaker baffles? Free air installations FTL...no midbass for me![]()
We do have E46 adaptors to mount 5.25" speakers in the factory locations. Is that what you are looking for?
I have 6.5" speakers...but I need something like in the original post to give the speaker an enclosure instead of mounting it to the plastic door panel in a free-air setup...Do you have something like this?
Awesome...might have to eBay the 5/25" Morels I installed.
Just EQ them for the enclosure...![]()
VP Electricity
2007 E91 328xi T Premium Nav BT CA - PnP custom audio system by musicar northwest
Sent you an email, definitely interested.
Do these change the max mounting depth? I have read that normal mounting depth with the stock baffle is around 2.3 inches.
thx-zd
If you are still in need of an e39 (97 540i/6) test mule, Im located in North Aurora,IL and I can drop my car off for a few days.
And a fair price. I ended up making some and spent about 3 times as long as I had planned... And it isnt my first time modifying stock locations with MDF...
But I got some TS-C720PRS mids in there!
If I move to snow country I might have to get an e39 just so I can install these!
2002 M3
2011 M3
2016 X5 40e
