| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | |
| TireRack Garage | Homepage | Supporting Vendors | Articles | Online Store | Photo Gallery | Forum Rules | Advertising |
| Track, Auto-X & Drag Racing sponsored by Bimmerparts.com Discuss "organized" racing, bmw club racing, car set-ups, driving techniques, track tips, events, driving schools, maintenance and more. www.bimmerparts.com. |
Thread Tools |
Which 6pt harnesses? College student budget
I've been looking from site to site trying to figure out what type of harnesses I should get but I'm not sure what to get. I was leaning towards Schroth Clubmans but I thought they were kind of unconfortable and one of my friends wasn't happy with his. These are going in my 95 M3 that will have a roll bar and Recaro Profi SPG seats. So, I'm looking for what people think are the safest, most comfortable harnesses at around $200? Willing to go a little higher in price if recommended though.
Ah, so what's up with your signature?
cheapest i found it .
http://northstarmotorsports.com/prod...productID/7762 |
Ge-Force harnesses are good value for the money. Discovery Parts shows 6-point camlock for $155
Jim Levie, Huntsville, AL NASA & BMWCCA Certified Instructor |
Your best bet is the $200 FIA rated Racequips. You can get them from Driving Impressions @ www.teamdi.com
E46 Project Blog: www.jaffster.com
Adam, get the Clubmans. They are what I have, and are 199 each.
I think they are offering 10% of next weekend when iRacing is going to be there at their shop. So buy them then? http://www.hmsmotorsport.com/store/s...an/clubman-III
+1 for Clubmans.....Joe and the Boys at HMS will take care of you.....AND....they are in Steeler Colors....so you can strap in and feel like a 6 time Super Bowl Champion.....
![]() .....I'm the Buckshot Jones of Club Racing....... |
G-Force 6-point camlocks are FIA rated for $155/set. They work as great as any other belt.
-Anthony
'06 Z4 3.0si Coupe, Montego Blue '97 Z3 2.8, Atlanta Blue (on loan to Dad) '87 BMW 325is SpecE30 #003 / #007 K-Prepared Instructor for: BMWCCA, PCA, Chin Motorsports, Street Survival AnthonyMagagnoliRacing.com <<>> www.MyTrackSchedule.com <<>> DTR Performance
-Jesse
![]() "Hardly an off, just a magnanimous use of the race track." - David Hobbs |
I like my Schroth Hybrid, and while it does take a little more effort to release the cam lock, overall comfort of the belt is much better for me personally. You have to think about the camlock being operating in the worst case...for example you get in an accident and you break a hand/finger, could you still operate the camlock quickly?
I have the g-force belts and have no problem buckling out of them. Some times the cam lock will stick in the "open" position and you have to flip it back to buckle back in, but I've found I like this camlock over some of the other camlocks I have used.
I do have issues with the adjusters though. I find that I have to re-tighten the shoulder straps several times in a full 30 minute session. So they do tend to slip a little bit when pulled really really tight. I'd also guess that my hip straps are loosening up a little bit as well. They never get loose loose, or slip off my hans with the little winglets, but I make sure to pull the straps tight after my first lap, and then I will check them on long straight aways. Get the eye-bolt end pieces, extra cost, as it is really hard to get the bolt through connectors at the right angle. You can't bend them like some of the schroth bolt through connectors. At least, they haven't been tested after being bent like the schroths. |
$200 for harnesses with a 2010 date (i.e. one more year)?
If you buy an SFI-only belt, be aware of the expiration date (2 years from the punched date of mfgr). FIA belts can be cheaper in the long run (expires end of Dec on the date punched, which will be 5 years from the date of mfgr).
Dan Chadwick
Boston Chapter BMWCCA Board Member & Instructor. Opinions are mine. Near Orbital Space Monkeys 24Hrs of LeMons E28 528e |
-Jesse
You might be reading a bit to much into what I'm describing as there is never any loosening that causes slack in the belts. I just like the belts to be very very tight. 50g sled test data is available. |
Belts shouldn't slip. My Schroth's do not slip at all. Once cinched in, you're not moving until you release...and they've been crash tested.
![]() +1 for the expiring quality belts for DE's over cheaper new belts. The expiration is somewhat arbitrary and not observed in DE's and you get more comfort in a quality belt...and adjusters don't slip... ![]()
Carlos. |
Colors aside....the Schroths dont slip at all....anyone that has seen me knows I am way top heavy and have to strap in until it hurts. I go NOWHERE man.....
I run the G-Force belts and like them, especially for the price... I will say that I too find myself tightening them, BUT... it seems to me, seeing as how I'm every bit of 260lbs, and I'm using them with stock seats... I figured it was kinda normal for a guy as big as I am moving around a bit. To clarify: I find myself cinching them down because I didn't get them tight enough in the first place.
Once I get a race seat in the car, I guess I'll find out for sure. I'd say get the best belts you can afford... if the G-force are it, they are certainly better than some more expensive alternatives (IMHO) like some of the 4-point varieties out there. Also... on the DE thing... PLEASE check with the club. Some DE's do in fact check dates. They may not be as strict as a race sanctioning body, but they may have their own rules (like THSCC's 5-year limitation.)
Stacy (Stack) King
Owner/Manager, Asphalt Ventures, LLC HPDE Chairman - Triangle Z Club / Tarheel Sports Car Club, North Carolina ![]() Last edited by StackTrack; 11-04-2009 at 04:07 PM.. |
I also run the G-force 6pts. I have not had them come loose on track in the 2 years I have owned them.
One thing I don't like, and this could just be because of my setup, is the 'pull-up' option on the lap belts. It takes some time to get them set as tight as I want them. I think the 'Pull-Down' option would have been better for me (it is an option at time of order... and I ordered pull-up).
98 BMW E36 M3
07 Jeep GC Diesel |
| Bookmarks |
| Thread Tools | |
