For those of you who have removed these, any tips on the best way to go about uninstalling them? Any advice on removing these pieces in general?
I have only taken off the front pillar covers. Pop off the plastic caps, and there will be a torx there. After you remove that, you have to gently pry it off. I wound up breaking the tab in the middle because it is so fragile.
Rear lip $130
http://forums.bimmerforums.com/forum...9#post15593279
For the C-Pillars, I used this page, starting at the "Removal of rear parcel shelf" heading.
For a general tip, I would use clean, proper panel pulling tools so you don't damage or dirty the fabric.
I'm planning on wrapping the pillars and headliner in alcantara, that's the purpose of the whole removal.
My gf's little bro did it to his M3 over the weekend but I wasn't there to see how it was done. He's going to work on it with me whenever we decide to start, but we were trying to gauge how hard it would be to remove all the pieces to begin with.
Thanks for the help
i was thinking of doing the same cause im getting all the materials for wholesale... i got a leather dealer thats hooking me up...
when you re wrap the pillar panels they are a bit of a pia to get back on. be real careful getting the snaps to re snap (that sounds real dumb). you have to apply just enough pressure to snap them on, any more and you end up breaking them. i re did my old e39 and ran into this problem. you can get away with breaking one or maybe two any more than that and the panels end up sagging or bowing out and looking like crap
I know I'm going to break at least a few of them. Hopefully when I start doing this, my gf's little bro will be more helpful about getting the things removed without breaking any clips.
Has anyone ever seen a diagram showing exactly where the clips are?
Another option was just to buy all the pieces, either from a junk yard or salvage yard, then try the wrap job and finally do the install. I might still go that route, I just need a long weekend to start the project.
it will look sex like this
One last little question here:
All e39's have the same fitment for the pillars and headliner, correct?
so i took it off tonight... i was boared... wow alot of pieces... on the front curtain so the a pillar theres a torx bolt behind it... dont break the middle piece either... im sending them out to get reapholstered dunno how much itss cost but hopefully not that much since i did most of the legwork... also i dont know how to take out the sunroofs lid to do that too... if i cant get that doen i might just dye it or leave it... and do a dark charcoal alcantara on the roof... yayer....
only thing i want the opinion of is should i get the visors redone in alcantara as well... and should i do a two tone thein with light and dark grey alcantara???
Black interior looks so nice all around...
the hardest part is getting it off the sunroof... i still dont know how to get off the moon roof cover...
