Has anyone used one of these to get some alignment numbers?
http://www.sears.com/shc/s/p_10153_1...8293000P?mv=rr
Says it's good to a tenth of a degree, just like SmartCamber gauges. Seems like if you could rig up a jig with some equal length dowel rod to lock between the tire and rim. You could lay it down right in front of the tire and be able to zero out any level differences. Seems like it would work.
I need a laser level either way to setup my toe-plates, so why not use this tool as well.
Craig BricknerClick to Join: BMWCCA # 366493
BMW CCA/PBOC/Chin Motorsports DE Instructor
2008 M3 Sedan Jerez/Black
I don't think that that will measure a horizntal angle. You cabln do a poor man's alignment with string and jack stands though. Mind you, toe plates can be picked up pretty cheap too.
2011 M3 Sedan
2006 GMC Sierra 2500HD LBZ
1999 323i GTS2
1995 M3 - S50B32/S6S420G/3.91
1990 325is
1989 M3 - S54B32/GS6-37BZ
Hers: 1996 Porsche 911 Turbo
Hers: 1989 325iX
Or you could completely rip off the smart strings design like I did... cost maybe $35 in steel and welding consumables.
Sorry about the crappy quality of the pics. That, and this was a test run to make sure it worked out...
I use a longacre digital level for toe -- but I need to make something that doesn't rely on the hub of the wheel to rest on.
I think the zeroing will be the hard part. In principle, in seems like you've got it figured out, but practice may be way different. I tried a similar method that another guy swore by that didn't work for me. I thought I had found an really level spot in my garage using a 36" level, then did trig to figure the camber angle...my floor was not as level as I thought.
Anyway, if you're getting the digital level anyway, and your idea works, you could do a really useful DIY.
BTW, Greg L., Micah, I, and others were looking for you Sunday. Sorry that didn't work out for you.
Dish soap works and is less messy then grease.
I checked camber on scales prior to doing a corner balance. Since the pads where level and in the same plane (to about a 1/16") it seamed to have worked. At any rate, my driving isn't as good as the car is, so a good enough setup is good enough.
- Ian
2000 M Coupe, stripped and DE prepped
46mm wheel bearing socket for rent - $30 deposit + $10 fee. PM for details.
Ceramic or vinyl?
Right! Safe is my number on goal. Diving into adding rear adjustments pretty much forces me to do my own as it's a real pita to adjust after the car is back together.
So if I can get within .2 degrees and nearly dead on with toe, I'll be happy.
I'm going to buy the level either way to be more accurate with toe I'll post back.
Any more tips, thanks!
I just cut up some leftover 1/8" lexan to make 2x2 plates with some grease in between for settlling. A bit messy, especially when dirt gets in there, but it works. I might try dish soap, or put them in bags or something. I level my scales for corner balance, then put the lexan on top (2 each), and do my alignment there. Easy to settle the suspension on the lexan plates just by shaking the car. I use strings on either side of the car on jackstands (measured from hub centers) for toe. Works well, to about 1/16" which is probably closer than most alignment shops get.
The smart strings (or DIY knock-off) would great for track side though!
So far I just adjust camber and just measure from the center hub of the wheel to the string on both sides. Not the most accurate way to find the center line, but I haven't had a chance to measure it any other way. Really, that's the way the laser racks find the center line (IIRC.)
I also use the rack stop from turner to make sure I don't have to reset the steering wheel all the time.
A buddy of mine that works for Pratt & Miller has this for his track car:
"There are some people who sit behind the wheel everyday unaware of the potential man and machine can have when pushed 10/10ths in a symbiotic relationship." -Anonymous
Has what? You ended in a colon....not sure what you are talking about.
A setup like that is cool - but costs ~$2k or more.
- Ian
Oh, so there's a pic there and I'm blocked at work. My bad.
Yeah he bought it used from a race team but the low end of the scale for that is around $3600 with scales and everything.Yes there is a picture in there. Sorry...I'll host it on my PB account here in a minute to see if it works for you. How about now?
GST had this setup at the redline time attack event at california speedway a few weeks back. pretty impressive.
check out these as well: http://www.tein.com/products/alignment-gauge.html.
I think some of the p-wrc teams were using a similar setup when I saw them in mexico.
Chairman of the Bored--Live Sockets Entertainment
Join the Rally Revolution!
