Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 5 Series (E12, E28, E34, E39, E60, E61) > 1988 - 1996 (E34)
Old 10-07-2008, 02:05 PM
M5W's Avatar
M5W M5W is offline
Cars: 91 M5, 86 325es
Send a message via MSN to M5W Send a message via Yahoo to M5W
S38 Headers Wrapped
Heres some pics of my lastest venture. DEI Exhaust wrap on my headers and some block-off plates for my air pump entries. Just have to cut off the air tubes going out of the port, then spray the headers with high temp silcone spray and there done.
Before: naked
Now: All bundled up
Air Pump Block-Off Plates
The high temp graphite gaskets
Masked off areas for spraying
After Spraying
Cleaned Up Flanges
Old 10-07-2008, 02:32 PM
5mall5nail5's Avatar
5mall5nail5 5mall5nail5 is online now
Smell the Glove
Cars: 3
Send a message via AIM to 5mall5nail5
I would use copper spray to seal the block offs to the headers as those will probably leak over time.
Old 10-07-2008, 03:01 PM
M5W's Avatar
M5W M5W is offline
I'm picking up some high temp graphite exhaust gasket sheet after work today, will that last long ? My only concern is it leaking over time. Use copper spray with those as added insurance ?
Old 10-07-2008, 03:14 PM
attack eagle's Avatar
attack eagle attack eagle is offline
Mutual Admiration Society
Cars: `03 Tahoe
Send a message via AIM to attack eagle Send a message via MSN to attack eagle Send a message via Yahoo to attack eagle
looks nice.
`03 Summit White Tahoe LT
LM7, G80, GT4, PDZ, ZW7, G65, PDP, etc.
Member #5
Old 10-07-2008, 07:49 PM
Burn535i's Avatar
Burn535i Burn535i is online now
like a boss
Cars: 06 GLI, 92 535 (SOLD
badass
Old 10-07-2008, 07:52 PM
romodude06's Avatar
romodude06 romodude06 is offline
Cars: 1994 BMW 525i
That looks sick. :]
Old 10-07-2008, 09:01 PM
nmp411's Avatar
nmp411 nmp411 is offline
Cars: 90 535i
Niiiiice
e34 parts for sale!
http://bmwpartout.yolasite.com/
Old 10-07-2008, 09:03 PM
screwbiedoo15 screwbiedoo15 is offline
Cars: 90 535i/5, 89 325i/5
Looks very nice. Jw, how come you didn't do ceramic coating?
[E34] Miller MAF. 3.64 LSD. Racing Dynamics Headers. Remus Catback Exhaust. Bilstein HD Shocks. H&R Springs. M5 Sway Bars. Racing Dynamics Strut Bar. Racing King Subframe Inserts. Clear corners and tails. Euro bumper trim. 17" BBS RX wheels.
Old 10-07-2008, 10:40 PM
M5W's Avatar
M5W M5W is offline
I decided to wrap em just cause. No real reason.
Old 10-08-2008, 12:28 AM
OrE34's Avatar
OrE34 OrE34 is offline
AutoX in 2010
Cars: 94 e34, 84 e30
Send a message via Yahoo to OrE34
gives the headers a good look. awsome
Old 10-08-2008, 01:55 AM
TheGoldenOne TheGoldenOne is offline
Do Work
Cars: '92 525i, '86 325es
very nice job on the wrapping...I neglected to use gloves/longsleeves while wrapping mine and boy was that a mistake. How did you do it?
Old 10-08-2008, 10:14 AM
M5W's Avatar
M5W M5W is offline
Latex gloves and dipped the wrap in water before wrapping it around the headers, gets a much tighter fit when it dries.
Old 10-08-2008, 11:24 AM
Smell the Glove
Cars: 3
Also traps moisture and causes corrosion
Old 10-08-2008, 11:58 AM
teambutter's Avatar
teambutter teambutter is offline
Cars: 97' 328is
Send a message via AIM to teambutter
Hmmmm.. I would've thought that once the headers got to operating temp there was no way moisture could be retained??
Old 10-08-2008, 12:02 PM
Smell the Glove
Cars: 3
The fiberglass cloth in and of itself traps moisture... operating temperature or not.
Silicone spray can help, but it can also trap moisture.
Ceramic coating is always preferred used
I'd show you a picture of my old manifold after removing the DEI heat wrap, but I don't think I have it any longer. It was terribly rusty and corroded. It was stainless.
Old 10-08-2008, 12:05 PM
M5W's Avatar
M5W M5W is offline
I used a little electric heater overnight to dry them , and i'll be masking of the unwrapped areas tonight and spraying the wrap with a high temp silcone spray from DEI made specifically for protecting header wrap from moisture and corrosion. And also a wet header dosent stay wet very long after being heated up to 1500°.
M5W's Avatar
M5W M5W is offline
Old 10-08-2008, 12:06 PM
M5W's Avatar
M5W M5W is offline
How long did it take to get as rusted as you say it did ? A season ? I couple years ?
Old 10-08-2008, 12:15 PM
teambutter's Avatar
Cars: 97' 328is
Thanks for the info 5mall5nail5... Learn something new everyday...or try to at least!
Old 10-08-2008, 12:21 PM
M5W's Avatar
M5W M5W is offline
I'm actually concerned now. How long did it take for the wrap to fail ? I followed the procedure to eliminate any air pockets in the wrap and it has dried tight to the steel. After spraying it is there any other way to keep it dry ? Also i only drive this car in the summer and it rarely sees rain.
Old 10-09-2008, 04:11 PM
M5W's Avatar
M5W M5W is offline
Updated
Old 10-09-2008, 04:24 PM
Smell the Glove
Cars: 3
The header wrap didn't "fail" but when I removed the setup from my car after a year it was heavily corroded underneath. I'll look tonight I think I have my wastegate dump tube still.
Its not really a matter of seeing rain - moisture in the air gets under that stuff, normally the moisture evaporates with ambient heat or exhaust heat, however if moisture gets underneath its not as quick to burn off, if at all, and it corrodes.
Don't worry about it, but next time I'd send them out to be coated.
Old 10-09-2008, 04:38 PM
M5W's Avatar
M5W M5W is offline
k. Also looks like because of funding issues my turbo project is put on hold yet again. Having Metric Mechanic putting in there rally cam (284 degree intake, and an e28 m5 exhaust cam (254 or 256 i believe) with the port work so i'll be running NA for another season or two and if and when i go turbo i will swap out the rally cam for my stock cam.
Old 10-11-2008, 01:55 AM
M5W's Avatar
M5W M5W is offline
Updated. Just waiting to cut off the air tubes next week.
Old 10-26-2008, 01:01 AM
M5W's Avatar
M5W M5W is offline
Here are my air tubes cut off
