Im board at work and started thinking about headwork for my S50. I have decided cams are not worth it since I plan to do go turbo(for a daily/random track whore, around 400whp). Car currently has 120k on it but is running strong as ever.
So two part question for shits a giggles.
First is porting worth the effort when FI is the plan?
Second, I know the S54 head is better, but will it fit?
M5 because why not have a 700hp baby mover?
The answer to question 2 is no they are very different.
93 325is: obd2 M52, 22rpd tuned, 6266, RSI manifold, 555whp on 18psi
kinda figured.
so what about porting the S50? Any worth while gains without getting into larger valves?
can you give me some more info? Price, flow numbers, dyno sheets showing gains? What exactly are you cutting/smothing and how does it differ from a NA port job?
If I do anything I will more then likely just do it myself, but if the price is right and the power is enough I might be convinced to splurge
I would think if you are even asking those questions you probably don't have the knowledge/skill/tools to port the head yourself.
