Page 1 of 4 1234 LastLast
Results 1 to 25 of 95
Thread: E36 M3 Powersteering Leak Fixed...reservior relocated.
    Saint Louis, Missouri
    2011 Tahoe, 2011 335is
    One of the things that drove me nuts for years was the powersteering reservior location and leaky hoses on my E36 race car. The factory hoses will eventually leak. I replaced the factory hose with a new one and removed the crimp fittings and used clamps. They worked fine for awhile and then started to leak again. I also hated where the factory reservior was as it was difficult to access and a mess to drain and fill.
    I decided to relocate the reservior...well, actually replaced it with an aftermarket can and used AN fittings to eliminate all the leaks. Here's how it turned out.
    I installed the new reservior behind the passenger side headlight for easy access. It's a Canton Racing unit with AN-10 and AN-6 fittings with internal baffles. It's a nice part and it fits perfectly in this location. I drilled two small holes in the frame rail and shimmed the mounting clamp with some washers.
    I used a Mocal banjo fitting with an AN-10 end to replace the factory banjo line. I reused the factory banjo bolt and washers.
    I used an Earl's compressing fitting on the small return line after I cut the flared end off the factory line. The smallest output they had was AN-8 so I used a AN-8 to AN-6 union and a 180 degree AN-6 swivel fitting to allow easier routing of the hose to the new reservior. You can still see the old hoses that I have not yet removed.
    I used rubber lined adel clamps to secure the hoses and ensure nothing would vibrate on anything. I also made sure the fittings would not come in contact with the front sway bar as it moved with suspension travel.
    So far so good. No leaks. PS fluid levels are easy to check and I'm quite pleased with the results.
    Here's the parts list:
    Canton Racing 77-252 - Universal Power Steering Tank w/Mounting Hardware - 10-AN Bottom & 6-AN Side Port Male Fittings (cheapest place I found was www.hrpworld.com)
    Mocal Metric Banjo to -AN Hose adapter 16mm to 10-AN BJ1610H (www.batinc.net/mocal.htm)
    10-AN 45 Degree Swivel Fitting - Earl's Part #804610 (www.anplumbing.com)
    6-AN 90 Degree Swivel-seal Fitting - Earl's Part #809106 (www.anplumbing.com)
    6-AN 180 Degree Swivel Fitting - Earl's Part #818006 (www.anplumbing.com)
    8-AN - 6-AN Union Reducer - Earl's Part #991912 (www.anplumbing.com)
    Hardline Tubing Adapter/Compression Fitting 8-AN to 1/2" Hardline - Earl's Part #165008 (www.anplumbing.com)
    10-AN Stainless Braided Line - Earl's Part #400100 (www.anplumbing.com) --- You'll need 3-4ft depending on your hose routing and reservior location.
    6-AN Stainless Braided Line - Earl's Part #400060 (www.anplumbing.com) --- You'll need 3-4ft depending on your hose routing and reservior location.
    Teflon Tape
    Dec 2005
    Berkley, MI
    2000 E39 M5
    That looks great.
    Connecticut
    95 Dakar M3, 02 Dodge Ram 1500
    It looks really good. Those damn P/S lines always leak and that resevior is a PITA to get too. I wold appreciate a parts list for this, Ill have to do this once the rest of the motor is sorted out.
    It looks stock.
    Quote Originally Posted by bjl4776 View Post
    Parts list posted.
    Jun 2004
    seattle
    Turbo m52, HPF m3
    Now thats clean, This will go on my to do list right now!
    MODS: TOMANY TO LIST!
    Indianapolis
    scooter
    Quote Originally Posted by vinnymac View Post
    Parts list posted.
    Vince,
    You have to much free time on your hands. Looks good, also looking forward to looking over your diff cooler set-up. See you in a few weeks.
    -Scott B.
    Quote Originally Posted by scottbm3 View Post
    Vince,
    -Scott B.
    Ha. Definitely looking forward to hanging out in a couple weeks. Talk to you soon!
    Mar 2004
    Fort Worth TX
    Wreck Miata,Dirty Thirty
    Awesome, what did all the parts end up costing you?
    Mar 2001
    H-town, TX
    95 m3, 03 X5, 06 X3
    looks good.
    #71 SM
    04 Silver Grey M3
    95 Arctic Silver M3
    03 X5 3.0L Titanium Silver
    07 GX470- Silver
    Molon Labe...
    Excellence is a habit, not an act.
    Queens NY
    99 M3 Euro, 09 Fit
    genius solution
    99 Techno S50B32 6-speed ///M3 (Complete)
    Mods: SOLD
    SoCal 626
    97' E36 M3 Track Car
    i wish this was here two weeks ago, before i changed replaced my P.S. lines with factory. probably would have saved going this route.... +1
    Living Life Turn After Turn!
    Def's Avatar
    Def is offline Lead Disagreement Eng PE
    Aug 2002
    SW22, Volt
    Looks good. The only thing I'd change is to ditch the compression fitting on the rack and flare the hardline and use a tube nut and sleeve. You'll probably use the flaring tool in the future as it's a pretty handy thing to be able to do.
    Jan 2006
    Delaware
    97 328is, 2016 F150
    very nice set up. i like it a lot.
    my ps lines started leaking a couple months after i replaced them. now the rack is leaking somewhere.
    when i get around to replacing my rack this summer, i think im gonna do something like your set up.
    -Jason
    --I shoot a Nikon D300. I track a 1997 BMW E36. I wrench with Matco.
    I Boost a 2015 F150 Ecoboost --
    --I don’t Fail; I succeed at finding what doesn’t work--
    --Horsepower is how fast you hit the wall and torque is how far you take the wall with you--
    --If you can leave rubber from the apex to the braking zone, you have enough power--
    --1997 BMW 328is--2016 F150 CCLB Ecoboost
    --2004 F250 CCSB FX4 Diesel (sold)--2006 Acura TL (Sold)--2010 Acura MDX (Sold)--2019 STI (Sold)
    Quote Originally Posted by Def View Post
    That's a great idea. I may try that if I have any issues with the compression fitting. It's low pressure so it should be OK, but thank you for the great suggestion.
    Do you have any links to tube nut/sleeve fittings that can be adapted to accept an AN fitting?
    Thanks.
    Louisville, KY
    turbo m3
    I just replaced all of my factory hoses like 3 months ago.... BUT when they start to leak I will be replacing everything with your setup!!!
    This is my signature....
    Quote Originally Posted by Greg S View Post
    I'd have to pull the receipts to remember the exact cost...but here's an estimate:
    Canton PS tank ~ $120
    Mocal banjo fitting $35
    Braided lines ~ $35
    AN swivel fittings ~ $75
    So...roughly $275 give or take once you factor in shipping fees.
    Apr 2006
    NorCal
    MTree
    Great solution to a P.I.T.A issue.
    Oct 2005
    Virginia Beach, VA
    99 M3, 01 F350
    VERY nice... :
    "Torque is like cowbell... you can never have too much." - Michael Cervi
    Sep 2003
    Savannah
    POS-325e
    I'm happy to see at least ONE of the STL BMW racers using aerospace quality stuff and techniques in their race car installations.
    Looks good!
    POS-325E 2018 BMWCCA MP National Champion
    E60 535i DD
    Oct 2008
    NH
    2000 M Coupe
    good idea - good work
    2000 Z3 MCoupe, '01 LSB E46 M3, '99 GTI VR6, '06 Audi A4, Andrew '95 Avus M3
    Def's Avatar
    Aug 2002
    SW22, Volt
    Thanks.
    Sorry, didn't see this when it was posted.
    Just search "tube nut" or "tube sleeve" on SummitRacing.
    Here's what they look like(should have both a sleeve and a nut on the pic). Just pick the size AN fitting you want, it doesn't matter if the sleeve isn't really tight on the tube from a pressure holding standpoint(i.e. metric/SAE size differences).
    Philadelphia, Pa USA
    E39 M5, M3 #226 CM
    Great write up -- I know the thread go back a bit but I just wanted to add one correction to the parts list for anyone who is copying your install. Which I did.
    The hardline to 8an adapter is listed with the wrong part number. What you want is the same type of fitting but in the female version. Part # 165108. This is the correct part to go from the hard line to the 8an to 6an reducer - as that part is male on both sides.
    Thanks again for the great write up
    [/QUOTE]Hardline Tubing Adapter/Compression Fitting 8-AN to 1/2" Hardline - Earl's Part #165008 (www.anplumbing.com)
    [/QUOTE]
    Mar 2001
    H-town, TX
    95 m3, 03 X5, 06 X3
    vinnymac, what coolant expansion tank are you using?
    #71 SM
    04 Silver Grey M3
    95 Arctic Silver M3
    07 GX470- Silver
    Molon Labe...
    Miami, FL
    95 M3, 98 M3, 08 M3
    Quote Originally Posted by BJO View Post
    That's the Zionsville one (in his pics).
    Carlos.
    Nov 2005
    Alpharetta, GA
    '95 M3 IP #595, '07 Z4MC
    I just completed this modification and thought I would post my alterations to Vinny's original post.
    I chose to keep the reservoir on the intake side of the motor and also chose to use a braze weld fitting. For the braze weld fitting you will need a steel 8AN male weld-on fitting. I drilled this out to 15/32" about 1/2" deep. This provided a nice tight fit for the braze welding. I also replicated the factory pressure reducer by taking an M10 bolt that I drilled a 3/16" hole the length of the shaft and then cut a 1/2" piece off, filed it to fit the id of the trombone and inserted it in the trombone and crimped it in place. I then braze welded the 8AN male fitting on the end.
