I've always dreamed of doing this and when I saw it done on youtube, I knew I had to do it.
I promptly removed my tape deck from the center console and got to work.
I will be removing most of the tape mechanism, coating an iPhone sized area with felt so that it doesn't get scratched and running a DICE Silverline into a dock positioned at the end of the tape area.
Here's where I've gotten so far (damn those little screws are in tight...)
Update 12/20 - Ordered Dice Silverline. Its ready to roll as soon as I get the module.
reserved
Since the tape hole is just BARELY large enough for the 3G iphone (although the old one fit through fine, weird...) I had to bust out the knife and shave down the opening. I'll sand it later, I promise.
I removed all the internal components (what a pain in the ass) and made enough space for a slot loading holster case. I fitted it loosely and tried everything out... slides right in!
Used a knife (yeah I know I know) to drill a hole in the side for the iPod cable.
So, um, it fits. I reinstalled my business tape today just to make sure I hadn't destroyed anything in my hacking and gutting. It works! Unfortunatly I was sent the wrong DICE connection type (trunk rather than radio) so I have to sort that out before this will start working.
Last edited by taylorwilsdon; 12-25-2008 at 02:50 AM. Reason: Automerged Doublepost
E46 M3 | Steel Gray/Imola Red | 19" BBS RS-GT
E39 540i | Jet Black/Black | 17" Style 42
This should be a fun post!
Good work so far.
Halston Pitman | sales@bavsound.com
BAVSOUND | BMW Audio Upgrades, Made Simple
www.bavsound.com | 404-381-1800
Plug & Play BMW Speaker Upgrade Kits | BMW iPhone, iPod, Android & SirusXM Integration | BMW Subwoofer Upgrades
If using a 3G phone, what will you do when an incoming call comes in?
I'd recommend using a dedicated iPod instead.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x22 | fax: 714.908.1796
Twitter | Flikr | Facebook | YouTube
Subscribed!
2003 530i SP, PP, CWP, Dinan CAI, Dinan Throttle Body, Dinan Stage III Software, Dinan Strut Brace, Dinan Shock Brace, Dinan Camber Plates, Bilstein Sport, Vogtland Springs, Eibach Anti-Roll Kit, OEM M-Pars 18X9J 275/35/18 all around, OEM M-Aerodynamics Kit, Beisan VANOS Seals, Bavarian CDV, Bluetooth Retrofit, Sirius Retrofit, Driver's 4-Way Lumbar Retrofit, Rear Sunshades RetrofitBMWCCA Membership # 405708
cool i might try this myself
1989 BMW M3
1999 BMW 323i vert
keep it coming with the good stuff. i plan on doing this to a 540 and 740.
I stand up and applaud to your creativity and effort!
subscribed
The most fun you can have with your clothes on.
Ive seen this before but they used one of the first gen I-pods, it was beautifully integrated system, subscribed to see how its done
MODS
1JZ, BC 264 cams, BC TI Springs and Retainers, Ferra Keepers, Arp Head Studs, Arp Main studs, Arp rod bolts, Custom Emerald Performance Dual Plenum intake, 70 mm TB, SC6169 T3 Turbo, full 3 inch SS exhaust, Ar5 Transmission, 60lb injectors, Walbro 400 fuel pump, GTR intercooler. Porsche Turbo Calipers, Gutted Tein SS coilovers with Koni Race shock inserts , Tein Pillowball Camber Plates, UUC Swaybarbarian bars....needs more mods and a tune!!!!
sick man, more oem style solution to my head unit
Vee put vindshield vipers on aur headlights becaush ve are from Shveeden and it rainesh and shnowhs a laut en Sveeden!
Ordered my DICE Silverline tonight, so hopefully this will be up and running right after Christmas.
very creative idea. i hope that it all comes together smoothly for you
i miss my E39
Added some very ghetto updates. All I need now is my stinkin' correct DICE unit and its getting ready to roll. I'm going to break the locking pins off the iPod cable so that it can be removed without having to open the dash to press the pins together.
Thanks for the kind words thusfar, I'll be sure to keep you all updated.
[QUOTE=taylorwilsdon;15091912] I'm going to break the locking pins off the iPod cable so that it can be removed without having to open the dash to press the pins together.
QUOTE]
I had a thought on this, why not wrap it time with electrical tape or use a zip tie so you don't have to break off the pins.
1989 BMW M3
1999 BMW 323i vert
just subscribed to see what happens with your project. it looks awesome.
ive seen it on youtube and loved it straight away. im thinking of having a go myself as i am having the alpine ida-x100 fitted next week and thought it would make sense to make use of the factory tape deck.
although once i get it going (will see how yours goes first) i want to mod it a bit to make it more secure. a couple of my family are into metalwork and i am goin to use the tape deck as a basis but get them to put something similar together that is set back in a little bit with room to put a cover on the front to hide any devices you have plugged in. think this will work?
what i did was file them down to round shapes instead when I built my flashlight area dock. They still work to help retain the connector in the ipod but don't prevent you from removing it.
how are you going to hold the ipod and connector in place? or is this more like a hidden storage bin solution
subscribed!
Will it still play cassettes?
[ame]http://www.youtube.com/watch?v=hfF6HVjgeEA[/ame]
LOL!
Good work!
ive seen this too, cant wait til its done!
im having a go at something similar to this but am having problems finding a holster for the ipod classic to slide the ipod into inside the unit. any ideas where i can get one of these?
Taylor any update on this?
Halston, the replacement DICE I received had the wrong harness again At least this one works. Its not my 1st priority right now so I've put it on the backburner but I'm going to try one more swap, and then just buy the R17 harness outright from EAS.
