Anyone have a working INPA & NCS Expert version with E9x cars?
Is there a link for download anywhere?
+1 want to know how it can be done for e90s
I've kind of gave up on Progman for my 05/2009 e90. It will not read the car info properly and CKM is disabled for some odd reason. I think NCS Expert will definitely work if you have the correct daten files. It's also much more dangerous though.
Get NCS Expert 3.1.0 and the latest daten files. Then load "E89" as the chasis. Not sure what the year limit is, but I think Progman v38 should allow you to work at least until the 2010 models.
Can you tell us where we can find the latest daten files? I want to use NCS-Expert with e87 08/2007 but i have only old daten files. NCS-Epert don't connect.and the latest daten files.
Hi guys,
I have the latest versions of daten files. These are from ISTA 34 which should cover upto 2010. I will upload them once I get home.
I only need E81/E82/E87/E88 and sdt777 need E9x. So it would be enough if you upload E81/E82/E87/E88 and E9x?
Here are the latest datens . Password is "don't make business out of it" [remove the double quotes and the spaces].
If the v34s go to 2010, what do the v38s that I've got go up to? I always assumed v38 was for MY2010
There are no daten for E87?
To work on an E9x Series car you must have the proper daten files for the E89. You must use the E89 chasis ONLY.
I have been able to code cars up to 2011, you just need to do a small modification to your INPA cable.
And also, when the module would not read, I would still get a trace file! But it was a huge 112KB file that seems to have EVERYTHING in it. But maybe that is the ZCS file? Because I changed my CC_GURTWARNING (hoping that will get rid of the chime, but after seeing another post there is/could be a different one for AKUSTIK GURT...), to Nicht_acktiv and when I read the airbag computer it does show that, but this big "generic" trace shows it as Active still.
I think the big file shows the default options. I've also had situations where the huge file didn't match the file I got after reading a module directly
So have you guys been able to find files for the R56? I tried reading mine... and get a CHASSIS ERROR message.
