| Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com. |
Thread Tools |
Turn by Turn Lightning course at NJMP
Lightning Raceway at New Jersey Motorsports Park reminds me a little of a combination of Lime Rock and Mid Ohio. It is a short and fun 1.9 mile track like Lime Rock and Turn 1 even reminds me of Lime Rock’s famous uphill turn. It also has many blind turns similar to Mid Ohio, including Turn 6 which is blind turn going over a hill similar to Madness, except turning right instead of left. There is also a section of turns, Turn 2 to Turn 6, where if you mess up one, you basically have blown the whole section. Same thing can be said for Turns 7 to 11 at Mid Ohio.
![]() Turn 1 is at the end of the main straight. On the track map it looks like a kink that could be taken with little or no brakes. In reality, when you are on the track it looks like it is almost a 90* uphill turn similar to the uphill at Lime Rock. While it is a deceivingly fast corner, you must do some heavy braking for it. Once off the brakes and turned in, get back on the gas early as you go up the hill. The key to this corner is to make sure you get close or even on the apex curbing and be looking at the track out curbing. Because the corner is blind, you must look at the white track out curbing as your cue to where the track goes. This will allow you to take it at speed and exit properly. Many people where staying inside or in the middle and not using the full track here. This cost them a ton of speed. Just as with the top of the uphill at Lime Rock, you must straighten the wheel a little bit as you crest the hill and the car gets a little light. Turn 2 to Turn 5 are all linked and lead to the fast increasing radius sweeper that leads to the short straight near the bridge. If you mess up any of these turns it will cost you significant speed on that sweeper/straight. The key turn is the left hand T4. You must realize that Turns 2 and 3 set you up for Turn 4 and take them accordingly. Note: many people where having trouble with Turn 3 and there were many spins and off tracks here. I just brush the brakes for T2 to get the car to turn in. You must early apex T2 and track all the way out to the edge of the track early. In the background there are several tall trees. Most of them are light in color, however there is a very dark one that stands out. Use this dark tree as your reference point for your track out point and aim for it. You should be making 1 continuous arc through Turns 2 and 3, almost like a double apex. You will probably need to brake for T3 and trail braking helps rotate the car here. You must late apex Turn 3 and hug the right hand side to set you up for the left hand Turn 4 which is the most important turn of this section. As you unwind the steering wheel after Turn 3, you should continue turning the wheel to the left for Turn 4. This should be one continuous smooth motion. You do not want to unwind the wheel, go straight for a little bit, then turn left. Again, the transition from 3 to 4 should be one continuous smooth motion. You do not need the brakes for turn 4; just modulate/feather the throttle to help rotate/position the car. As you make the left hander, you will see some white curbing on the far left side of the track at the start of Turn 5 (uphill right hander). As you track out to the right after turn 4, do not force the car back to the left hand side to set up for the right hand Turn 5. Instead gently aim for just in front of white curbing on the left side so that you will start to be turning right and your car will become parallel with the white curbing just as you pass it. You should brake a little early but lightly while turning right just a little. This will rotate the car towards the apex at the top of the hill. Feather/modulate the gas to settle the car after turn in and gently accelerate up the hill. Make sure you get in close to the white apex curbing at the top of the hill. The car will get light as you crest the hill. Going over this turn is like a right hand version of Madness at Mid Ohio. As you crest the hill and the car regains traction, feed the gas in and this will naturally push you out to white curbing on the left hand side which is the track out point. You can get some passing done here if you stay inside as the other person goes wide after cresting the hill. As you track out to the white curbing, continue on that arc making only small gentle corrections with the steering wheel. You are trying to make one continuous smooth turn through here. This will bring you back inside to the white curbing on the right side of the track. Continue to follow the right hand side of the track all the way to the braking point for the 90* left hand Turn 6. Turn 6 actually has a lot more grip and can be taken a lot faster than it first looks. A lot of people where over slowing here. Take a classic line through here making sure you hit the apex and track out points (white curbing on right side of track). You want to gently unwind the wheel as you accelerate out of Turn 6 so that you are in the middle of the track as you crest the hill. Because the hill is blind, the tendency is to move to the far left since it is a left hand turn. Avoid this tendency and stay in the middle of the track as you crest the hill. This will set you up to be able to brake later going into the bowl/lightbulb turn. There is a little more camber at the bottom of the bowl then at the top. This allows you to carry more speed if you are lower, but you can get a much better run out of the bowl if you are higher before you start to come down towards the apex. I still have not figured out the fastest way around it yet. I was braking as late as possible, carrying as much speed as possible and then stay about ¾ of the way up the bowl maintaining my speed before coming down. The beginning of the bowl seems to go uphill. About halfway around it starts to go downhill. As the track starts to go downhill, use this as your cue to start to get in towards the apex. As you start to come down towards the apex you should be feeding in the throttle and accelerating to get a good run out of the bowl. You should be close to full throttle exiting the bowl, modulating it to make sure you track out at the right point. After you track out you want to slowly unwind the wheel so that you are in the middle of the track when you crest the top of small hill on the main straight. It looks like the track goes straight at the top of the hill, but it still continues to the right. This was causing many people to track out early, get to the top of the small hill, realize the track is still going right and have to yank the wheel to the right to stay on track. The correct line puts you in the middle of the track at the crest of that hill, and finish tracking out to the left significantly after the crest of the hill. By slowly unwinding the wheel after tracking out of the light bulb turn, you will make ONE continuous gentle arc all the way past the top of the hill on the main straight, and finally tracking out to the left side after the top of the hill. The main straight leads back to Turn 1. General notes: Because there are so many blind turns on Lightning, start off slowing more for the turns than you think you should until you get to know your way around the track. Many people either took the turns too fast or got back on the gas too hard too soon and ran out of room really quick on track out. Fortunately, there is a lot of run off room in these places. Also because there are so many increasing radius turns that lead to straights, “Slow In, Fast Out” really is the fastest way around the track anyways. If you keep this in mind, you should have no trouble learning the course and picking up speed as you get to know it. Lap times where around 1:15-1:35 for the group. Video with Data Overlay of a few 1:17-1:19 laps. Data includes speed (MPH), track map and track position, g-forces (2G graph), throttle position, braking, RPM's and lap times. -Scott
HPDE Track Event Schedule
Track Videos 1991 BMW 318is 24 Hours of LeMons car 1984 Porsche 911 Track Car 2001 BMW M Roadster - 1/4 Mile: 13.5@104mph 1998 BMW M Roadster - 1/4 Mile: 13.3@102mph Z3 Stereo System Installation for Dummies Guide to Upgrading Brakes
Wow! Nice writeup. I wish I could have read this mid-day on Friday, I bet this would have gotten me out of the mid-high 1:2x's. Were you there on Friday? What run group were you in?
btw - I live a few towns over from you. Small world... |
There is so much speed to be had in turns 2-5, and 8 as well. According to my video, I spent the first session at 60mph in 3rd gear in turn 8. By the end of the day, I was doing 85 in 4th. Turns 2-5 are so important, your rhythm has to be perfect. I never got turn 5 perfect, and I was constantly lighting up the tires. I watched my speedo jump from 60 to 80 one time over that hill... yikes! I never got 6 right either, I never tracked out far enough and always stayed waaay too far left after it while cresting the hill. That's a hard habit to break.
My timed runs (1.21:1): www.apexeta.com/vid/nj08tt.mov
![]() -Scott
I saw you in the blue group, you guys are crazy. Nice time! My buddy in the white M3 did a 1:22 - I was a little shy of that. No timer or camera... |
Excellent thread with great info. I was there for the TT on Saturday. I couldn't stay until they announced the results though since I had to head back early to NYC.
I had an excellent time. It was my first time running with EMRA and it was a great experience. The advice about taking it slow and getting a feel for the track is spot on. Its pretty easy to get the hang of, but requires seat time like any track. It seems that the TT results have not yet been posted on the EMRA site...is there another way/place to access this information? Or, do you guys know how long it usually takes for the results to be posted? Thanks. I was in the black E46 M3 with orange wheels in the ST1 class. My traqmate says my fastest lap was a 1.16.2. Id like to see if it was accurate compared to what the timers recorded and how I fared against the competition. If all goes well I'll have some video posted soon also.
![]() Last edited by E28Fiend; 07-14-2008 at 06:44 PM.. |
-Scott
It can sometimes take EMRA up to a few weeks to update the site. You were definitely one of the fastest. Your car sounded like an airplane going down the straightaway... I wasn't sure if you were going to take off or what.
Hey Scott, it's Jeff with the Avus Blue E36 M3. Nice write up! That really will help everyone prep for their first day at the Lightning Circuit.
It was good to see you again and glad to see you are on BF.c.
sounds like a fun track, anyone know how the race went? I would to have loved to make it out to race there but work and moving got in the way big time
Cars sold now
#150 WC emra andrew vovou
![]() I found that as I got more and more comfortable with the track I could carry good speed around the last sweeping righthander, get on the gas early and fly down the straight. I saw 140MPH indicated a few times , but the E46 speedo is definitely off above 100 so I gotta take a look at what the traqmate says. I thought the track was awesome, even though it was a bit dusty, and there is basically no shade anywhere.
Eric
![]() '97 Cosmos Sedan Some stuff, mostly AST 4100's. |
Here is video with Data Overlay of a few 1:17-1:19 laps.
sweet... looks like fun. tks for the video and data scott.
'90 E30 M3
'91 325i Sport '87 325ic '03 540i/6 M-Sport '05 X5 3.0 Sport BMWCCA #360858 SCCA# 374179 NASA # 128290 My Track Schedule Lemons South Fall 2009 Blog |
Heres a link to some video I have of my first session on the new track.
http://www.vimeo.com/1342799
| Bookmarks |
| Thread Tools | |
