Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com.
Old 04-10-2009, 10:44 PM
That Fly 325i That Fly 325i is offline
Cars: 325is
Quick springs and drifting question
From what i read soft springs let you know when the back end is going to give way. But when i drift a corner and i try to catch it and countersteer and stuff it gets bouncy. Its hard to discribe but i went into a turn and the back end breaks loose and when i go to catch it it whips the car the other way and shifts all the weight. I know some of it is driver error but would stiffer springs make catching the oversteer easier?
--Shwartz II 325is--
Go: Bilstein Sport Shocks/Bav Auto Coils, KMAC adjustable camber plates, Eibach Lowering springs, TMS Aluminum RSMs w/ TMS reinforment plates, M3 sunflowers
Show: ZHP shift knob, M3 floor mats, Pioneer Heady
Coming soon/wanted: 3.23 tabs of LSD, Black Vaders, s50.
Old 04-11-2009, 03:14 AM
hish911's Avatar
hish911 hish911 is offline
BMW CCA Member
Cars: 2001 bmw 325i
you probably dont know how to drift right, stiffer springs wont let u catch the oversteer easier but it will help transition the wieght of the car to get you sideways
Old 04-11-2009, 01:14 PM
Critter7r Critter7r is offline
Craziness ensues....
Cars: 2005 325Xi
Um.. hm..hm.. ahem... tap....tap....tap..... is this thing on?
Listen carefully, because I'm only going to say this once....
You can't drift in a 325.
Any advice I may give here is - at best - tongue-in-cheek, and just as likely outright offensive. I've been doing this for a long time and I usually have a pretty good idea of that which I speak - but not always. So break out your grain of salt and try to keep up.
Old 04-11-2009, 01:49 PM
bms72586's Avatar
bms72586 bms72586 is offline
Cars: 2005 bmw 325i
Send a message via AIM to bms72586 Send a message via Skype™ to bms72586
^^^did he say can or canT?^^^^
Old 04-11-2009, 02:43 PM
White Knuckles White Knuckles is offline
Cars: '89 325i S52 =)
Cant drift a 325? http://videos.streetfire.net/video/J...007_143794.htm
The guy who invented the first wheel was an idiot. The guy who invented the other three, he was the genius.
Old 04-11-2009, 04:05 PM
Lateral G Lateral G is offline
Rennstrecke Fanatiker
Cars: E30, E36, E36, R56
That's a hook slide.
Buy Going Faster.
Go to a Car Control Clinic.
Old 04-11-2009, 11:58 PM
Cars: 325is
same shit controlled oversteer. You all know what i mean..
Old 04-12-2009, 01:40 AM
r0nd3L's Avatar
r0nd3L r0nd3L is offline
Cars: 2004 GTO
Do you lift when that happens?
Old 04-12-2009, 01:56 PM
What you described -- the car whipping the other way -- is a very well understood vehicle dynamics/car control issue. While it's well understood, it's hard to fire off a line or two that will provide a meaningful explanation. And there's no substitute for seat time. That's why I linked those resources. The book and the class are cheaper than any car mod you can do, other than changing your tire pressure.
"Going Faster" costs just $29.95 and covers skid control and many other topics quite well.
A CCC or AutoX instructor probably won't want to teach you how to drift, because it's the slow way around a corner (except on gravel), but getting into and out of a skid is typical fare for this type of school. Having that car control skill under your belt, you can adapt it to driving sideways.
Old 04-12-2009, 06:04 PM
odortiz's Avatar
odortiz odortiz is offline
Cars: '95 M3, '94 325is
once you feel the rear about to hook up when exiting the drift, you need to snatch the wheel straight. otherwise, remaining steering combined with all the stored energy the springs just released, will cause an over-rotation, leading into a tank-slapper. to feel the tipping point, you have to be totally relaxed in the seat, which comes with seat time. ideally seat time while sideways on a skid pad.
David Ortiz
Website
