Took some work, but the seem to fit....
The fronts are totally FINE! The rears were fine last week, but at yesterday's event the drivers side rubbed slightly...but I think/hope we solved the problem...
Jason Becker
25 SSM
Monsters. They look fantastic, I love that front shot. 285 fronts, amazing.
Terry
Stuff. I got stuff.
OK Jason, that convinces me that more rubber is a given. At least 275's all the way around. I'll have to start looking for when the current tires are shot which should be in the next four events.
Now in E92 M3 ZCP -- Absolute beast
that's just nuts, plain and simple![]()
997 Carrera 2S..the choice of 2 out of 3 Top Gear presenters.
Would you like some coupe to go with your tires?![]()
You have to check....but I am pretty sure the overall diameter of a 275 is going to be too tall.
Width is not the problem up front. As you can see, a Z can take a lot of tire width up front (LOL!!!), you just need to keep the overall diameter as short as possible, and the 285/30/18 is very short. That way you don't have to raise the car up too much.
I am starting to feel the same way...it's getting out of control
LOL!!!!
are those fikse's?
Mods: A Few...Rod Bearings, VF Eng. SC stage 1 - 5 lbs, HP Coil packs, Underdrive Pulleys, Organic race Clutch, CDV Delete, Shift pins, Short shift kit w/bushings, Shortened shift lever, Randy's Subframe, IE Bushings, TCKline suspension, Adj. Cast. Camb. (front), Adj. Camb. (rear) 700# springs, RSM, Rogue cover, Metric Mechanix trick variable ramp LSD 3.46, Wilwood Big Brakes, 18" CCW LM's, 315 30R 18, PSII's Complete custom exhaust… Ceramic coated headers ID/OD, Race cats, Eisenmann sport w/83 mm, Custom gauge pod, Custom gauges, Dual Wide band Air/Fuel monitoring, Built-in scan gauge, Becker Traffic Pro, Seat hump removal-both sides, Seat front raise, ACS rare low profile rear wing, Smoked tails, HID's Lightly smoked,
Special Thanks To: Randy Forbes Rocknroad 2Kredz3 MC28REPSOL IslandS62 Clintjg jonesmechanical Ron Stygar and many more on our board!
wow, so even though the tires stick out of the wells up front, you don't contact your hood or rub? Nuts!
Wow, I have been waiting for pics of these. Can't wait to get some driving impressions of the setup. I am not usually a fan of the full polished, but it works on your setup. Just make sure you buy some stock in mothers polish!! Those rears when warm should do the trick as far as putting down the torque on corner exit. Outrageous!
1999 M coupe, Black/Kyalami Orange, Sunroof Delete; GT4088R turbo, 610 WHP @ 22PSI Pump Gas; 2.79 Gearing; TCK D/A's; Forgelines 19x9 et38 w/265 30's; 19x11.5 et19 w/305 30's. Brembo GT Brakes; Race Logic Traction Control.
1971 Datsun 510: High Compression VG34e, CAI,Fuji Blue, GC C/O's; system, Penultimate Rear Crossmember R160 lsd 3.70, cv axels; CCW LM16's 16 x 7.5/8.5 w/215 40 and 245 35 T1R's.
That suspension is up pretty high to keep them off the guards ...
.-=[ Kenny ]=-. See the BFc Drag Racing Standings List for BMW street cars. Watch my drag racing movies on YouTube. Some info on
BMW turbo street car Drag Racing 101
What are the offsets of the wheels??? No idea a 10 would fit up front without modification
~Ken~ '99 M coupe THE "original" TT Stage 3 - HTA3586R; 701 whp 672 wtq @ 26.5 psi ; NeverSell - CoupeCartel
I did have to raise it a bit, but it is still much lower than stock.
The rear ride height is around 12.75", and front I forget, but the control arms are dead nuts level.
The pics may be misleading because in each one the car has either come off the lift or jack...and there is some hysteresis in the suspension.![]()
You can definitely fit 315/30 R18 on 18"x11" inside the guards, no need to jack it up.
Very nice, what are the offsets of those wheels?
Looking good Jason! I need to swing by and check it out soon! I want to go for a ride/drive in that monster.
Previous car
Euro S50B32 swap, Swain Tech cermamic coated euro SS replica headers,custom subframe/diff mount reinforcement, 3.46 diff, TcKline S/A coilovers, 18inch BBS CH's. Gen 1 Projector Z's with HID's and angel eyes
Wow, that looks crazy! We need some video of that thing from the outside!
-Joe
Jason,
The front tires clearly stick out a bit. Does the tire actually tuck in without rubbing or are you just not compressing it that far?
They look amazing. How do they feel?
Inspiration!
Siiiiick![]()
alpinweiß on anthrazit buffalo 1984 745i, 2014 Fiesta ST, 1984 635csi 1986 635csi 1987 L6 1999 M coupe 2002 M3 1995 325i 1976 2002, 2001 996 TT 1994 850 T5 wagon 1998 GTi VR6 1983 scirocco
Not Hoosiers buddy!!!!
I don't care what Tire Rack lists as the size for A6/R6 they are bigger than advertised. I'd say they are closer to a 310...ask the people in the Track forum...they'll tell you Hoosiers run wider....
No they don't tuck up...there is only about 3/4" (maybe less) of travel up front.
It's crazy amount of grip!!!
No problem!![]()
