perhaps my memory is foggy but wasn't someone working on a rear disk brake conversion that was less expensive than the ebay kits or buying 323 rear control arms? Did it happen?
The first freedom is not speech, or guns or religion. It's choice.Originally Posted by jrhaileYou know, it's time like this that brings a tear to my eye about this community: We all tuned in to support a fellow BMW driver elude the po-po. In the end, there is only one winner here: bimmerfourms.com and its members. I hope one day when I'm doing 150mph down the freeway that you will all support me, as did this fellow enthusiast. Drive on bimmerheads, drive on
320I building enough boost to run air tools..on CIS, waiting for my rear diff to
It's not really possible to sell a kit for less. If you make your own of course it is. Nic and I both are working on homemade setups (more theory than actual work in my case). It's really a simple problem, but nothing is cheap these days.
not hard, but machine work is expensive.
someone get this man some specs, please! i would be more than happy to 'demo' a set for you, dj
No parking brake = no pass inspection.
I have postponed all goodie projects until the car is back from the booth, reassembled and driving.
Yes I know, this is what 2002parts.com sells. (also on ebay I think) If you add up the cost of all the components though, you're left with about $100 for the customs brackets. It's a fair price, and unless you make the brackets with your own hands or find the calipers really cheap you can't save any money.
I think its worth noting that no one on this forum NEEDS rear disk brakes.
HA I probably know that better than anyone, I was just pointing out that there's no use moaning about the cost when you can simply opt to not buy them.
I think someone told which models they fit the last time we talked about this. They were quite expensive new if I recall.
Slightly off topic. In addition to the trailing arms, calipers, lines, and rotors what else is needed to do this swap. Any help is appreciated.
"..Horsepower is a measure of work done over time, or the rate at which work is done."
http://www.cardomain.com/ride/579694/1
Vented drums... Doooo it.
"The most important thing is balance." - KT
On the 2002 rear disc conversions you use Golf/Jetta calipers/brackets from MkII's. I would think the Mk III's would also work. I used calipers from an Audi as they were the same. You can also use Golf/Jetta Mk IV calipers (they are aluminum) with the Mk II brackets. Not exactly sure of the years but the Mk IV calipers I have are off a '99 Jetta. The all have the emergency brake built into the calipers so it is just a matter of adapting your emergency brake cables to fit. Mk II stuff is very common in the local pick-n-pull.
By the way the 2002 conversion uses the Mk I (Rabbit) front rotor and it is 9.6". Mk II and later fronts are all vented discs and will not work with the rear calipers.
Hope this helps.
Steve.
The drums are quite substancial in these things. Now primary problems with these devices of reducing speed, is that they reduce speed and heat up, and then wear unevenly and then just shit themselves. So they used to put cooling fins on them in the olden days, much like you would see on an aircooled 2 stroke motor.
Heres my proposition, and i doubt it would get off the ground but its interesting none the less, instead of having cooling fins that are alligned with the rotational surface of the drum but instead have cross fins that are pointed towards the rims on an angle, taking advantage of the high pressure zone and cutting into the air and cooling the drums. of course you would have to cast them, and by then you have hyper improved drums, but they are still drums. You would have turbine drums...
I guess with a rear disk conversion it leaves opportunities for such kits like from the big brake people.
But whatever goes, it was an interesting idea none the less ( for me at least)
Franzen
On the old solid axle Corvettes, they used a cooling fan that fit between the axle flange and the drum. It was stamped metal and would pull air in the large openings cut in the backing plates. The openings had screens to keep debris out. This was used on the race cars of this period.
Still no where near as good as disc brakes for disappating heat.
