| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | |
| TireRack Garage | Homepage | Supporting Vendors | Articles | Online Store | Photo Gallery | Forum Rules | Advertising |
| Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water. |
Thread Tools |
#1176
Questions for the patient coupe monster builder.....
Im building an m30 turbo engine for my e24. 5 years in the works forged and custom internals built to handle big torque. My engine builder has an e23 745 turbo customer he built an engine for in the 80's that has 600 k miles on it !!!! I say build it to handle the horses and torque and in the long run you will spend much less. A smart man learns from his mistakes, a wise man learns from the mistakes of others....... Beautiful car and the envy of many including my self (atleast in this thread). |
#1177
Everyone knows that limits have to be pushed in order to make records on S52 stock motors, but nothing was pushed, it just failed. What has George made? 752 rwhp or something? This car dyno'd like 300 rwhp less than that. We can blame it on nitrous use in past history or whatever we want, but the attitude in this effort was greatly dampened when the thing fell apart. That's how humility works - getting ahead of yourself and having something catastrophic happen will surely put you in line. Next time, a wise person will not jump so far ahead. I've learned to never make claims that you A) haven't already made happen or B) are willing and able to make happen regardless of possible damage.
B) there are two options - 1) go bigger and better with forged internals/valvetrain and a stouter block, or 2) replace damaged block/parts with an OEM S52 block/parts. to be that committed to breaking the stock S52 record requires alot of money - an amount far greater than that alotted for this project. it also involves a fair amount of luck - unless you know every little thing a motor has been through, you just don't know for sure how much stress it will tolerate while going for the record. so yeah, i guess it would have been fun for Brian to go for the record, but the circumstances have taken him in another direction. you talk about it as though this project has failed, when in actuality it just changed direction. there's nothing "fail" about a built M52 capable of 700whp, even if its been done quite a few times before.
I guess the point is, there was this big game talk about hitting the S52 record and it failed on a base tune at 400 some odd hp. Its very humbling and eye opening i think. I mean if the thing failed on a soft base map then there's no way it was going to be hitting 750+ rwhp. The scope didn't really change, it wasn't realistic from the get go... so in that regard I guess it changed.
It's cheaper to take a stock S52 to a high power level a few times to break a record than it is to build a forged built motor with head work. So I guess what it boils down to is that it easy to bolt a 6262 to an S52 and said you're going to do _____, and when _____ didn't happen its, "well the scope changed anyway so whatever". People don't usually call our "world records" and then let them slip away, unless of course they weren't really in it to win it anyway. Obviously it makes more sense to build a motor to run 750+ rwhp, but we all know that works. Just saying. If it broke at 720 rwhp that'd be a noble effort.
at any rate, aside from the things i disagreed with, you essentially reiterated what i just said...so thanks, i guess? obviously Brian wants lots of reliable power, and that matters to him more now than the stock S52 record. a.k.a. i don't think he gives a sh_t if the effort being put into this build is perceived as less than noble by whoever...especially since its going to end up being exactly what he wants anyways... there's no pleasing everyone...the goal may be the same (700+whp), but the scope and direction of the project most definitely changed whether you can see it or not. if it didn't change, you'd see Brian still working with a stock S52 block and internals.
Damn man. Jon is right in saying its cheaper to take a stock motor to high power a few times. On those dyno pulls, Brian should have cranked it up to 25-30psi and broken the record. Would have achieved the same thing, a broken motor, and a broken record.
I think Brian stated he wants more than 800whp now, did he not? He said he needs a bigger turbo for his future goals... Implying needing over 800whp.
![]() 2008-2009 Turbo/Motor Build Thread - 382whp/402wtq & 12.8@116.6 | M52 Engine Parts For Sale | S52 Engine Parts For Sale
#1183
as far as Brian wanting 800+whp, i think he'll see how far he can push the 6262 on race gas and high boost with the build motor first. i mean he should be able to achieve ~750whp with enough boost on the 6262. besides, we don't want to take everything Brian says verbatim or it might just amount to "big talk" and "false claims" should he change his mind and go a different direction in the near future lol.
#1184
Brian most love having an official spokesman for his build thread. Saves him a lot of time.
You seem to dismiss the "blown" engine. A blown engine is something that happens when someone intentionally destroys it, or makes more power than the components were designed for (headgasket due to pressure or heat, rods bending, pintons cracking, etc). I am just trying to keep things grounded in saying that this thing "blew" on a base tune. You still don't know that the manifold constructed, intake or exhaust, can even flow enough air to make that power (i'll reserve my judgement of the intake manifold). The turbine is being fed cylinders through 3 runners at 3 corners of the T4 flange... I mean there's a LOT in question other than the motor staying together. Just trying to be realistic.
I know for a fact that the intake will flow enough volume for the specified HP goal. Keep in mind that we are all on this forum for the same reason.... To learn and have fun while doing it. If you are on here for any other reason than that you should leave. We are wanting to push the limits of physics. Step back 15 years and look at the "advanced components" compared to what is being done today. The quest for more horsepower has taken us a long way in a short time. That is something that no one can deny.
The valve deciding to fall into the cylinder has very little to do with the base tune. I was prepared to perform a failure analysis but was told by brian and shawn to let it go. we are at this point focussing all of our efforts on the future by puting together a motor that will handle the power. This is not a heavily funded project. Had Brian not blown through his lottery winning in Vegas on that one girl I'm sure he would have been more than happy to buy 2 or 3 s52 blocks and continued to experiment until we achieved the goal. |
#1188
My name is Cameron Vongschlong...and I am a surfaholic. |
#1190
#1191
a man's wallet hand do. She may not have been hot. ![]() |
#1192
Did this girl involve like a few sandwich baggies full of coke?
Who blows $7k on a girl in Vegas who's not seriously depressed? Weird.
Was he drunk in the champagne room for 8 hours?Tell me about it... ![]()
#1195
2-3 s52 bottoms sounds like 5 to 7k to me.
Eh that's pretty steep. Depending on the market at the time of purchase, a stock S52 goes from $2000-3000. So $7k for 3 S52's isn't that low...
#1197
"Who's afraid of the big bad M3?"
-1997 Estoril M3 -TURBO- GT35R_8.5:1 VAC forged pistons_Eagle rods_All ARP 2000 hardware_ Cutring HG_Fully balanced & blueprinted 3.3L S52_Tec3_60#injectors. Goals with this setup: high 6 second 60-130; 135 mph in the 1/4 -1998 M-Roadster (wifes car) |
#1199
Carl, PM me about the crank alone (or IM)
Lessons learned and move forward.
Built again with the knowledge you have learned....good luck
Nelson Mandela borrowed this from Marianne Wilson in his 1994 inaugural speech - "Our deepest fear is not that we are inadequate. Our deepest fear is that we are powerful beyond measure. It is our light, not our darkness that most frightens us. We ask ourselves, "Who am i to be brilliant, gorgeous, talented, fabulous?" Actually, who are you not to be? You are a child of God. Your playing small doesn't serve the world. There's nothing enlightened about shrinking so that other people won't feel insecure around you. You were born to make manifest the glory of God that is within you. It's not just in some of us, it's in everyone. And as we let our own light shine we unconsciously give other people permission to do the same. As we're liberated from our own fear, our presence automatically liberates others.
| Bookmarks |
| Thread Tools | |
