Any difference that matters?
Lemfoerder is oem. I'd not even heard that Febi was making those.
9/2004 Chevrolet Suburban Z71, black, purchased March 2016, 270k miles.
6/99 740i Cosmos Schwartz M Sport, 214k miles, purchased May 2017
2001 740i OrientBlau M Sport, purchased March 2023
1984 MasterCraft Stars and Stripes, Blue/White, PCM Ford 351W, PowerSlot, 912 hours, purchased September 2012 (not a car )
4/99 323is/5. Titansilber, 211k miles. Straight body project.
past BMWs: 5/1994 325isa (Arktisgrau), 3/1997 328is/5 (cosmosschwartz), 9/1990 535i/5 (calypsorot), 9/1990 318i/5 (brillantrot) 7/93 325i/5 convertible (samoablau) 2/92 325i/5 cabriolet (lagunengruen).
SÜNDE REISEN
Thanks, they are definitely more expensive. Like $70 more. Wasn't sure if it mattered.
$70 now or another pair in about a year lem is the only way to go
S52 Wisco/trm pistons eagle rods top mount 6266 (etc) (etc) zionsville fatboy radiator VDP oil cooler setup
obd1conversion baffled oil pan push/pull eletricfans m50manifold CAI JB lightweight flywheel VACsolid motor trans TMSsolid diff subframe mounts tc-kline/koni adj rear shocks tc#550rear springs tc#600front springs tc ride height adj tc/koni adj coilovers tc monoball camberplates tc monoball shock mounts tc monoball RTAB TMS monoball adj rear control arms TMSmonoball upper inner CAB tc derlin frontCAB 323 lsd uuc evo3 SSK 18" RD sport RS2
I got febi and have not had any problem with them. I couldn't justify spending that much money on Lemforder's
RIP 328is
Hmm... something else to consider.
Mayle
FEBI
Lem's
I have Meyle's on one of my E30s. They seem to work fine. Only 10k miles on the install though.
SÜNDE REISEN
You get what you pay for...
I bought Lem's
I'm having to replace mine soon , do you mind me asking how long have you Febi's on yours and what milage you've done ?
Here in the uk febi's are about £80 a side Lem's £135 are they worth the difference ? add the rear bushes and drop links it works out £420 both sides ?
Any advice/opinions much appreciated . Cheers JJ
Just a note Febi is a division of bilstien so the febi maybe a better choice considering bilstein is the best name in suspension products
I had Meyle tie rods, and they lasted a year. Don't know anything about Febi, but I think MaxxChris is right: you get what you pay for. I wouldn't put anything other than Lemforder on the car.
-vik
97 M3/4 Cosmos/Dove -- mostly stock
ex-99.5 A4 1.8TQ Volcano/Opal -- not so much stock
Remember that Lemforder made the crappy OE balljoints. So if you want more of the same, use the same, especially if paying too much makes you feel better.
The Meyle products are quite good. I have used them with great success.
I have only had the Febi's in for a few thousand miles. But before buying them I took my time researching the same information and advice that you are currently looking for.
Many people bagged the Febi's because there are not up to OE standard, but hwo many aftermarket parts honestly are?? The people I spoke with said they had no problem with the products so I took the chance, and so far no problems.
RIP 328is
Both are great companies! Lemforder is OEM, however Febi is owned by bilstien. Both are great like I said.
"When tolerance becomes a one way street, it leads to cultural suicide."
