Results 1 to 7 of 7
Thread: M62 Power Steering hose Replacement DIYs
    West Michigan
    98 540iA (Prd 11/97)
    M62 Power Steering Hose Replacement DIYs
    __________________________________________________ ____________
    High pressure PS hose replacement!
    Thanks to Qsilver7.
    Calgary Alberta Canada
    530i 2001
    none of the photo's in the first link show up for me. Help
    Nov 2014
    Dallas TX
    2018 M2
    Does anyone have any info on the power steering oil cooler return line (steering box --> cooler)????? I can't see where the line goes into the steering box
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    The lines to the box attach as shown in the pic, you may need to blow the pic up. They are #5 and 8.
    Not easy to get to at the box end.
    http://www.realoem.com/bmw/showparts...27&hg=32&fg=20
    Nov 2014
    Dallas TX
    2018 M2
    Yea I've seen the real oem and bently diagrams. They are completely worthless. They don't even show the lines going into the cooler correctly. I figured it out though.
    Link for what I did: http://www.bimmerforums.com/forum/sh...5#post28331685
    Oct 2012
    Chestnut Hill
    1998 540i
    Confused by Link
    Quote Originally Posted by jamesdc4 View Post
    Thanks to Qsilver7.
    The link above for "High pressure PS hose replacement!" goes to the "7 Series E38 Forum". This engine is also present in the E39 series for the 540i. How much of this DIY is applicable to the E39?
    Oct 2015
    Washington, IL
    2003 540i6
    Quote Originally Posted by mberg75 View Post
    It's the same setup. Use the write-up in conjunction with the diagram link Jim provided in the 4th post. I don't recall having a fancy clip though.
    2003 540i/6
