| Register | FAQ | Members List | Calendar | Search | Today's Posts | Mark Forums Read | |
| TireRack Garage | Homepage | Supporting Vendors | Articles | Online Store | Photo Gallery | Forum Rules | Advertising |
| Forced Induction sponsored by Active Autowerke Discuss turbocharging and supercharging your BMW engine. Also force-feeding Nitrous, Propane or water. |
Thread Tools |
#26
MOE -- My GF is still looking for two cars for her daughters, and I would like to revisit that with you now offline. The timing is perfect. What is motivating the sell? This time it's a CEL --mixture deviation too rich; mixture deviation too lean
Johno
99m3 coupe Eurosport Twin Screw -- 345 whp/281 tq South Bend Stage 5 Clutch/Z3- Short Shift Kit Koni SA/H&R - Front/stock springs Rear Ground Control RSMs Eclipse Sunroof mod
#27
When you had the smoke test performed, where did it leak? How about a pressure test? They are usually better for boosted applications.
Did the fault follow the O2 sensor when it was swapped? I'm guessing not. Sounds like its time to TTS1 it Johno. You'll make moar torques and have moar fun, and its far easier to diagnose.
![]() 2008-2009 Turbo/Motor Build Thread - 382whp/402wtq & 12.8@116.6 | M52 Engine Parts For Sale | S52 Engine Parts For Sale
#28
The fault did not follow the 02 sensor. I am tempted with the TT S1. Also an AA system. Nick G. bends over backwards to give excellent cusotmer support, as does Marco. UNtil I fix the current problem I am stuck. I would not sell this to anybody before it is runing 100 percent, and if the problem is with the car (vs. the TS system) I will be in the same boat anyway.
Johno
#29
I hate the thought of selling my system but you saw the pictures of my car and it's totaled. I should be getting the car this week and will start posting things shortly after. I know you are frustrated but you have to admit there is nothing like the power this system puts out when everything is working well! Good luck with whatever you decide to do. I hope to find another project and be back on the boards in the near future.
2000 M Roadster, Eurosport TS SC - 73mm Pulley ~ 14lbs Boost, Schrick Exhaust Cam, .098 Head Gasket, ARP2000 Head Studs, S54 Radiator, TMS Shorty Headers, UUC LW 8.5lb Flywheel, SPEC Cerametalic Race Clutch, UUC Clutch Stop, UUC Tranny Mount w/Enforcers, UUC EVO 3 Short Shift, UUC Braided Clutch Line/CDV Delete, Dinan Throttle Body, Dinan Front Strut Tower Brace, TCK Koni S/A Front & Rear Struts, H&R Sport Springs, H&R Adjustable Front Sway, TCK Delrin Rear Trailing Arm Bushings, Zimmermann Drilled Rotors, Braided Brake Lines, Scorpion Exhaust, Hella Fog Lights, For Sale - Stock Headers, Intake Manifold, and Exhaust
#30
Sorry to hear about your car.
You are right -- Josh developed a superlative system. It feels just right on the car.
Johno
#31
FOR SALE!!! 42lb Injectors CLICK HERE
![]() Eurosport Twin Screw | TRM Tuning | UUC |Dollar Tree | H&R | Active Auto Werkes | Vorshlag | Wal-Mart | Cobra | Mason |EMP Stewart | ZKW | Understanding Wife = 128 whp (per liter) & 311 ft lbs TQ ![]() Tarheel Chapter BMWCCA / Tarheel Sports Car Club |
#33
you someone DID want to revert to NA/stock. The part I dont get is the DME/tune thing.
We all sent our DME's to Josh/Conforti for modification all those years ago. So how do you go back to stock tune? My guess is you would you include the existing/modified DME you are running now as part of the TS kit you are selling then buy a different stock one for your car after its had the goodies removed?
'99 M3 Hellrot vert; Eurosport Twin screw SC, Schrick exhaust cam, TRM "Stage II TS" tune, UDP's ~400whp; oil cooling system; GC coilovers; Euro 6-spd w/diffsonline 3.46 LSD |
#35
#37
Honestly, given that you are not a DIY type of guy, I would sell the kit/car and go with something else that satifies your desires in OE form. It sounds like you need something you can drop off at the dealership, get a loaner, etc.
I think it is the nature of the aftermarket FI beast to have to tinker and trouble-shoot with some frequency. To the extent you have not had to do this for the last 40k miles is a tribute to the strength of the ES kit.
Mr. Hyde
![]() Dr. Jekyll
#38
#39
Here is a picture of the MAF harness we discussed from the install instructions.
#40
Find a porsch wreckers, and ask them if the do "rental" on the MAF you need - quite often a wreckers will loan out parts to help people like you and me diagnose problems
Fast, Cheap, Reliable - Pick any two, and the third is laughable
#41
Thanks for the suggestions.
I actually do ALL of my own work on the car -- it's when I get into territory where there is no service information available that I get concerned. I would have ZERO hesitation getting a kit from Nick G, Mike McCoy or Marco.
Johno
#42
On another note, i have been thinking of my dream car.......E30 M3 Chassis with an S50 with a TS = WOW!
#43
i would guess around $6-7k, it depends. i am going to sell my twinscrew kit soon with 80k+ miles on it and hardly ever any problems. i hope to recoup that amount.
ORDER YOUR PRIUS STRUT BAR NOW, BECAUSE THEY ARE BACKORDERED
| Bookmarks |
| Thread Tools | |
