these are excellent for the e46 fogs and e39 in general, very few LBF errors with this kit, we have a 95% success rate with all the "difficult cars".
kit includes:
2 ballasts with built in igniters.
2 BT hid bulbs.
you can add a lifetime warranty for under $10.
add a set of GENUINE depo ellipsoids, DjAuto or our very own BT ellipsoids at an incredible price.
complete the package with a set of predator Orion V2's for an unbeatable package.[/size]
brackets as well as fog light adapters are available(slightly extra)
free bavtoys stickers while they last.
click here to place your order:
BavToysHID
-zkw- -hella- -bosch- -depo- -prolumen- -kwd- -bbs- -predator chromium- -predator ice- -simota- -ecis-
//-install guides-//-total lighting group buy-//-zkw group buy-// -exhaust group buy-//-ellipsoids+hid group buy-//-led tails group buy-//
Wattage?
H1 5000k is included right?
Good fawking lawrd that is uber cheap!
wow, cheap...
Maybe I'll get some H4's
we have 20 of these left, after that they are gone.
I have a 1998 e36 sedan, if i get the D2S HID kit it will convert the headlight into true xenon light right?
Also what is the difference between color - 5000k, 6000k, 3000k(optional) and 8000k(optional) packages?
The fog light adapter harness will allow me to add HID's to both the fog-lights right?
What is the D2s Adapter Harness? and the Predator Orion V2
Lastly, i have the complete Stock headlight unit that came with my car, it has never been tampered with, will this kit fit right into my headlight unit?
Sorry for so many questions here i hope you dont mind, please let me know...
Last edited by Blanchimont; 09-12-2008 at 09:14 PM. Reason: cut cut chop chop more additions
not really, while it will improve your output somewhat the stock headlights aren't very good and they are not meant for xenon.
there's an option to add headlights, they are not very expensive and you'll have the benefit of getting a complete package that drops right in without the need of you doing any modification.
the higher the number the lower the output but the more color you get, 3k is yellow, 5k is white with a hint of yellow, 6k is bright white with a hint of blue, 8k is blue and 10k and above start getting into the purple spectrum.Also what is the difference between color - 5000k, 6000k, 3000k(optional) and 8000k(optional) packages?
the choice should be between 5k and 6k, i and 80% of others like the 6k.
only if you buy an additional hid kit, each kit can only power one set of light, for low's and fogs 2 kits and an adapter are necessary.The fog light adapter harness will allow me to add HID's to both the fog-lights right?
d2s do not apply to you.What is the D2s Adapter Harness? and the Predator Orion V2
orion v2 are the latest angel eye kit we have.
http://www.bavtoys.com/orionv2.php
read above. ditch the stockers and get a set of ellipsoids, you'll be much happier.Lastly, i have the complete Stock headlight unit that came with my car, it has never been tampered with, will this kit fit right into my headlight unit?
Habbie - Will these fit DEPO's? If so... sign me up.
"Don't run out of talent mid corner..."
Wow, looks like a pretty good deal.
Damn, Amazing deal!
2015 ProSolo STX Class Champion
Dam what a deal, I'll be getting some xenon fogs with my new bumper
Great deal. Anything for the E34?
I love all the lighting deals going back and forth.
Month to month newer and lower pricing.
I have the bvtoys e36 ellipsoid headlights which uses h1 bulbs. If I were to order the h1 hid kit for my low beams will it hook up to the oem 9006 low beam harness or would I still have to use the pnp harness that came with the headlights?
I'm assuming that the harness on the back of the h1 hid bulb will plug into the ballast/ignitor and then i would plug my oem 9006 harness into the ballast/ignitor?!?!
habbie do you have H4s? I'm about to order.
5000k?
it won't throw a low beam error code? if it doesn't, count me in.
95 540i beat around thingamajig
02 pathfinder lifted
Ordered a set of h1's for my e34, thanks.
