Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > M series > 1992 - 1999 M3 (E36)
1992 - 1999 M3 (E36) (1992 - 1999) BMW's second generation M3, and the first M3 to feature BMW's classic inline six motor. Featuring 240hp (european models had a 286hp and 321hp), a slick shifting gear box, and near perfect weight balance, the E36 M3 was named Car & Driver's "Best Handling Car At Any Price."
Old 03-11-2001, 12:59 AM
02Super 02Super is offline
hey bob,
how did you get the wires for the easternmotorwerks gauges into the engine compartment without removing the glove box?
thanks.
Old 03-11-2001, 03:55 AM
Bob ///M3's Avatar
Bob ///M3 Bob ///M3 is offline
Retired Original
BIMMERFORUMS
Administrator
Cars: 1999 M3 & 2003 330i Also 2004 Camry XLE V6
Send a message via AIM to Bob ///M3
Smile
You need to push a rather stiff piece of wire like 12 or 10 gauge solid copper wire or a coathanger through the grommet on the firewall. The grommet you need is down below another grommet. The one you want has a red wire already going through it that you should be able to see.
After penetrating this grommet the wire or coathanger will come into the cabin of the car underneath the glovebox. You'll need to remove the underpanel and pull back the top part of the carpeting to find it. Then you need to either put a small hook at the end of the wire or coathanger you just used and attach the ends of the wires you will be "fishing" back through to the engine compartment. Usually taping the wires you'll be pulling back through to the coathanger is strong enough that they won't seperate as you pull them back through.
That's it!
Good luck with the install...
Bob <font color="1E90FF">/</font><font color="7D26CD">/</font><font color="red">/</font><b><font color="gray">M3</font></b>
Old 03-12-2001, 12:50 AM
NormK NormK is offline
Question
Hi Bob,
About the Eastern guage package:
1] Can you specify guage (e.g. no grn/red color on voltmeter but plain like oil press/temp guages)?
2] Do you think an Amp guage is more informative.
3] BMP catalog says option of selecting wht or org color backlight. Do you need to specify for Eastern kit?
4] Do you need to specify which JTD dist block (i.e. I read somewhere there are different size threads on some)? If yes, which do you recommend.
Sorry for all the Q's. This is my first post so I hope this works.
Rgds,
Norm
Old 03-12-2001, 11:28 AM
the gauges just come in the plain color, no red or green on the voltmeter, just like the oil temp and press gauges...
you dont need to specifiy for eatern kit which backlight, it just comes with one light a belive, which is the original,
you dont need to specifiy which JTD block either, they will determine it for you based on your car most likely,
lastly, i dont know much about the amp gauges, but the voltmeter is pretty important if your running some high wattage systems, such as a sound system...or if you just want to know if your battery is doing okay...
hope this helps..
Old 03-12-2001, 11:50 AM
Kevlar's Avatar
Kevlar Kevlar is offline
Needs No Explanation
Administrator
Cars: 2008 M3 Coupe
Send a message via ICQ to Kevlar Send a message via AIM to Kevlar
I like my voltmeter... when I have the stereo running at 1/2 to full power, i can see the voltmeter needle drop whenever the amp in the trunk needs power. I kinda knew something was up from before cause my dash lights would dim as well whenever i had the stereo running at full tilt.
Let me get this straight... You are swapping out parts designed by hundreds of engineers that get paid thousands of dollars for something you bought at Pep Boys because your buddy who doesn't have a job told you it was 'better'?!?
Old 03-12-2001, 02:15 PM
Bob ///M3's Avatar
Retired Original
BIMMERFORUMS
Administrator
You'll want to make sure you order the oil pressure gauge with the lower scale. The maximum oil pressure for a M3 is 58 psi. One gauge offered has a maximun reading of 80 or 90 psi and the other reads up to like 150 psi. Get the lower scale.
Like others have already told you, everything else is standard except for whether you want the full kit that includes the JTD oil distribution block or not. Go with the block.
Good luck!
Old 03-12-2001, 02:40 PM
Dan Wang's Avatar
Dan Wang Dan Wang is offline
Send a message via AIM to Dan Wang
I personally used a coat hanger to fish the wire through the firewall.
Its the most complicated part of the whole installation
