Bought this off Ebay here . (Top right). It cost £67 + postage £27. Clearly it will fit in width and height. Depth may be an issue as it's 76cm as opposed to 60cm (Allard)..I will need 2 short right angled pipes
diagram of pipework
[/quote]
....3 months later finally past the thinking stage ....I'll see how the car likes living with this slightly more restricted airflow for a while before repositioning the old fan currently upfront to its new home behind the rad. Trimmed the new cowling which originally had the same perimeter profile as the cowling behind the rad with a jigsaw to fit snuggly one inside the other ... then bolted them together like this
took the old fan and pwm controller unit off its old front mounted frame this afternoon and mounted it in the new adapted cowling (used some more bolts with spring washers to secure very firmly) behind the rad. im gonna run it like this for a week or two to make sure it doesnt overheat vibrate etc. was a bit worried it would vibrate too much as the old fan frame is actually cushioned with rubber grommets where its bolted to the car. but it runs smooth vibration free as before & aircon no change there either so looking good touch wood
here are some photos...
old intercooler
new fabricated bracket painted black
old intercooler out
rubber tubes
alloy extentions
silicone bends
there she is
left side pipework
sliced brake duct left side
brake duct back in place
same from the front
right side with spliced brake duct ...forms part of the plastic structure and rigidity of the wheel arch so cannot be removed completely
a side view
top mounting
undertray back on
bumper back on
from above
finished
and back home again
Looks really nice.
2002 325ci
too much work! but i like..
///bMpower
Thats Bad azz!!!!! I like alot, did you feel any gain in power?
that is sweet. so you dont have the fan anymore right?
RIP homie TehPandaShow: Loiue
yes increased performance and scope for more boost and fuelling
lower thermal load on engine
improved economy
a/c fan has moved to the inside and is a puller now on the inside in a revised cowling
freaking nice!!!!!!!!!
Way to cool. Great pics and stuff.
2000 - 328i Black / Black with 120,000 miles
beautiful. awesome post
Manual Sports Package l H&R Race Springs l Angel Eyes l 6k HID's l Clears l 5% tints l LED tails l M3 Trunk Lip Spoiler l Conforti's Cold Air Intake l CSL V2 l Vorsteiner Vented Hood
Looks like a lot of hard work...im to lazy to take something like that on. Hell, im to lazy to even work at Taco Bell . No job for me.
Nice work!
99 323i
ive been asked to explain the cowling a bit more ....didnt make it very clear where it came from
the 320d existing cowling is empty, just a large tube behind the rad. i noticed that the cowling from a 1.8i has the same outer perimeter shape as that in the 320d (check realoem.com) and it holds the same fan as that in the 320d, but behind the rad instead of in front. i wanted to keep the old cowling in situ but use the 1.8i cowling also (bought off ebay for not much) to hold the a/c fan. behind the rad it's doing the same job except it's now a puller instead of a pusher. i trimmed the 1.8i cowling round its edges to make it fit inside my 320d cowling and bolted them together... then it just drops in freeing up space at the front for the intercooler.
1.8i fan here - http://i12.ebayimg.com/07/i/000/9d/a6/8cfa_1.JPG
simon
thats wild, im impressed with the hooked up touring wagon...sweet
thanks for the nice comments guys!
