Does any one know if disconnecting the battery will reset the values stored in the computer? Specifically, I want to be able to reset the fuel trim parameters.
If this will reset the paramters... how long do you need to disconnect the battery to get it to reset?
I don't know if a battery disconnect will reset the adaptation values or not. Use of the proper diag system certainly will and you'd have to use that to find out if a battery reset worked.
Jim Levie, Huntsville, AL
NO it will not...adaptations can only be cleared out with a GT1
Thanks for the reply... I stopped by the dealer today and they claimed the same thing... they will do a reset for $46
