Go Back   Bimmerforums - The Ultimate BMW Forum > Bimmerforums - BMW Car/Model Specific > 3 series (E21, E30, E36, E46, E90, E91, E92, E93) > 1983 - 1991 (E30)
1983 - 1991 (E30) (1983 - 1991) Born from the sporty character of the 2002 and the sharp design lines of the E21, the E30 was a blend of the best of BMW's heritage. The second generation 3 Series provided a thrilling driving experience that used the best technology available.
Old 12-13-2006, 09:54 AM
wind wind is offline
Cars: 530 e34, VW Scirocco
Send a message via MSN to wind Send a message via Skype™ to wind
many ppl told me that disc's are better, but in real life..
when I was testing stock discs and stock drums on my vw braking force felt the same. You also have to remeber that if you're rear brakes will be to strong your car will tend to go sideways during braking
on drums handbrake is stronger than on discs - dont ask me why... it just is
ps. nice to see you again m8 pozdro
Old 12-13-2006, 12:32 PM
redhatpat redhatpat is offline
Cars: 90 325i, 68 Barracuda
Send a message via ICQ to redhatpat
A good set of drum brakes can brake just as well as a set of disc brakes on the first go. After several hard brakes, (once they get hot) the drum brakes will be useless while the disc brakes should still be good. If you want to test this out, drive down a winding moutain road and try out your drum brakes when you get near the bottom. Have the number of a tow truck handy!
Old 12-13-2006, 12:54 PM
equate975 equate975 is offline
Minnesotas Most Wanted
Cars: 1988 m3 2.3
Send a message via AIM to equate975
Originally Posted by MrK View Post
I have had my zimmerman cross-drilled rotors (Pagid pads) for about a year now, and they work like a charm. No cracks or warpage anywhere, and even though stopping power is a little low when the rotors are cold, they do a great job once they're warmed up.
I have the same on my m3, they are utter bullshit, I can't wait until summer so I can take this junk off.
X-Drilled are 100% completely worthless, /end
Old 12-13-2006, 01:44 PM
slowman's Avatar
slowman slowman is offline
rebmeM
Cars: '84 325e - '79 Kawi Z1000
Every time I see a thread about upgraded brakes I just shake my head... :
What people don't realize is that if you can lock up your tires with the stock brakes, then you don't need to go to upgraded brakes. The only time you would go upgraded is if you wanted to customize the feel of the brakes to how you like it.
Track use would almost require at least upgraded pads and fluid, even if you can still lock up the tires. Logically, the more stress is induced on the parts, the stronger they will need to be to prevent failure.
I guess this rant is not directed at people who track their cars... more so to people who only drive on the street and some auto-x. If you drive on the street, you will never, never, never need upgraded brake anything. What a waste of money, I'd rather put that into a Schrick cam, chip, and some suspension pieces....
Old 12-13-2006, 02:37 PM
JohnW8 JohnW8 is offline
Cars: 89 325is, 92 Miata, 07 Silverado Classic
Wink
Originally Posted by slowman View Post
... If you drive on the street, you will never, never, never need upgraded brake anything. What a waste of money, I'd rather put that into a Schrick cam, chip, and some suspension pieces....
Then... you would need upgraded brakes.
I agree with you, slotted cross drilled stuff looks good but the performance doesn't justify the price. Good pads with higher boiling point brake fluid and good tires will do as good a job to stop a car than any of the high dollar stuff.
JohnW8
Old 12-13-2006, 09:20 PM
KoRny's Avatar
KoRny KoRny is offline
Cars: 1997 BMW 328i
Send a message via AIM to KoRny
The only reason I'm asking about the E36 M3 5-lug is because I'm planning on doing a conversion to my car to fit wider tires on them. So in order to do this what kind of brakes should I put?
Old 12-13-2006, 09:39 PM
Cars: 1988 m3 2.3
You don't need bigger brakes to run wider wheels...
Old 12-13-2006, 09:47 PM
sheepdog43's Avatar
sheepdog43 sheepdog43 is offline
Cars: 1991 BMW 318is, 1991 Mazda Miata
Originally Posted by gooten1 View Post
To bring back a thread from the dead, this has been helpful. I was thinking of going M3 brakes, till I read this. The brakes are pretty crappy now, spongy and reluctant, but now I'm going to rebuild the stock stuff and see how it runs.Will the stock setup handle a power adder (FI) and track events/mountain runs?
On the mountain, if it involves lots of downhills, I would say upgrade them. I have heard that on mountain races, you should always have upgraded brakes, I do not do them so... I would think if you are only racing up a mountain, you would be fine.
Unless you significantly up the power you should be ok.
Just follow some of the earlier advice, better fluid, stainless lines, better pads.
M42club
Old 12-13-2006, 09:57 PM
wludavid wludavid is offline
Cars: .
Send a message via AIM to wludavid
If you do all the cheap stuff and you still get fade, plumb some cooling lines from the airdam. Works wonders from what I hear from Spec e30 guys.
And of course, try different pads to see what you like best.
And then there's the obligatory, "mod the driver, not the car" argument. Better technique means less braking. Also, better tires mean less braking, 'cause you can take turns at higher speeds.
Old 12-14-2006, 04:44 AM
also - if you have enough space infront of you you can brake with your engine - just keep shifting down and remeber that 1st and 2nd gear are slowing us down veeery fast..
and where was this button for the engine braking.. Im sure I have seen it somewhere...
Old 12-14-2006, 12:04 PM
Reynard38's Avatar
Reynard38 Reynard38 is offline
Cars: '01 330i, '97 911S
Bigger brakes equals more unsprung weight. Also those bigger rotors are rotating mass as well and that extra weight means more HP to accelerate. The idea behind big brakes was to disapate the heat. I would think that with a good cooling duct setup the stock calipers with good rotors,pads,stainless lines and fluid would be up to the task.
The 25mm master cylinder is a matter of personal preference. I have one and I like it. The peddle effort is increased, but the travel is decreased.
Old 12-14-2006, 03:20 PM
X2theZ3's Avatar
X2theZ3 X2theZ3 is offline
///M POWER
Cars: 90 E30 M3 S50
Send a message via AIM to X2theZ3
It sounds like you really know what you're talking about.
Old 12-14-2006, 03:41 PM
Schneller Bayer's Avatar
Schneller Bayer Schneller Bayer is offline
Super Person
Location: Langley/Winnipeg, Garmisch-Partenkirchen, Germany
Cars: LSB S54 m coupe
I don't know if it was mentioned but RPI equipped has an e30 BBK.
It consists of wilwood calipres and 12' rotors, minimum wheel size is 16'.
Most BBK setups are actually lighter than the stock setups. I don't know if this one is, but I know the calipres are lighter than stock.
www.rpiequipped.com
- Armin
Originally Posted by Mitch View Post
God drives a Ferrari 250 GTO so he can keep miles off of his e30 M3.
Old 12-14-2006, 07:20 PM
Reynard38's Avatar
www.rpiequipped.com
The Wildwood calipers are most likely aluminum They would be lighter, though I don't know if they would make up for a 12" rotor.
