Results 1 to 25 of 37
Thread: DIY-oil filter housing seal
    Boston
    fast M6, faster camaro
    well, it has come to my attention that a common problem with these is a leaky oil filter housing seal, this is due to using something like a crescent wrench to remove the oil filter cap, instead of the 36mm socket. if you develop a bad oil leak after an oil change.. chances are this is your problem. as embarrasing as it is, since i am a master BMW tech.. i recently made this mistake, when i let another tech borrow my socket and it ended up locked in his toolbox during the weekend that i was changing my oil. being a common problem, i decided to make a little DIY write up for the replacement of this seal. this work was done on a 98 528i.
    tools needed:
    36mm socket
    13mm socket
    16mm socket
    10mm socket
    13mm wrench
    flathead screwdriver
    19mm wrench
    extension
    ratchet
    T50 torx socket
    14mm socket
    tools that will come in handy:
    prybar
    vaseline
    swivel
    parts needed:
    oil fitting washer- #32 41 1 093 596(4)
    gasket- #11 42 1 719 855
    recommended part:
    oil pipe- #11 36 1 705 532
    banjo bolt- #32 41 1 084 908(2)
    ok, now here we go, sorry for the crappy pictures... all i had on me was my phone
    first, check the joint between the oil filter housing and the engine block to make sure this is your problem, it should be leaking somewhere around here:
    first, remove the oil cap with the 36mm socket (remember... this is why we are in this situation) in order to let the oil flow down into the oil pan, this way you don't lose much oil. remove the airbox and MAF sensor. remove the upper coolant hose for better access to everything.
    next, remove the two bolts holding the power steering fuild resevior and move it to the side (no need to disconnect) do so with the 10mm socket:
    once this is out of the way you should have a clear view at the leaking area
    remove the alternator belt. do so by using the T50 torx socket to release the belt tensioner, and pulling the belt off of the idler pulley:
    remove the alternator by remove the two 16mm bolts holding it on:
    and
    use the prybar to get the alternator loose, then remove the two connections in the back.
    1: remove metal clip with a screwdriver, and pull connector off
    2: remove power cable with 14mm socket
    remove the power steering pump by first removing the two top bolts (13mm)
    and then the bottom one (get to from under the vehicle) with the 13mm wrench
    move the power steering pump aside (no need to disconnect power steering lines)
    remove the oil filter housing by removing the six 13mm bolts holding it to the block
    it is easiest to remove the VANOS high pressure line from the cylinder head, and just remove it with the oil filter housing, do so with your 19mm wrench. if you have never replaced this line, i recommend doing so while you have it out. that is the oil line and part number listed above, make sure to also replace the banjo bolts and washers. keep track of the bolts removed from the housing, as they are all different sizes.
    once the housing is loose, remove the pressure sensor plug connection in the back, similar to that of the alternator
    once removed, pull the seal off of the block, or the housing (whichever one it stuck to) it will probably be faitly brittle and hard, and clean the mating surface thoroughly. i took this opportunity to use the parts washer and clean everything off... if you don't have access to one... brake cleaner will do just fine.
    once clean, press the new seal into the grooves on the housing itself, no gasket sealer needed
    before installing it, check the condition of the two dowel pins in the block, make sure they are not bent or damaged in any way... if they are, replace them
    from here... install everything in reverse order, and tighten the housing bolts in a criss cross pattern in steps. this is a great time to replace the belts as well.
    i hope this helps some people... let me know if anything is unclear please.
    mat
    Last edited by jamesdc4; 11-15-2009 at 07:48 PM. Reason: Corrected part # for oil filter gasket.
    Martinsville VA
    2003-525i BMW
    Thanks for one great write up--thats going to help many here in the future and it may be me---I wonder how our moderator thinks about-- the way that oil filter housing is in no way connected to the block---seems connected to me.
    If I may be permitted to edit
    This write up with the picks needs to be in the general how too's in our diy lists!!!!!!!
    Boston
    yea... it felt pretty damn connected when i pulled it off... haha
    thanks!
    all in all.. it took me about an hour and a half... but that's with a lift.. not to hard a job
    Los Angeles, San Francisco
    2000 528i (01/2000 mfg. date)
    Real good writeup, thank you bowmang. I'm curious though, how does using a crescent wrench cause breakage as opposed to the 36mm socket? Don't both tools just torque it the same - right at the center of the cap, or does the crescent wrench do it eccentrically, causing a shearing force?
    Boston
    ya know, i was wondering the same thing... so i put it to the test, since mine was already damaged... i checked it out. i first used the socket, and watched where the damage was done... i could not see anyy flex or anything that would cause such damage... so i installed the cap, and removed it the same way i did before... with a crescent wrench, and there was clearly some flex going on there... i could see it pull away from the block very slightly.. it didn't look like much, but apparently it was enough to cause such a leak. i suppose it is because the socket puts only turning force on the cap, whereas the wrench pulls on the entire assembly before breaking the cap loose.
    Tucson
    03' 540i/6 M-tech
    You better replace that belt!
    chiefwej 2003 540i ///m-tech 6-speed Black Sapphire Metallic w/gray
    See: My REGISTRY PICTURES
    Mods:plate delete, debadged, 35% tint,euro console, Evans NPG (zero pressure cooling system), CDV delete, Rogue Octane SSK, RP Symcromax
    Quote Originally Posted by bowmang View Post
    Thanks bowman. That makes sense since the socket would be perfectly on center and the crescent would not be. I guess the same might happen with a strap wrench. I'll check mine next oil change!
    Boston
    haha... yea... belt definately got replaced when i saw that!
    Apr 2008
    St. Francis, MN, USA
    528i
    The gasket part number is for a oil pan gasket. Do you have the part number for the oil filter housing seal?
    Boston
    oh.. really?> my bad, i posted the wrong number.. give me a second, i'll get it
    Boston
    ok... fixed
    the part number is 11 42 1 719 855
    Dec 2007
    Seattle
    528i, 240sx, sc300
    This should be moved to the DIY! thanks op, this was very very helpful.
    Boston
    yea... i didnt't know about the DIY section until after i wrote it... if the mods want to move it, please feel free
    Martinsville VA
    2003-525i BMW
    It's been over there since right after you wrote it up--it's in one of the sections
    that you have to click on to get too---DIY needs to have all the stuff listed in
    one long list--but it's good to have in any format
    Boston
    Quote Originally Posted by Poolman View Post
    oh really? well it's good to know that the mods are one step ahead of me
    Hong Kong, Shenzhen, China
    '01 530iA, '05 750Li
    Excellent write up....
    When I had my done last couple weeks ago, I thought I was leaking oil from the oil pan....whew....
    But I'm a little confused about removing the oil filter cap...which tool to use to avoid damage to the seal?
    Again, big props to you for the informative write-up!
    Boston
    Quote Originally Posted by Jim530i View Post
    yea.. when i first looked at, i thought it was the oil pan gasket as well.. i even ordered the part.
    all you need to avoid the seal being damaged is a 36mm socket... that should do it
    Jan 2006
    Perry, GA
    E36 M3, X5 4.6is, E85 Z4
    Great writeup, thanks! With your help, I did this repair today on my '99 528i (10/98 build) and I wanted to add a few thoughts.
    The job is pretty easy, there is just a lot of disassembly that must be done to gain access to the filter housing. Although it was basically the same as you described, there were a few minor differences in my car.
    First of all, DEFINITELY disconnect the battery first. I skipped this step and found out that the positive lead to the alternator is hot even with the ignition off. I accidently touched a wrench to it while removing a bolt and POW! Sure as hell got my attention. I went straight to the trunk and pulled the negative lead from the battery.
    My alternator came out pretty easily. I did have to use a prybar, but very little force was needed to free it. Getting it back in was another story. I wrestled with it for at least a half hour before finally coaxing it in. The lower bracket is very tight and the only way I could get it back in was to loosely install the upper bolt and then swing the alternator down and tap it into place with a rubber mallet. I had to use a light and mirror to look into the lower bolt hole to get it aligned so the bolt would go in.
    I didn't have to remove the coolant hoses. It made it a little tight to work, but it was worth it in my opinion. I removed the fan, then just sat it down in the bottom of the cooling shroud carefully leaning against the back of the radiator - I never actually removed it from the car.
    On my car, there are only 2 bolts holding on the power steering pump. So it wasn't necessary to raise the car and get underneath it. I did anyway, though. Mostly so I wouldn't have to bend over as far to work on it (hurts my back to hunch over the engine for a few hours). I also wanted to look for a coolant leak "while I was in there". It looked like it might've been the water pump and the bearing did feel a little loose. I had an extra one and there was never going to be an easier time to replace it, so I went ahead and swapped it out.
    The old gasket was hard as a rock and very brittle. And there was oil all over the side of the engine.
    Hopefully this was the source of my oil leak and I won't have to deal with the oil pan gasket!
    1998 ///M3/4/5 | 1999 528iT | 2003 Z4 3.0i
    Omaha, NE
    1998 528i 5-spd 102K
    Here is another write-up that has been around for a while.
    1998 528i:
    http://www.bmwtips.com/tipsntricks/oil/housing.htm
    Boston
    thanks for the tips guys!!
    everything you said is pretty much right on the money.. nice work!!
    Omaha, NE
    BMW spec calls for 25 Nm torque on the Oil Filter Cap, which I think is a bit much. This torque twists the housing upon install and removal of the Oil Filter Cap.
    Take another close look and you will see that the sealing is achieved by the O-ring making contact SIDEWAY with the housing.
    The O-ring sealing is different when compared with paper gasket (which mates the 2 flat surfaces together and it requires the torque to seat it properly).
    What I do these days to make install/removal easier and to prevent damage to the Oil Housing?
    Tighten the Cap with 36-mm socket until it fits snugly.
    Then using only 2 fingers on the ratchet, give it a slight tug and that is it.
    I have been doing this trick for 3 years, not a single drop of oil leaking.
    Removal of the Cap is a breeze.
    Actually try this next time you change the oil: just tighten the Cap down until it stops, start the engine, you will NOT see any oil leak. Actually even with this snug fit, the Cap won't even come loose (notice the friction when you tighten the cap?).
    The reason I do a little tug at the end is just to make sure the Cap is nice and snug. I stay away from 25 Nm torque value.
    Philadelphia, PA
    1999 BMW 323ci White
    Oil filter housing seal project
    First, thanks to everyone that's taken the time to post their knowledge on these pages. OK, my oil filter housing is leaking and I will be replacing the seal and the O-rings. I'll try to take as many pics as possible to post them and I will be reading and checking these post to gain confidence on this project. Thanks to everyone. I will need some O-rings.
    Omaha, NE
    Quote Originally Posted by rayros215 View Post
    For cross-reference, I wrote the DIY Oil Housing Seal for my 1998 528i here.
    NOTE: Use ONLY BMW seal ($6 at dealer).
    http://www.forum.bimmerfest.com/showthread.php?t=414315
    Middle of a corn field
    E39 hamster/ruberbandPWR
    Good thread!
    Getting ready to do this, just as soon as I clear enough space on my garage floor...
    Quote Originally Posted by cnn View Post
    Isn't VICTOR REINZ the OEM gasket?
    http://www.eaceuroparts.com/parts/pa...01%20719%20855
