Okay, I had a BMW distributor cap on there, all nicely numbered with wire #'s. That cap and rotor is completely worn out. When I replaced with aftermarket those numbers are no longer on the distributor cap. I know the cylinder firing sequence but the engine runs incredibly rough when I hooked it up in that fashion. Can someone send me a pic or help me out with numbering?
No picture but "from the bentley"
Spark plug wires must be installed such that firing is
1-5-3-6-2-4 where 1 is at the front of the engine and the rotor turns clockwise when viewed from the front.
***EDIT*** Found it
Right-o, I know the firing order. But which connection on the distributor cap is 1? It's not the lowest (or "first"). I guess there's only 6 possibilities, eh? I guess I'm a little worried I'm hurting something but the worst case is setting off a check engine light and it not starting (?)...
Check my edited post
PN is 12111725070. I'll check in a bit, but I'm pretty sure both my original and replacement parts had numbers on them. Original was Bosch, new stuff is Bremi. What brand did you use?
It has to be something else, since Bremi has the numbers on their caps ... at least mine did when I replaced it last November.
