So the cars have a second washer fluid res. for "intensive" washer fluid. any problem with just putting normal blue stuff in both? or.. does anyone have a better preference for good fluid?
Steve
'86 635csi black
'16 535d Xdrive Jatoba Brown
'62 AustinHealy Replica (w/350SBC)
'71 Jaguar XKE 2+2
The difference in the two systems is the main fluid is for washing your windshield when it is mildly dirty, like every other car. When you activate the intensive, the fluid from the other system is dispensed onto the windshield and the washer jets are heated. The main use of the intensive system is for freezing conditions with ice or sleet buildup on the windshield. IF you live in cold, freezing conditions, it would be best to use the less diluted, "intensive" type antifreeze/fluid. If you don't use your car in that situation, no reason to even fill that tank. Heck, you could even do what we did to our Volkswagen in high school. Fill that tank with wiskey and run the tube into the glove box. When you need a shot, PRESTO!, bartender at the push of the button! Not that I would ever do that!
I used to think it would be handy to fill the intensive tank with de-ice fluid, but the system really doesn't work that way.
First, the jets are heated any time the key is on, there is not even a temperature switch like the heated door lock.
When you hit the Intensive washer button, fluid from the intensive tank is pumped for about 2 seconds and then the relay switches to the regular tank and starts a normal wash cycle, pumping from the normal tank. (See note under intensive wash switch in diagram below)
There are several cleaners made for cutting that greasy road grim, but they usually come in concentrated form so I'm not exactly sure what would be the best way to mix it and use it. Here are a couple of examples:
Big American cars- fill the trunk with ice, push out the drain well plugs, holds 2 kegs side by side, cut hole in the rear seat "firewall" for the tap line.
If you lived where Coors was unavailable, you could boot leg 2 cases in each of the quarter panels between the back of front wheel well and just open the front doors and reach forward. Nice drive back from TN if you loaded with ice.They wouldn't get foamy before you sold them at a kegger at $1 each.
Now whiskey through the washer pump, that is as good as NOS at a party.
Give me a diablo sandwich, a Dr. Pepper, and make it quick, I'm in a god-damn hurry.
so if i use some cheap whiskey in the intensive cleaner will it hurt the paint?
Plus, how long can i suck on the washer nozzles before the regular cleaner kicks in?
excuse me.. how long do i get my dumb friend to suck on the washer nozzles?
Steve
'86 635csi black
'71 Jaguar XKE 2+2
^ what about the adults
how do you activate the intesive wash thing?
Pull the washer/wiper stalk toward you to run the regular washer cycle and push the end of the stalk in towards the steering column to activate the intensive washer cycle.
There is a large arrow with an "S" in it on top of the stalk pointing to the steering column to indicate the proper direction. I don't know what the "S" stands for, but I think of it as standing for "Special".
"intenSive" lol
I never noticed that before. both mine have it.
So that means i can control how much rum and how much lemonade i use!!
Steve
'86 635csi black
'71 Jaguar XKE 2+2
Now if only I could figure out an ice dispenser!
Lol
the 87 has the cooler in the back maybe we can crank it up to make ice! I've always wondered about that. The BMW engineers didn't think we should be distracted with cupholders in the cars.. but they put a cooler in back designed to keep a 6pack cold. I guess they think you should stop periodically and toss back a cold one before continuing on!
Steve
'86 635csi black
'71 Jaguar XKE 2+2
so....i guess I am looking for clarification...my washer fluid light is on. i want to top off both tanks. for the non-concentrated, I can use any typical ww fluid? the car will see cold, but no snow.
For the concentrated, any ideas besides the one chris put up? I have never seen those products, though I confess I've never really looked for them. is there a bmw product I can get at the dealer?
Just saw these at the store the other day, haven't tried them yet. Thought I would use the 2-in-1 in the main, and the de-icer in the intensive washer, they are both good to -25:
http://www.rainx.com/Products/Windsh...g_Remover.aspx
Just bought a bottle of intensive wash cleaner from the dealer. BMW part number 83 12 0 410 745. Directions on the bottle say to use it at full strength. I don't think the intensive wash tank has the fluid lever sensor that triggers the light on the check panel, but I may be wrong on that.
Mine: 1988 635CSi Euro in Diamantschwarz Metallic, 1989 ALPINA B10 3.5 in Alpineweiss II, 1981 528i in Kastanienrot-Metallic, 1958 Isetta 300 currently in rust repair
In the family: 1958 Isetta 300 in Federweiss/Pastellblau, 1987 635CSi, 2000 M5
My YouTube Channel
i have some of the rain-x all season sitting around. i used that in my honda. works quite well. for how much i use it, i might just buy the dealer stuff. trevor, how much was the dealer solution? and how much did you get?
I paid $7.25 for a 0.5 liter bottle, but this is Canada. Expect to pay somewhere around the $5.00 mark in the US.
My YouTube Channel
I came across this thread a while back and never wanted to bump it due to the date but since someone already bumped the thread......
How does one activate the "intensive wash?" I don't think mine was never functional and it's about to get chilly in a month or two so I thought I'd get ready. Doubt it'd get below zero here but I've definitely had to deal with ice on the windshield.
I don't have my manual handy right now.
I'm sure that I remember that the intensive fluid I bought from BMW
30 years ago was for splattered bugs on the windshield.
Had nothing to do with winter. The heat was to prevent ice clogging the nozzles.
I think the heat for the mirrors, door locks and nozzles turned on when the
freeze warning tone sounded when the temp reached 36 degrees.
Activate it by pulling the stalk forward (as you would to activate the normal washer ) and depress the button on the end of the stalk towards the wheel at the same time. As Chris said you'll get two seconds of mix into your normal de icer fluid from the intensive wash tank.
Bob is right ; the intensive wash is all about washing grime off and nothing to do with de icing. The door lock heater duration and side view mirrors heat activation are ambient temp driven albeit with no particular connection to the freeze warning chime. However the washer jet nozzles heat up when the car is turned on regardless of ambient temp.
