Hey guys, I just replaced my coolant temp switch and was bleeding my system when for about 10 minutes nothing but steam came out of the plug. fearing the worst, I closed the bleed valve, and turned off the car... does anyone out there know what might be going on? is this by anymeans normal? Its a 1987 325is by the way. Thanks!
Perhaps the bleed valve wasn't open enough and/or the coolant temp was too high? Water turns to steam at 212 degrees Fahrenheit. If the system isn't closed, then steam will escape to atmosphere where ever possible.
I have had good success bleeding by getting the nose of the car up as high as possible (ramps work great) and filling via the overflow tank. The engine is then run with the temp dial turned full hot, with fan on high and vents set to defrost. When warm air starts coming out the defroster vents, then the bleed valve is opened until it just about falls out. Usually less than a quarter cup of fluid sputters out before going to steady stream state. The bleed valve is closed as soon as a steady stream of coolant comes out.
I suppose a blown head gasket can cause an inordinate amount of air in the coolant system. Hopefully this is not the case.
Joe M in WV
hey thanks a lot! i'll try that now! if my head gasket was blown wouldnt i be able to tell rather easily... ex. oil everywhere, creamy gunk in the valve cover etc...? Thanks again!
Try this as the bleed procedure:
1) Using ramps or a jack get the front of the car 1' or more higher than
the rear. That will make the radiator and bleed screw the highest point
on the engine and facilitate removal of air.
2) With the bleed screw open, add coolant until no more air comes out of
the bleed.
3) Leave the filler cap off, or at least loose, and set the heat for max
temp and fan speed. Leaving the cap loose will prevent air that's still
in the system from causing a "coolant fountain" once the engine heats
up. Start the engine and allow it to warm up to operating temp. As it
warms up occasionally crack the bleed screw to release any air and top
up the coolant as necessary.
4) Once the engine is at temp bring it up to 2000-2500 for a few seconds
several times. Then crack the bleed until no more air is released. At
this point the heater should be throwing lots of hot air, which
indicates that the heater core is filled with coolant. You may have to
repeat this a few times to get all the air out.
Jim Levie, Huntsville, AL
Honestly this thread is some of the best advice i have seen here in a while. I was just about to start searching and this popped up!
now how about the same kinda walk thru for the clutch
Thank you guys!
Need Illustration or Design work? www.robbiebyerly.com
yeah, it took a good hour to bleed my e30! best of luck
Bav's Build Thread: http://www.stanceworks.com/forums/showthread.php?t=2498
Ok guys thanks again! I think I got her bled!
