Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: *DIY M50 VANOS Oil leak-Fix found!
    PA
    Girl car
    As many of you know, I've been fighting with a nasty oil leak on my M50 with VANOS. The leak was these two caps that look like freeze plugs. To my knowledge, all E34's have the same setup as I do. The setup is a clip holding the cap. On newer models, the plugs were pressed in;and if they leaked, you are screwed.
    The other day I got a nasty oil leak again. I got tired of it pissing oil on the driveway; so I pulled the housing out. Then I removed the caps. This is done by sticking a small flat head screw driver in the special notch to pry the clip that holds the caps in. After that, I used my finger nails to wiggle the caps out.
    Well what do I find in there? An o-ring!
    It appears to be that the lower cap covers a relief valve and the upper one just covers a hole?
    Lower:
    Upper:
    Anyways, I went to Autozone and got a box of assortment distributor o-rings for GM vehicles. It had a perfect match!
    Fitted onto a cap:
    I haven't reassembled this yet so I cannot confirm if it will leak or not. But the old o-rings were hard and flat, so I don't see how they could seal the caps. I'll report back tomorrow once I get it all assembled.
    The reason I posted this is because I've searched a lot on finding a fix for this but without any luck. So I decided to figure it out myself. Hopefully this will help people in the future. A new housing is $400+, o-rings cost me $3.
    P.S. If you notice that yours is leaking and you say to yourself "Its only leaking a little bit, I can deal with it." Well don't put it off. I put it off because it leaked a little bit. Then, as I mentioned, one pleasant afternoon I start the car up and oil is pouring out.
    Edit:Part number is 90441. This is in the HELP section at Autozone. The manufacturer is Dorman.
    Vehicles:
    (Sold) 95' 525 - ZF320 5-speed swap, 3.46LSD rear, Raceland headers + straight pipe
    (Current) 2012 Scion tC 6-spd M/T - slow
    Great White North
    various
    good detective work. I hope it fixes the problem
    Atlanta, GA
    '11 328xiT/6, '99 M3
    Hope it fixes it. Have you looked into Dr. Vanos if it doesn't?
    -Denton
    PA
    Girl car
    Dr.Vanos, to my knowledge, has nothing to do with the oil filter housing. It is suppose to replace the solenoid and a few other things that rattle over time.
    Vehicles:
    Oct 2008
    Grand Rapids, Michigan
    95 BMW 525i - New engine - well not really new...
    Great Info - hopefully this fixes it
    Jul 2005
    Crook County
    BMW X5, Lotus
    Yeah
    Thanks for sharing.
    Atlanta, GA
    Quote Originally Posted by russiankid View Post
    Gotcha, didn't know what was included in the kit...got confused when you talked about a new VaNOS unit.
    -Denton
    Kansas City MO
    Too Many
    Im interested to see if that fixes it. I noticed tonight I have an oil leak in that area. I plan on searching for it this weekend.
    Jun 2006
    The Eagle's Nest
    bf.c e34 contour
    WEll written!!!
    This should be in the FAQ section!
    Sep 2002
    USA
    BMWs
    Awesome
    FWIW I think the non vanos housing is plugged with threaded plugs.
    Nov 2007
    E36 328i
    nice product placement w/ that coke.
    Aug 2008
    ATL HO
    1992 BMW 525i
    Keep us posted. Thanks, Johnny
    * Discounted Price * Style 8 Wheels, Brembo Rotors, Stainless Brake Lines ETC. For Sale All New.
    http://forums.bimmerforums.com/forum...1#post21382181
    PA
    Girl car
    WARNING! Check your oil before starting! I drove the car a little bit and got home and the engine oil level warning came up.
    Anyways, both caps are dry so far. They popped into position right after the oil pressure built up and they stayed dry.
    Vehicles:
    Jun 2008
    Somerset, NJ
    American
    Hmmm...I'm gonna have to look into that also....
    PA
    Girl car
    I will post the part number up tomorrow, to tired to get it today.
    Hardest part of the job is getting the housing out of the car.
    Vehicles:
    Jun 2008
    Somerset, NJ
    American
    Yeah I saw that. I was looking at it and I'm like yeah. This is going to be on hold until the weekend.
    PA
    Girl car
    Quote Originally Posted by somerandomdude View Post
    Over all it took me 45 minutes to get the housing out. Since I have school it took overall two days to complete. Tomorrow my HID's go in.
    Vehicles:
    Jun 2008
    Somerset, NJ
    American
    Nice. How are they?
    PA
    Girl car
    Haven't installed them yet. I didn't have time to get them in today.
    Vehicles:
    Nov 2007
    SoCal
    '93 525i
    A aprt number for what?
    PA
    Girl car
    Quote Originally Posted by e34freak1993 View Post
    The o-rings.
    Vehicles:
    PA
    Girl car
    Vehicles:
    TX
    e46 330i
    That's where I seem to have an oil leak as well (if it's not the oil pan gasket, that is). Thanks for the input. Now all I need to do is to figure out how to remove the oil filter housing. Thanks Bentley for nothing on this subject
    Black Sapphire MetallicNatural BrownSilver Cube e46 330i ZHP/6MT - Sold
    HellrotDove Grey e36///M3 - RIP
    Black Sapphire MetallicNevada BrownDark Bamboo e70 X5 xDrive4.8
    Alpine WhiteCoral RedAluminum f30 328i Sportline/6MT
    Imola RedBlackBlack Aluminum e46 330i ZHP/6MT
    PA
    Girl car
    Quote Originally Posted by cngzsn View Post
    1.Remove air duct tubing for alternator.
    2.Remove air box.
    3.Remove fan,shroud, and belt.
    4.Remove alternator by removing the idler pulley and lower bolt. Remove two bolts that hold the wiring on.
    5.Undo the two top bolts that hold the power steering pump to the housing. I didn't remove them completely I just slid them out.
    6.Undo the bolt for the oil filter cap so oil can drain back into the oil pan.
    7.Remove the banjo bolt for the oil line on the VANOS solenoid.
    8.Follow the oil line and you will notice its clipped to the fuel line. Remove the clip so you want rip the lines when removing the housing. Also, remove the connector for the oil pressure switch
    9.Now, get a piece of paper and draw the bolt pattern. I used bags, labeled 1-6, and on my diagram I labeled where each bolt goes.
    10. Remove the 6 bolts and pull housing out. You will have to find the best way to get it out. Both times I pulled it out I angled it a little differently around the radiator hose. Its not hard, just wiggle it around.
    Installation is reverse of removal.
    Vehicles:
    TX
    e46 330i
