Ok, I just bought an e30 325e with 160K+ miles on it and have no idea when the timing belt was last changed, if ever. is there a way to tell if it's still good? Hell, can you SEE the timing belt without disassembling things (obviously, don't know much about it). Either way, I know they suck on e30s apparently and it'll need to be changed out for some peace of mind. How much am I looking at for labor? How many hours does this take? Is this something i can do myself? The extent of my mechanical knowledge extends to suspension work. I've changed control arms, bushings, and shocks. That's really about it. Thanks in advance!
Yes it is a job that someone can do but in your case i would leave it up to the professionals. If you mess one thing up it can damage the whole engine.
I wouldn't want to say futile words, but i don't think you have a timing belt in your engine. It's a timing chain and it is inside the engine compared to a belt that would be outside the engine. I guess for a timing chain the flatrate that BMW would charge should be in between of 3-6 hours but i never asked since you don't change a chain as much as a belt. Like mine as over 200000 miles on it and still strong.
Winter and summer cars..... life is goooooood.
your correct. e30 do have timing belt and i would def recommend replacing it before a major failure occurs
I think i understand my "in space brain" thought now. The E30 is your 1987 bmw ? i'm not to good with the E.... kinna models. I thought it was for the bimmer on the pic, so that is why i didn't understand you newer model had a belt. Am I getting this right this time......
yes thats correct. you need to study up more on BMW
hah, yeh, the 87 is an e30. the white one is an e46
you'll get the hang of it. just keep reading the boards
I did the timing belt on my daughter's 1987 528e, it was SIMPLE. The only mistake I made was when I loosened the fan clutch's 32mm LEFT HAND nut. Yeah, I knew it was a LH, but when the wrench slipped, my arm broke off the hose that goes from the coolant overflow reservoir to the radiator...AT the radiator. I couldn't mickey-mouse it, I had to get a replacement radiator (cost me $25!)
Other than failing to disconnect that one thing FIRST, it went easy and took less than 90 minutes. I wasn't actually in there to change the belt, but the water pump. On that engine (and I think it's the same as yours), the coolant pump is part of the timing belt tensioning system.
Actually, I'm pretty experienced. Years of owning crappy American cars got me loads of work. I have both a Bentley's manual and a Haynes for the E28's (I also have a '88 535i.) Given the choice, it's a Bentley's, hands down better.
For the job, you need to remove the fan shroud, then that little hose ant the big ones. On an E30, you may need to pull the radiator for more room, and have a THIN 32mm or 1-1/4" wrench to get the fan clutch off the water pump. If I recall correctly, take off the distributor cap & rotor, a few bolts around the water pump and the timing belt cover, and you're in.
Just look for the timing alignment marks to be matched, and don't move anything once the water pump is out (it's holding the belt tensioner.)
Really a much simpler job than I thought it would have been, and I'd never done a timing belt before. Timing chains on big American v8's, yes, but this was MUCH easier.
hmm... i'll have to see if i can find a writeup on this. I'm always up for a challenge and could be fun and give me some confidence in the mechanical thing. just don't want it to be TOO much a problem. would hate to start it and then have to pay for a tow on top of the labor
Most shops charge about 3 hours to do the job. With an understanding of what needs to be done but never having done one before, I was able to get one done on my old '87 325 in a little over 4 hours.
+1
3 hours. just asked one of our veteran tech's, and he did just did his on his E30 in about 30 minutes, LOL.
Took me 90 minutes on my daughter's E28, and I'd never touched one before. Having all the right tools helps enormously, BTW.
As I stated above, I was in there to change the water pump, but at the suggestion of my parts supplier (Steve Haygood, Automobile Solutions of Thomaston GA, http://www.stevehaygood.com)
I decided to change that belt while I was at it, just in case it was due. (It wasn't, but I had the parts in hand so why not. Belt and tensioner, new.)
there should be enough room to do the work w/o removing the radiator, you can put a piece of cardboard to protect the radiator.
fantastic. you guys are great. one last thing. any web writeups, preferably with pictures or at least exactly what tools i need?
Yeah this one
http://www.pelicanparts.com/BMW/tech...iming-Belt.htm
is pretty good. Your best guide is the Bentley manual.
No pictures on this onebut a very good step-by-step description http://www.bmwe30.net/cgi-bin/datacg...119&Section=08
yeah i think our shop charges around 4 hrs including the cam seal.
There's a height beyond skyscrapers, there's a distance beyond the freeway.
Certified BMW Level 1 Technician
2000 540 Wagon (sold), 1995 740i (sold), 1984 Rabbit GTI Turbo,2007 328xi,1997 318ti (sold),1995 525i
I no longer live in Vegas, that was a dumb pick on the username
thanks for the help everyone. i'm still deciding whether i want to attempt this or not. reading writeups, it looks like a job that could be extremely easy but then not be once i start.
