Page 70 of 83 FirstFirst ... 2045606162636465666768697071727374757677787980 ... LastLast
Results 1,726 to 1,750 of 2052
Thread: Carsoft Success!
  1. #1726
    Apr 2006
    California
    2008 BMW 750LI
    thanks for this,will this work in win 7 32bit? thanks....
    Quote Originally Posted by Ricardo567 View Post
    This is a list of all files necessary to run Carsoft 6.5.06 in windows 7 (64 bits) laptop with only USB slots
    1. Download the Winzip 15.5 trial version http://www.winzip.com/win/en/index.htm
    2. Get Carsoft Interface at CarsoftWest for $56 http://carsoftwest.com/services.html
    3. Get Carsoft beta software from http://www.4shared.com/file/EEyW2qRh...Windows_7.html
    4. Buy Belkin (F5U409) http://www.frys.com/product/5756282#detailed
    5. Download the driver of Belkin USB-Serial converter for windows 7
    http://www.mct.com.tw/upload/Driver/U232_10.2.zip
    After downloading from the links above, you would have 4 files necessary to run the project:
    [IMG]http://www.****************.net/newuploads/e9122.jpg[/IMG]
    You won't need "BMW_Tester.rar" if you don't buy interface from CarsoftWest.
    How to install Carsoft 6.5.06 for Windows 7 (64 bits) with USB supported.
    http://www.youtube.com/watch?v=QFJ-ZToyQFk
    How to connect a laptop with Carsoft 6.5.06 for Windows 7 (64 bits) and E46 2000 via CarsoftWest Interface
    http://www.youtube.com/watch?v=5dy3vbJopr0
    This is LIVE "DME & EGS" Idle Testing E46 2000 with Carsoft 6.5.06 and Laptop Windows 7 (64bits)+USB port
    http://www.youtube.com/watch?v=uzOFd5dI29w
    This is LIVE "DME & EGS" High Way Testing E46 2000 with Carsoft 6.5.06 Laptop Windows 7 (64bits)+USB port
    http://www.youtube.com/watch?v=BCZh4hGO8sk
    (edited.thanks)
    2008 Bmw 750LI
  2. #1727
    Orange County, CA
    E39it, 03 M5, F10 535
    bosanci28, you can edit the double/triple posting yourself by editing each post you want to remove and then chose delete from the drop down menu. Happened to me more than once.
    E39 M5, E39 SC Touring, F10
    "Beating My Wallet" but loving it!
  3. #1728
    Bay Area, CA
    E30 325i, E53, E46
    It will work under win 7 32bit as well and I installed under win 7 32bit. No problem at all. Hope this help.
  4. #1729
    Apr 2006
    California
    2008 BMW 750LI
    well,his file contains some virus,my internet security ,delete it some of files.
    i have a good working version ,but for xp.
    thanks anyway,
    2008 Bmw 750LI
  5. #1730
    Sep 2011
    colonia Lindavista Mexico
    1995 BMW E34
    Hi, everyone, I am a new here, I want to buy a good quality carsoft, anybody who can suggest me one chinese reliable supplier? much appreciated!
  6. #1731
    Apr 2006
    California
    2008 BMW 750LI
    well you want to buy one? or more than one?,
    if you buy from china sometime they charge way to much for shipping,
    if is for one i suggest you buy from ebay if cheaper or there are website that sells those around 50$, with out the software ,i think.
    goodluck
    2008 Bmw 750LI
  7. #1732
    Sep 2011
    1995 BMW E34
    carsoft
    Quote Originally Posted by bosanci28 View Post
    goodluck
    I just need one for own use, Ebay sells expensive I think, I think there is site which sells cheaper and can pay by paypal. can you suggest?
  8. #1733
    Apr 2006
    California
    2008 BMW 750LI
    Quote Originally Posted by sengthan View Post
    look here 57$ from china (free ship), or here usa 56$ free ship.
    but make sure you do more research,to get the right one,there are few design there,the one i have is different than the 2 links i put here.
    goodluck
    2008 Bmw 750LI
  9. #1734
    Sep 2011
    1995 BMW E34
    Thanks for your info, I'll think about it.
  10. #1735
    Des Moines, Iowa
    1993 BMW 325is
    Hey, does anyone in this thread know what dme code 252 on a 1993 325is usually indicates?
  11. #1736
    Sep 2004
    FL
    2017 F250
    Alright so I followed all the instructions, got the crack folder with the 10 files and everything.
    When I plug the module into the car, either under the hood or using the OBD2 port, 4 out of 5 green lights come on, only the service interval light stays off.
    But when I try to run a total diagnostic I either get the cannot connect to module error, or a "ERROR - Read error file" or something like that (sorry it's late and I don't remember exactly what it said).
    But if I just run the DME diagnosis I will get some output like software version and stuff like that, all others seem to not be able to communicate with the module.
    I'm running a clean install of win2kpro on an old laptop with a serial port.
  12. #1737
    Dec 2007
    Queensland, Australia
    E70 3.0sd E21 323i
    Run a single diagnosis on the file that shows the error - this will display the error and allow it to be erased once the fault has been rectified.
  13. #1738
    Sep 2004
    FL
    2017 F250
    Alright so the "Module does not respond" is normal and just means it either doesn't exist on the car or there are no errors??
    Here are my results, feel free to advise on how to fix the errors:
    -2002 X5
    DME:
    211 - no msg
    227 - no msg
    68 - Crank-shaft sensor
    EGS:
    83 - EDS/MV voltage supply
    -2000 M5
    DME:
    106 - Injection valve 3
    -2001 530
    DME:
    39 - Signal Break Light Switch (I already know I need a new one)
    168 - Pedal position sensor potentiometer supply channel 1
    227 - Mixture Deviation: bank 1 Cylinder 1-3
    228 - Mixture Deviation: bank 2 Cylinder 4-6
    EGS:
    149 - CAN - ABS/DSC wheel speeds (Pretty sure I just need a new wheel speed sensor)
    50 - Speed monitoring 1
    146 - CAN Torque Interface
    EDIT: After watching the videos above I see that it should says "Status: OK" for the modules I have with no errors. I find it hard to believe the M5 has no other module besides DDE, and the x5 and 530 only have DDE/EGS. But then again what do I know?
    EDIT 2: Just found out I need to use the round connector on the X5. But so do I really not have any other modules on the X5 and 530?
    EDIT 3: Got more output from the M5
    Instrument cluster:
    BF - Instrument Cluster Internal Error
    CE - Outside temperature sensor
    F5 - CAN Identification missing (ASC)
    90 - Power supply Term. 15
    ABS/ASC:
    116 - no msg
    LCM/CCM:
    23 - wiring dim potentiometer
    I have no idea what any of that means
    So I did the same thing mffarrel did and bridged pin 7 & 8, it did the trick. I was only able to read DME and EGS before, now I can read all of them (except the ones I don't have of course). After doing lots of module reading and error erasing and live data showing, I tried starting the car and it wouldn't. For a good couple minutes I thought I had messed something up, but it just needed a jump. I really didn't think I was out there that long with the car on and not running, but after I got it running I tried reading the modules and stuff with the engine running and everything worked just fine.
    So I suggest having your car running just so you don't end up draining your battery down.
    Now who wants to tell me what program/how to set remote windows up?
  14. #1739
    Long Beach, CA
    1995 BMW 318is
    3. Get Carsoft beta software from David Mc above ( Post # 1715) to get the carsoft 6.5.06)
    http://www.youtube.com/watch?v=CZ9xAn4tMro
    http://www.youtube.com/watch?v=ALLq7lnQL34
    http://www.youtube.com/watch?v=piFSwoU8iLo
    http://www.youtube.com/watch?v=IXEA5x6jr_w
    BMW E46 3 Series Diagnostic Test with Carsoft 6.5.06 via Laptop windows 7 (64bit) and USB
    Ricardo567: I have Windows 7 64 bit and I was trying to follow your directions in step 3 to download Carsoft 6.5.06, but all I see from the files in the 4shared link in post #1715 is "BMW Carsoft 6.5.rar". I also noticed in your video that the file you have is actually "Carsoft 6.5.06 for Windows 7.rar" Can you tell me where to get this file? PM me if necessary, thanks.
    Update: for anyone with the same problem, use the link in step 3 in post #1727 to get Carsoft 6.5.06 for Windows 7. The directions for step 3 in Ricardo567's original post are old.
  15. #1740
    Nov 2011
    France
    E46 318I
    Hello everyone, I'm french and I really need your help..
    So, i've made the installation of files exactly like described in the first page..
    I've an e46 318i from 2000 with only obd2, no obd1 under the hood (sucks).
    I've a carsoft interface and a computer with xp and a real port rs232.
    Carsoft seems to work, but only DME respond ! The live data works fine but that's all !! No other module seems to respond !
    I try on the e36 from 1997 of my brother and all module seems to respond fine !!
    So what should I do ??
    Thank you all !
    So I read the mffarel trick, and when I openned my obd2 plug I see that the pins number 7 and 8 are already bridged, there is just one cable for 2 pins.
    I didn't know how to open the plug connected to the interface, could it help if I try bridge or something in this plug ?
    Everything works fine now, I made a mistake in the pin number, i finally bridged the pin 7 and 8 and it works fine now !! Thanks bimmerforums and mffarel !!
  16. #1741
    Sep 2004
    FL
    2017 F250
    I previously got carsoft running successfully in win2k.
    But now I'm trying to get it running on vista...problem is I can't get the setup to run. I tried compatibility mode, running as administrator, etc. My cursor just changes to the loading symbol for a couple seconds and then nothing.
    What am I doing wrong?
    Edit: Got it to install, I think it had something to do with UAC (User Account Control) being turned on. But I will be attempting to get it to work with a usb->rs232 adapter, so wish me luck.
    Edit 2: No such luck. Tried all the different prolific drivers, some worked some didn't, but in the end carsoft couldn't communicate with the diag cable (which I know works). Granted I got a cheap usb to serial from monoprice so I didn't have my hopes too high.
    I got a PCMCIA to serial adapter, but my laptop takes pcmcia express, and those are like $30
    I think I'll just get an extra long serial cable and just use an old desktop I have laying around.
  17. #1742
    San Jose, CA
    1997 BMW 540i 6 speed
    Why do you guys futz around with bootleg software? Windows is bad enough, w/o adding some cranky s/w!
  18. #1743
    May 2005
    USA
    1994 325IC
    (edited.thanks)
    Absolutely, It works on Windows 7 32 bits also.
    Nov 2009
    Spain
    1995 M3 e36 286 Euro
    Hi,im thinking on buy carsoft for christmas.
    But i need to know what version i need for my 1995 euro M3 e36.
    what i need for run properly?
    thanks for all!
    95' Euro Bmw M3 e36 286 Hp
    83' 318i E30 K-jetronic
  20. #1745
    Jan 2012
    indonesia
    Hii, david, i already try this step to install carsoft 6.5.06, i still have problem when i finish diagnostic, there is a note " module does not respond ", please advise me solution about this problem, thx
  21. #1746
    Sep 2004
    FL
    2017 F250
    The module does not respond is somewhat of a normal response. Basically it just means you don't have that module on your car. Or it could mean you need to bridge wire 7 and 8 (iirc)
  22. #1747
    Jan 2012
    indonesia
    Password for download carsoft v6.5 at 4shared
    Quote Originally Posted by David Mc View Post
    Thanks NoWaY! I am already using SP1.1 this is the link to the site to download Instructions, Carsoft 6.5, SP1 and the proper Cracks http://www.4shared.com/dir/7137899/6...4/sharing.html
    Hii, David.
    Can you help me about password to download carsoft v6.5 at 4shared and
    Can you help me about activation code v6.5
    My email : rachmat168@yahoo.com
    Thx for your help
    Best Regards
    Rachmat
    hii, lava lamp
    thx for your advise, i already use total diagnose, and result on module not respond in all diagnose
    please advise me
    Thx
  23. #1748
    Dec 2007
    E70 3.0sd E21 323i
    See post #607 on page 25 of this thread. You do not need an activation code if the software has been cracked correctly.
  24. #1749
    Palm Harbor, FL
    06 E64, 03 E46, 01 E36/7
    I've got Carsoft installed and running, but I get results in German. I tried again and thought that I loaded through the Eng folder, but still German. It was hard enough getting the com port shuffle and get the program communicating, so I hate to mess with it at this point.
    Is there anywhere that translates the error codes for the various modules (I know that I can type each into Babel or similar, but sometimes the translation isn't so good)? For example, the airbag module shows codes 45, 27, 52. These don't match up with the codes for a Peake tool, for example.
  25. #1750
    Dec 2007
    E70 3.0sd E21 323i
    Peake codes are in hex, you can convert them to decimal values using your computer's desktop calculator in scientific mode - push the hex button, enter the value, then push dec. Try the translator here http://translate.google.com/#
