SOLD AS OF 3/24/12
1995 M3 Coupe
Cosmoschwartz Metallic (Grayish-Black)
Black Interior
Mileage: 62,xxx miles
5 Speed Manual Transmission
VIN: WBSBF9325SEH05225
All four tires, all brake pads and rotors, valve cover gasket, spark plugs and boots have all been replaced within the past 500 miles.
ENGINE/TRANS:
The drivetrain is in great running order and has no fluid leaks or issues. The oil and filter was changed every 4-5k when the car was driven daily and annually since it’s been a second car. I always used Amsoil synthetic or BMW's Castrol Synthetic Oil.
-Radiator and coolant hoses were all addressed by the previous sometime b/t 2001-02, poduction date on OEM radiator is 2001 on parts label
-Carbonio Carbon Fiber Air Intake
-UUC Cat back Exhaust
-Active Autowerks Track Pipe
-Active Autowerks Headers wrapped w/DEI Thermal Exhaust Wrap
-Active Autowerks ECU Software (Had to remove 1/2012 due to issue with AA EPROM, currently running on stock M3 chip)
-Samco Coolant Hoses
-UUC Under drive Pulleys
-Amsoil Oil Filter By-pass Kit with braided stainless lines (approx. 8 qt. total oil capacity, provides the best possible filtration protection against wear and oil degradation as well as lowering oil temps.)
-JT Designs Transmission Mounts
-B&M Short Shifter Assembly
-Apexi Air/Fuel Controller wired into glove box
-Greddy Auto timer installed in overhead light console
CHASSIS/SUSPENSION:
-OEM LTW non-staggered wheels painted black (BMW motorsport logo in center) - could use some refinishing work, LF has a scrape on lip and LR has some marks
-H&R 5mm front wheel spacers with Turner Motorsport front wheel hub extenders
-Turner Motorsport Cross Drilled Brake Rotors Front and Rear (Just installed 7/2011)
-KW Variant 3 Coilovers (fully adjustable ride height, dampening, and rebound compression)
-Active Autowerks Upper Strut Brace
-JT Designs Rear Billet Shock Mounts
-JT Designs Aluminum Under panel
-BMW Motorsports X-Brace (from E36 convertibles and the 1995 LTW models)
-UUC adjustable Front and Rear Sway Bars with VAC Motorsports adjustable end links
-UUC Chromoly Adjustable Rear Camber Correction Arms
INTERIOR/MISC:
-Sparco Corsa Drivers seat with Sparco 5 point harness
-Sparco Torino Passenger Seat
-OEM BMW Motorsport Seatbelt on Pass. side - has BMW Motorsport printed on the belt
-Smoked Tail Lamps
-Autometer Gauges (Exhaust Gas Temp. and Air/Fuel ratio mounted on a-pillar)
-EGT warning light installed in dash to the left of steering wheel.
-Momo Race Steering Wheel
-Autopower Race Roll Bar w/ All Options
-ZKW HID Projector Headlights
-18 button On board computer option fully functional except ambient temp. feature
-Partially removed interior to save weight (no rear side panels, rear sound deadening, or interior trunk carpet/panels)
-Rear seat is currently installed in the car (black leather with tri-color ///M stripes) and the seat belts are there but there are no seat belt buckles installed.
-A/C has been removed to save weight (I recently found a box with various a/c parts that was given to me with the car by the previous owner, will go with the car but can't be sure of condition)
-Windshield washer system not installed but could easily be installed - I have the reservoir, pump, and lines that will go with the car
-Kenwood CD player installed in dash
-Headliner has started to sag since the weather got cold. I was quoted $175 to repair it by a reputable trim shop.
The car is currently located in Pittsburgh, PA but was originally a southern car from VA. I purchased it in January 2006 and drove it as a daily driver for a few years before it became a secondary vehicle. All of the modifications were done on the car with 24k miles on it. At that time the car was a local tuning shops promotional car and was being used for car shows, marketing materials for adverts, etc. I'm a level 1 Service Advisor and Dinan Specialist at a local dealer, and as expected the car has been maintained to the T. It has been well taken care of and has absolutely no mechanical issues. The car is covered with a OEM car cover 75% of the time. The cover was just recently replaced and was only used for a few months now. I can also have any BMW or Dinan accessories installed at heavily discounted prices if desired. Overall the car is in great condition for being 16+ years old. It could easily be converted back to stock, into a weekend warrior HPDE/BMWCCA car, or a full blown racecar.
Asking price is $15,000. If you have any other questions feel free to post or PM me and I will get back to you ASAP. It should go without saying, but if you don’t have anything positive to add to the thread then feel free to either PM/email me or please keep it to yourself. If you're serious, I’ll listen to any reasonable offer. The car is located just outside of Pittsburgh, PA and is about 25 minutes away from the airport.
Here are some older pics of the car from before the smoked tail lamps were installed and the rear wing was removed. It was also before the passenger seat and rear seat was installed in the car. The front plate was removed and a new OEM bumper trim insert was installed. I also installed Matte Black Kidney grills from Turner Motorsport. The hood decal and fog lights have also been removed. I will try to get some more recent pics up asap.
CURRENT WHIPS
2016 f80 M3 ZCP Mineral Gray/Black Full Leather
2015 e84 X1 2.8i xDrive M Sport LeMans Blue/Black, Dinan Stage I
PREVIOUS WHIPS2013 e92 M3 ZCP Alpine White/Black, Dinan Stage I
Beautiful. Too nice to be a track car. Throw the interior back in! Lol
USMC...RCurrent: 1988 M3 Alpine
1995 325i hellrot
2013 Suzuki DRZ400SM
Past:1993 325is 5MT Alpine
1996 328is 5MT Swartz
2007 350z Touring MT
2007 Volvo S40 T5 AWD 6MT
2011 Honda Ruckus
2007 Honda CBR1000RR Repsol
2005 Triumph Speed Triple
2006 Suzuki GSX-R600
2003 Honda CBR 600RR
The performance parts are great. Glad you got rid of the wing. Swap a clean black interior with vaders and it would be perfect for that occasional track day. HahaOriginally Posted by mose121
GLWS
1995 325i hellrot
2011 Honda Ruckus
wow beautiful car. come to a meet sometime. would love to see it
Current pics. How far are you from the south hills area?
Wow beautiful man
Thanks bud. It's really hard to let her go but the time has come.Originally Posted by tonymasone
CURRENT WHIPS
Would you be up to drive a few hours and meet half way toward CT?
1995 325i hellrot
2011 Honda Ruckus
CURRENT WHIPS
I'm looking to buy within a week. And a 7+ hour drive is just too long.Originally Posted by mose121
1995 325i hellrot
2011 Honda Ruckus
Car still up for sale?
Hi everyone. I'm currently on vacation and there is no phone or internet access when we are staying on an isle. I'm not quite sure what the difference between an isle and an island is, but I'm on an isle. Anyways, I only have spotty reception on my phone if we are on the mainland so it's difficult to respond. I'll be back in town Sunday night and will try to respond to everyone by Tuesday evening. I'm also moving next week so as you can imagine my life is pretty hectic right now. Thanks to everyone for being patient.
CURRENT WHIPS
Beautiful car. I too live in the Wexford area. Hopefully I'll see it on the road before it's sold. Good Luck!
-Previous owner's shop Dyno Tuned the engine to maximize reliability and performance
CURRENT WHIPS
I'm sorry for the delay in getting back to everyone. We're finally moved in and are getting settled. Verizon is supposed to be out to hook us up this weekend, but I'm not too optimistic about them keeping their commitment. They already told me that there's a chance they might not make it. Plus from what I've read they are notorious for missing appointments. Once I am back up I'll respond to everyone. Thanks everyone.
CURRENT WHIPS
Gorgeous car. I am looking for a track/street car; something very much like this. Is this the 3.0 engine? any idea on the power numbers from that dyno run?
Thanks.
Unfortunately I was never able to get a copy of the dyno results from the previous owner. All I can tell you is that this is one of the strongest S50 motors I've ever driven, and I've had the chance to drive a ton of e36 m3's in my 10 years in the business. Aside from FI or cars with internal engine mods this one pulls as strong as any S50/S52 out there.Originally Posted by RGTI
CURRENT WHIPS
Saw this driving in Wexford around spring time.
Thanks for the compliment. Where did you see me at?Originally Posted by rmk232
CURRENT WHIPS
Soo clean man. I wish i could have this lol
Free bump for fellow PA'er
2015 M235i 6MT
