Name: talal abdulla alkuraif
Chassis: euro mz3 1998
Color: blue
Mileage: 150 000 km
Build Date/Swap Date:from man june 1998
Motor: S50 B32
Transmission: 5 speed
Any Other Upgrades/Modifcations?: evo pulleys - e46 crank pulley - fan clutch delleted(electric fan) - voltage stabilizer - fuel ragelator - chip wich conect to the ait sensor and o2 sensor - cf intake system and k&n filter - ebay header - 11lb act flywheel(oem clutch) - 3.23 diff - fast tunning chip- bilstein shocks - hamann body kit
Chassis: E30 M3
Color: White
Mileage: 100k
Build Date/Swap Date:winter 07
Motor: S50 B32
Any Other Upgrades/Modifcations?:too many to list, motor is essentially stock
Name: Vakhtang Janashvili
Chassis: M3 E36 evo
Color Green
Mileage 38500
Build Date: 12/96
Motor: S50B32 (3.2)
Transmission: 6 speed
Differential Ratio: 3.25
Any Other Upgrades/Modifcations?: Supersprint decat x pipe, Super Sprunt Racing/PSS9/x-brace/weicher braces F&R/Stoptech BBK/ BBS LM F18x8 R18x10
Chassis: D2 coilover΄s
Color:Green
Mileage:230000km
Build Date/Swap Date:1999
Motor:s50b32
Source:
Transmission:6 speed
Differential Ratio:stock lsd
Any Other Upgrades/Modifcations?:smg converted to manual, not ready yet.
17" Oz futura wheels, rear 10" front 8,5"
http://i161.photobucket.com/albums/t...9092007199.jpg
Chassis: 1994 E36 325is
Color: Mauritius Blue Metallic
Mileage: 80,000 Miles
Build Date/Swap Date: April 2008
Motor: S50B32 (3.2)
Transmission: ZF 5 speed
Any Other Upgrades/Modifcations:
Engine/Drivetrain
S54 Crank Pulley
'95 M3 5spd ZF Transmission
'95 M3 Steering Rack
'95 M3 Brakes and Rear End
Canton Oil Vapor Catch Tank
Canton Aluminum Expansion Tank
Rogue Octane SSK
Turner Motorsport 10.5lb Flywheel
UUC Red Transmission Mounts
Bimmerworld Performance/Track Motor Mounts
Euro Oil Cooler
Euro HFM
Power Steering Oil Cooler
Walbro GSS-340 Fuel Pump
Dinan CAI
Zionsville Aluminum Radiator
3.38 Limited Slip Differential
16 Curved Maradyne Electric Fan
Supersprint Race Midpipe
Supersprint Race Cat-back
Exterior
OEM M3 Front Bumper
OEM M3 Door Mouldings
OEM M3 Mirrors
OEM M3 Sideskirts
OEM M3 Rear Bumper
OEM Clear Sidemarkers and Tails
Inpro Smoked Front Turn Signals
30% Front Tint and 15% Rear Tint
Kamei Eyebrows
Blacked-out Kidneys
Motorsport Intl' Door Badges
OEM GT Spoiler
OEM LTW Risers
OEM LTW Splitter/Tray
VIS Carbon Fiber Hood
Interior
Euro M3 Evo Gauge Cluster
Black Headliner, pillars, visors, window/door trim, etc from '95 M3
OEM M3 Illuminated Shift Knob and napa leather boot
OEM M3 Dove Grey Cloth/Alcantara Vaders w/matching rear
OEM M3 Cloth Door Panels
OEM 3-spoke Steering Wheel
Bimmian Aluminum Pedal Set
PCP Grey Reverse Indiglo Gauges
Autopower 4pt Race Roll Bar
Schroth Profi II ASM FE
VDO Gauges (Oil Temp/Oil Pressure/Coolant Temp)
OEM LTW/GT Door Sills
Suspension/Brakes
'95 M3 Control Arms
Treehouse Racing Control Arm Bushings
TcKline DA Coilovers (500/500)
OEM Front Strut Reinforcement Plates
Turner Motorsport Front Subframe Reinforcement Plates
Turner Motorsport Track Sway Bars
'96+ Rtab's with Ground Control Shims
BMW X-Brace
OEM LTW Strut Tower Brace
TcKline Rsm's
TMS Rsm Reinforcement Plates
OEM Rear Subframe Reinforcement Plates
TMS Rear Sway Reinforcement Plates
TcKline Adjustable Camber/Caster Plates
TMS Adjustable Sway Bar Endlink
Hawk HP+ Pads
Zimmerman Blank Rotors
Bimmerworld EVO Stainless Steel Brake Lines
Bimmerworld Brass Caliper Guide Bushings
Bimmerworld Brake Duct Kit
Lighting
ZKW European Ellipsoids
Philips 4300k HID's (low beams)
Lightning Plus Titanium DDE's
Apexcone 6000k HID's (fog's)
Stereo
Alpine 7893 CD Player
Wheels/Tires
OEM '95 M3 Staggered/Forged/ Polished & Painted LTW's (17x7.5, 17x8.5)
Michelin Pilot Sport II's (225/45/17 & 245/40/17)
Kosei K1 (17x8.5)
Toyo RA1's (235/40/17)
Misc.
Hardwired Valentine One
18 Button OBC Conversion
Garage Door Opener Conversion
Electric Fan On/Off Switch
'94 325is #94 IP/GTS3 Mauritius Blue Metallic
"And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high." - Ayrton Senna
Chassis: 94 Canadian Eurospec Limited Edition #8 of 45
Color: Dakar yellow/black leather
Mileage 43,000 kms
Build Date/Swap Date: 10/93
Motor: S50B30 (3.0)
Source: factory imported
Differential Ratio: 3.15 LSD
AC Schnitzer S3 Sport package
ACS exhaust and chip
ACS oil & pressure control units
ACS coilovers
ACS carbon tower bar
ACS sway bars
ACS rear hard rubber bushing kit
ACS 19x8.5/19x9 Type III 2pc wheels
ACS carbon lip
ACS carbon rear diffuser
ACS carbon rear spoiler
ACS roof spoiler
ACS mirrors
ACS steering wheel
ACS short shift
ACS aluminum pedal set
ACS carbon passenger foot rest
ACS carbon dead pedal
ACS aluminum hand brake
ACS floor mats
ACS door sills
ACS carbon door panels
ACS cabon center console
ACS carbon glove box trim
ACS carbon rear shelf
Chassis: 97 Euro spec M3 (SMG)
Color Dakar Gelb (Yellow)
Mileage 127,000 KM's
Build Date/Swap Date: Factory
Motor: S50B32 (3.2)
Source: Factory
Differential Ratio: Stock
Any Other Upgrades/Modifcations?: Bilstein sport shocks, SMG to Manual conversion
charlie
philippines
95 eurospec
dakar gelb
120,000kms
s50b30
'18 icw rims,imitza projector headlights with angel eyes, hid 8000k,custom '2 pipes,turner under dirve pulleys,alpine cda9887 head stereo,focal speakers,rockford fosgate amp,audio control eql,
Name: Scott aka MauiM3Mania
Chassis: US-spec 1999 M3
Purchase Date: 01/02
Color: Cosmos Schwartz w/sunroof
Mileage: 56k on chassis/43k on engine
Build Date/Swap Date: Apr 99/May 08
Motor: S50B32 Euro Spec
Source: Alex L. http://www.abloriginalparts.com/
Swap and tech support: Bf.com member BMWDIRTRACER
Transmission: Euro 6 speed
Differential Ratio: 3:91 LSD
Any Other Upgrades/Modifications
listed sorta as put into operation; (everything has been massaged over the years)
X-brace
Generic CAI
GC C-Plates Koni Eibach 550/600
UUC LWF/M5 clutch
AutoSolutions - modded 5 Spd. unit to work euro 6pd
Sparco seats (Calvin SAT here!)
Generic Al radiator
Alpina Diff cover
euro motor
Schrick 284
Alpha N
Generic Oil Cooler
Total work over - all bushings, b-joints, mounting points 06/09 - sub-frames,rear sway bkts reinforcements
Turner 30/28 bars - stiff/soft
GC Camber arms
Super Sprint - street mid and cat back
SSR 17x9 - Victor Racers 255/40 (auto-x)
DS II 8.5x17 - Kumho MX 245/40 (road)
~3100lbs w/CD changer and a 1/4 tank
88M3 AW 43k miles Project FS
Chassis: 1993 Euro
Color: Diamantschwarz Metallic
Mileage: 72,000 km (45k mi)
Build Date: 1993-01-16
Motor: S50B30 (3.0)
Source:
Differential Ratio:
Any Other Upgrades/Modifcations?: Planning on UUC SSK and Exhaust
Chassis: 1994 Euro, RHD
Color: Avus Blue w/ Black Alcantara M-Cloth Vaders
Mileage: 43K mi
Build Date: late 1993
Motor: S50B30 (3.0)
Source: Brother of a Bf.c member
Differential Ratio: stock (3.23?)
Any Other Upgrades/Modifcations?: none
Reportedly once owned by a Manchester United footballer...now a London daily driver (meaning it has a few external cosmetic warts). The drive is quite amazing, especially at the occasional motorway on-ramp or empty roundabout!!!
"Asphalt is evil, it must be punished!"
'89 Z1 Dream Black/Alcantara/Camo, Racing Dynamics, the coolest doors known to man -- Sunny days & Sundays
'90 Z1 Red w/custom red/black French leather, Ground Control coil overs, BBS RV-F --Mais Oui!
'91 850i Mauritius Blue/Black --1 of 179
'85 M635CSi Alpine -- "Explosive!!!"
'03 M3 Conv, Imola w/ SMG -- her daily driver
'17 30 Jahre M3, Macao Blue -- 1/500 made
Previously owned: 74 2002 (x2), 85 325e, 80 323i Baur, 94 325iC, 03 325CiC, 80 633CSi, 90 325iC, 98 318ti (Budget M3), 01 X5, 02 X5 4.6is (x2), 94 M3, 98 M3/4, 16 340i
Chassis:E36 Coupe
ColorDiamondschwartz
Mileage200.000 km
Motor: S50B30 (3.0)
Transmission: 5 speed ZF
Differential Ratio:3:15 stock
Supersprint rear
Eibach springs
Strut brace
Recently bougt my childhood dreams. I found out that good years of this cars passed some time ago
Chassis: US-spec 1995 M3
Color: Avus Blue
Mileage: 79k on chassis/61k on engine
Build Date/Swap Date: 7/95 / June 08
Installer: Vintage Sports and Racing http://www.vsr1.com/
Transmission: OEM 5 speed
Differential Ratio: Diffsonline 3:73 LSD
PWR 57mm rad, Fluidyne oil cooler, Autometer gauges, Bilstein PSS9s with linear rate race springs, Cobra seats, HMS roll bar, Motorsport strut brace, Vorshlag camber plates, etc...
Chassis: 1989 M3
Color Diamantschwarz Metallic
Mileage 70k on motor
Build Date/Swap Date:Completed 7-10-08
Motor: S50B32 evo
Source: BMC Motorspares http://www.bmparts.co.uk/
Differential Ratio: 3.23 from Mcoupe
Any Other Engine Upgrades/Modifcations?:
s54 crank pulley
Evosport alternator pulley
Power steering delete
AC delete
Secondary Air pump delete
ICV delete
Heater core delete
Custom side exit exhaust
Aluminum flywheel
Custom solid aluminum motor mounts.
Parts waiting to be installed:
Carbon Intake plenum
VAC billet oil filter housing
e30 m3 oil cooler
2qt Accusump
Fuel surge tank
Non-motor related mods:
Gutted interior
full roll cage
Brembo brakes (4 piston front, 2 piston rear)
Dual brake master cylinder with no brake booster
Sparco Evo seat
Autometer gauges
Chassis: 1998 328is
Color Arctic Silver
Mileage: 150,000km on chassis, 50k miles on engine
Build Date/Swap Date: Summer 2008
Motor: S50B32
Source: UK
Any Other Upgrades/Modifcations?: UUC Evo3 SSK w/DSSR, Bilstein Sport shocks, H&R sport springs, front M3 brake conversion w/euro floating rotors, M3 3.23 LSD, M3 front bumper & sideskirts, M3 mirrors, M3 vader seats, ZKW ellipsoids w/TSX projectors & OEM HIDs, OEM LTW wheels
For euro parts talk to Alex @ www.ABLoriginalparts.com
Chassis: '92 E36 318is
Color: Laguna Green
Mileage: 64,000
Build Date: 6/92 Body / '99 Motor
Motor: S50B32 (3.2)
Transmission: E36 M3 5 speed
Euro LSD
BimmerWorld Performance Engine Mounts
UUC Street Tranny Bushings / Enforcers
Rogue Engineering SSK
ECIS Euro Intake
Ireland Engineering Aluminum Radiator
Brembo 4 piston Calipers
Euro E46 Floating Rotors
US E36 M3 Rear Disc Brakes
Axxis Metal Master Rear Pads
Stainless Steel Clutch Line
Bilstein PSS Adjustable Coilovers
UUC SwayBarbarian F / R Adjustable Swaybars
TMS Adjustable Rear Swaybar Endlinks
BMW Aluminum Front Control Arms
Eibach Adjustable Rear Control Arms
Powerflex Offset Urethane LCABS
BMW X-Brace
Full Euro M3 Suspension Components
OEM Subframe Bushings
Powerflex Urethane RTABs
Z3 Front Shock Tower Reinforcement Plates
TMS Rear Shock Tower Reinforcement Plates
TMS Rear Subframe Reinforcements
Euro 3 Spoke Wheel
Euro Gauge Cluster
M3 F / R Bumpers
LTW Low Style Wing
DJ Auto Headlights
Apexcone 6000k SlimLine HIDs
Depo Smoked Corners
DDM Tuning M Door Moldings
It's not speed that kills, it's the speed difference that does. Obviously you aren't going fast enough.
Turning Benjamins into noise since 1997
I read a list of the 100 things you MUST do before you die. Funny, "Yelling 'HELP'" didn't make the list!
Name:
Chassis:
Color
Mileage
Motor:
Source:
Transmission:
Differential Ratio:
Coming soooooon......
Chassis: '97 M3 E36 3.20 EVO SMG
Color: Estoril Blau
Mileage: 102'000Km
Build Date/Swap Date: 3/97
Motor: S50B32 (3.2)
Source: IT
H&R Springs
[quote=jvit27;9630435]Thanks to the mods for giving us our own forum! If someone could sticky this thread, it can serve as a list of Bimmerforums members who have Euro motors and anything else about their car, whether it be a US car with a swap or an factory built one. Hopefully it will help put basic some information out there to begin the forum with and avoid clutter spread across multiple threads.
Please reply ONLY with the following info, or any pertinent info you wish to add to the list!
Chassis: 4/1994 Euro spec 286 Hp
Color Avus Blue
Mileage 88000 (147000 ks)
Build Date April 1994
Motor: S50B30 (3.0)
Source: Delivered Melbourne Australia
Differential Ratio: Standard as far as I know
Any Other Upgrades
Oil Surge protector
Later model brakes
Braided brake lines
Angel eyes
Purchased about 3 months ago, swapped my 1993 318is. Unbelievable drive... Can't imagine wanting another car!
Chassis: Coupe
Color: Cosmos Black
Mileage: 82000 km
Build Date: 1996
Motor: S50B32 (3.2)
Source: dealer
Differential Ratio: std
Any Other Upgrades/Modifcations?: coilover suspension upgrade & crappy CD player (needs update asap), otherwise std.
Chassis: 5/95 build Euro-spec M3
Color Code: Avus Blau Metallic
Motor: S50B30
Differential Ratio: 3:15 LSD
Autronic SM4, GT35R Turbo, 3.5" dump pipe into twin 2.5" custom Exh system, custom fuel system with twin in tank Walbro pumps, Sard fuel pressure reg, PWR intercooler, custom made intake manifold, AP Racing 330mm 4 Pot Brakes, VAC Diff support bracket, Carbon fibre air box.
ALOHA!
Chassis: 97' E36 M3
Color: Silver
Mileage: 90,500
Build Date/Swap Date: 5/2003
Motor: S50B32 (3.2)
Source: James Clay (Bimmerworld.com)
Any Other Upgrades/Modifcations?: HR springs, Bilstein Sport Shocks, AA Gen III Exhaust, AA CAI, thats all for now but definitely more to come ;-)
Now I get to add my name to the list! Just received it today, will install in the next 1-2 months.
Chassis: 93 325is sedan racecar
Color: black and red
Mileage: Chassis.....hell if I know. On the engine....95K from my understanding.
Build Date: 1997
Motor: S50B32
Source: abloriginalparts.com
Transmission: euro 6 speed and US 5 speed (edited for a dumb comment)
Differential Ratio: 3.91 race LSD with 3 clutches
Any Other Upgrades/Modifcations?: Well, it's a full racecar, so everything is modified. Nothing to the motor yet except for EWS delete, S54 crank pulley, and Grp N flash. See my build thread in my signature.
