After replacing two bad windshield washer pumps today, I opened the bad ones up to see if they were clogged. As you can see it looks like they both got water in them and rusted out. One was the intensive fluid pump under the hood and the other was the one under the front passenger wheel liner. I did not have to take front wheel off to get to the pump. Turning the wheel to the far left gave me enough room to get to the pump with just taking out the body panel rivets and two bottom wheel liner screws. Now I have working WW pumps. I found direct VDO replacement pumps from Autohauz for 20 bucks each. They did not require any rewiring, electrical connections fit perfect.
wow never seen so must rust on a motor
"Lieber Nurburgring als Ehering"
WOW!
Mine are toast!
All the fluid just dumps out after it has been filled.
mine arent working either I think I'll check mine for the rust problem
Live the life you dream of having
I had to break open both pumps with a hammer to see the motors, I could not find any way to open them up. They seemed pretty well sealed, so I guess must rust from the fluid that is pumped through them.
