Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - General BMW > Diagnostic Software
Diagnostic Software Do you need help with diagnostic software or have installation questions? DIS, INPA, EDIABAS, IBUS, CANBUS, CARSOFT
Old 10-25-2009, 01:59 PM
ian s ian s is offline
Cars: E36 M3 Evo
That's very helpful, thank-you. I set up a continuous ping from the host and the LED's lit up.
Time to take a look at the host side of things...
Ian
Old 10-25-2009, 02:27 PM
aise aise is offline
Cars: BMW 530i 2001
iīve got it. i removed network adapters .31 and .32 from unix and both leds are on before that the ifhservice took .32 but i figured it should take .30 wich is DISīs IP so i removed those 2 devices
Old 10-27-2009, 07:47 AM
susha1 susha1 is offline
Cars: chevvy
what do you mean ......i mean i am not very much clear with it.....you want a cheap one??
Susha BMW Performance Chip
Old 10-27-2009, 10:48 PM
capstorm capstorm is offline
Cars: BMW 316i E36
Hello guys,
I'm trying to run EDIABAS / INPA on WinXP laptop, and to connect to Diagnostic Head over cross-over cable and TCP/IP.
I'm not sure what IP to put for RemoteHost in ediabas.ini. IP of PC running INPA or Diagnostic Head IP?
I tired with both but same result, always timeout error. I also cannot start ifhserv32.exe. Double-click on it does nothing. I cannot see that process in Task Manager. So I think there lies a problem but I don't know hoe to solve it
Can anybody help?
Thanks in advance!
Old 10-28-2009, 06:21 AM
Rallyfinnen Rallyfinnen is offline
Cars: 740, 850, M3
So you have a real yellowhead connected via LAN, not a OBD cable?
I think you don't need ifhserv with the yellowhead, you only need to get the virtual DIS machine to be able to connect to your network card in the host (XP?)
Try to use vmnet0 in the virtual machine and make sure vmnet0 is connected to you LAN card. Hope that helped.
Old 10-28-2009, 08:41 AM
Cars: BMW 316i E36
Yes, that is correct. I have real yellowhead . Is it possible to use it only with INPA without DIS?
IP of EDIABAS station is 192.168.68.50 and yellowhead has IP 192.168.68.22. What IP address should I put in ediabas.ini?
Just one update to my previous post. I also have OPPS head. My intention is to use only INPA and heads, connecting to them remotely over TCP/IP.
In ediabas.ini under "Interface" I tried "REMOTE" and "REMOTE:Remote.ini" parmeters but it doesn't help
When using REMOTE I'm getting error:
EDIABAS Fehler 159, NET-0009: TIMEOUT
When using REMOTE:remote.ini I'm getting error:
Fehler 45, IFH-0035: CONFIGURATION ERROR
Durin INPA installation it is possible to install EDIC drivers for heads. Does anybody knows where can I download drivers for OPPS and yellowhead?
Also where is location of drivers files after installation?
Old 10-29-2009, 06:22 AM
Cars: 740, 850, M3
It should be possible, but since I have not tried it myself, maybe somebody else has some info?
Old 11-02-2009, 04:26 PM
steeee steeee is offline
Cars: BMW 325 Coupe
Does anyone know how ifhserv32.exe works, what are the parameter of the program and what it does. I think I might be close but I just cant ifhserv32.exe to display an ip address on the taskbar. What can I do to get it working properly?
And secondly to any one who has DIS/GT1 V44 working, does V44 or V39 need the Diaghead program to run or does it work without it.
Old 11-02-2009, 04:35 PM
zigzagsky zigzagsky is offline
Cars: 1999 BMW Z3M
There are a couple of things to see if IHFServ is running properly and display an IP address.
Firstly, drop down to the command line mode in GT1 and run the APITest. This should connect to the IHFServ app running under Windows and it should then show an IP address.
The second thing to try is to actually connect to the car. This should also then get the GT1 to connect to the diaghead via IHFServ and the Ip should get displayed.
As for the Diaghead emulator, you need it with both V39 and V44 in order for the GT1 to 'see' the OBD adapter running under Windows.
Old 11-03-2009, 07:32 AM
Cars: BMW 316i E36
Regarding my issues with LAN connection between OPPS head and PC, I finally found source of problem.
ediabas.ini should contain:
Interface = REMOTE
RemoteHost = 192.168.68.XX
Port = 6801
For OPPS to work wtih INPA station, OPPS head should first be unregistred form current station (you can do that through web interface connecting over LAN to head IP). After that INPA has found head and registered. Now everything works like charm now.
Thanks for help!
Old 11-03-2009, 02:40 PM
vantaam5 vantaam5 is offline
Cars: 2003 M5
Please,guys I need help!
When I try to run the API test I only get the error message:
"fault in execution of the function chosen.
Fault number:-2"
Have the DIS reconizing the car with the INPA interface and the diaghead emulator running
Old 11-03-2009, 03:16 PM
Beemer187's Avatar
Beemer187 Beemer187 is offline
Cars: BMW 330CI DropTop
Fault number:-2"
Make sure ifhserv32.exe is running too.
Old 11-03-2009, 03:22 PM
Cars: 2003 M5
It is running!
And it detects the car,reads the modules and so on...
Old 11-04-2009, 04:57 PM
Cars: BMW 325 Coupe
Finally done it, it works, DIS, thanks to zigzagsky for that last crucial part of information that I needed. Not how do I get automatic detection working.
Old 11-06-2009, 11:04 PM
shzeps shzeps is offline
Cars: e36
I am so close I can feel it.
Hi Group, I need to ask the experts about my DIS install. I have installed V44 on VMware and set up ip configs so that when running diaghead emulator it shows connected both in DIS and on the emulator. I have installed INPA and using a VAG-COM hex can serial interface (with pins 7 + 8 bridged), on a physical port (com1) can communicate with various modules on an e46 thru obdII. INPA does not recognize the ignition being on but still works.
When I run DIS and go into diagnosis it does not auto identify, nor does it connect to any control units manually. The error shown is a communication problem to the diagnostic head code 200.159. Yes I do have ediabas server, ifhserv32, and diaghead all running.
Is there a way to test the connection between my interface and diaghead emulator? Can my interface work only with INPA and not DIS?
I would appreciate any suggestions. Thanks
Old 11-07-2009, 07:26 AM
Cars: 1999 BMW Z3M
What are you using as your interface? If it's based on the FTDI USB chip i.e. a VAG one then you need to get inside the interface and solder pins 17 & 18 of the actual FTDI chip to ground. Note that this is NOT for the faint hearted as the pins are tiny.
Old 11-07-2009, 12:48 PM
Cars: e36
The cable is a VAG-COM HEX-CAN serial RS232 (not USB) original cable.
Old 11-08-2009, 09:59 AM
Cars: BMW 325 Coupe
i am using a rs232 port on my laptop, so i have a rs232 cable that connects to the my bmw. from ebay like this one Ebay Uk Item number:280420080631
Old 11-09-2009, 11:18 PM
Cars: e36
Thanks for the advice. I am not going to fight the system. I am going to order up some cables first like the ones you referenced and see where that takes me.
Old 11-19-2009, 08:50 AM
kennycoder kennycoder is online now
Cars: 1998 BMW 520i
Send a message via ICQ to kennycoder Send a message via MSN to kennycoder Send a message via Skype™ to kennycoder
Hey guys.. finally I've managed to put DIS to communicate with my computer via VMware... it pings and so on. The problem is that EVERY time i rebuild the kernel after using scoadmin, DIS won't boot.. The only thing i see is a black screen with a cursor. What am I doing wrong?
Thanks in advance.
Old 11-19-2009, 11:05 AM
randomy's Avatar
randomy randomy is online now
Cars: 96 328i
does it accept commands?
try running: init 5
Offering: E36 Parts for sale
NWS for NWS'ing: http://dvsteens.com (NWS!)
Polarized Sunglasses for getting laid in: http://www.habervision.net
Old 11-20-2009, 04:54 AM
Cars: BMW 530i 2001
Thanks in advance.
i had the same issue at the beginning. this is what i did, i configured all parameters nessesary (etc/hosts, scoadmin etc.) and then changed to fister translator. every time i changed to fister before other parameters were configured it wouldnīt boot to DIS.
DISv55 and SSSv32 are both running perfect no need for newer software.
Old 11-20-2009, 05:35 AM
ccfj1 ccfj1 is offline
Cars: 330ci Sport
How do you get to the GT1 console, I run it on a laptop and can use the mouse and only "crtl+alt" seems to work.
Old 11-20-2009, 01:05 PM
Cars: 1998 BMW 520i
Hello. Thanks for help
Finally I've got everything running smoothly :p Now I have two virtual machines.. one with DIS V57 just for diagnostics (dunno why SSSv32 won't install on it) and another with DIS V44 for possible future coding.
I've ordered EDIABAS / INPA interface from ebay (china stuff..). With this interface and IFHSrv32 / BMW Diagnostic head emulator I will be able to do everything, correct? I don't need the "yellow box" that is for sale everywhere, right?
Cheers
@ccfj1: ctrl+alt+f1 or f2 or f3.. (F2 is for X server where DIS is running)
In a virtual machine on VMware it's ctrl+alt+space+f1..2..3.
Old Yesterday, 02:29 PM
darkstarmedia darkstarmedia is offline
Cars: 01 750iL
So I have everything working except automatic detection... I am using the carsoft west cables... is there a trick to this? I am not using any usb adapters...
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
