I've been well aware of the 1999-2001 Bentley Arnage Green Label running a Cosworth-BMW twin turbo 4.4 L M62 engine for quite a while. I researched this several years ago, but came up frustrated when I couldn't find specs anywhere.
Well, I took another SWAG at this a few nights back and came up with considerably more information.
First, the 1999 Bentley Arnage had two Honeywell-Garrett GT1752S. The Bentley part numbers for these turbos are:
PB20321PH - Right hand turbo/manifold. BMW engine.
PB20320PH - Left hand turbo/manifold. BMW engine.
The Garrett turbo code on these turbos is:
452238-0003
452237-0003
The Bentley turbo part number appears to be a turbo/manifold combination from a number of sources. I have gotten pricing on these turbo/manifold combos through some speciality classic restoration shops. We're looking at around $2,500 for a single manifold/turbo combo. Unfortunatley, the passenger side (right) manifold is more difficult to obtain.
After a full week, I have been unable to get a single photo or diagram of the manifold/turbo to ensure so much as rough fitment possibilities. I have not gotten desperate enough to purchase the manifold for the purposes of measurements (and mouldings should a fit be eminent).
Maybe someone can leverage these data points for a future build. Or, more likely, the M60/M62/S62 will remain virgin V8s never seeing the world of BIG BOOST save unlikely HPF S62 TT .
GT17 hehe
Might be better off with some K03 action
too bad one can't just grab the manifold for cheap. at least it appears that one can obtain a mani. fitment remains to be seen. now who's got 2k to spare for this????
My slushboxed nikasil E34 530i is about to die and is a organ donor for future FI project, but I need a lot of machinery to make all those custom parts I need to build it the way I want, the potential of the engine is awesome, but it's plagued by very few aftermarket parts.
Either you pay custom made stuff or you machine stuff from scratch or from other existing parts, time consuming...yes.
But IMO a screaming V8 is just too addictive.
My Honda VTR1000F motorcycle build-----Leakdown tester-------M60 oil pump bolts------1000hp-----Jeep care
someone needs to do it
Why not just make a simple log manifold with a T25 flange and put two GT2560Rs or two GT2860Rs depending on your budget.
It should be very possible to fit that turbo up close to the block with a log mani, and two GT2560Rs would cost about $1.4k brand new and support about 550-600 rwhp and the compressors actually fit the M62 engine very well.
Internal wastegate, so no worries about packaging an external(or having to buy one), and you only need 2.5" intake tubes and 2" compressor outlet tubes, so relatively easy to package. Then blow through MAF and some sort of tuning. Shouldn't be too hard to crack the DME of an E34, so maybe some 36 lb/hr injectors.
It would be a pretty involved project, but I don't think it has any steps I'd call "impossible."
it's the closest thing i've seen to a turbo manifold for the e34/e39. maybe someone can fab one for less than 2500? problem is that nobody wants to drop 2500 test fitting parts.
I offered to make a TS kit for M60/M62, but can't find any local people who have a blown V8 that I can use for mock up purposes. I'd pretty much design the kit for free, and if the person who was interested wanted to pursue the project, they would just have to pay for materials/machining/parts costs.
In essence, the hardware is the easy part. The hard part is going to be finding someone who can tune it.
Regards,
Joe
1997 M3
1999 Z3 M Coupe - Turbocharged
Does it have to be in the car. The shop swaping my motor this week has one lying a round and when i go tomorrow i will ask them about it.
Let me know. However, if they have one will you pay for shipping to you?
Rito
530i E60 Wizard of Nos Nitrous System/STS Rear Mounted Custom Turbo(PSI_unknown)
we, aceperformancesystems.com, are working on a kits for M60/62/Tu, and N62/62Tu as we speak.
Probably see some more solid information about it around the end of this year realistically.
Intercooled twinscrew
--npavlo
1997 M3
Go for the twin screw. The boost with my whipple is basically instant.
