i drive a 2000 528i and i was wondering how to remove the fog light. thanks in advance!
My girl is Hotter then my Ride
that's a great writeup, thanks.
2001 E38 740i M Sport Steptronic/Anthracite/OEM M-Pars SOLD
1999 E39 528iT Sport/Titanium Metallic/Tint/OEM M-Pars/AEs/M Grilles SOLD
no probelmOriginally Posted by islandbeef
what about the 2003 530 ? i heard that you need to remove the bumper?
If you have an owners manual...there should be instructions on how to change the fog lights.
Turn to the (alphabetical) index in the back of the manual...and look up BULB replacement...that will give you the page that the section on LAMPS AND BULBS is located...and that's where you'll find the instructions on how to remove the fog lamps.
Good luck...(the owners manual is full of useful information)
BTW, if you don't have an owners manual...you can download one from www.e38.org/e39 ...look at the bottom of the left column. If your model year is NOT listed...download the one that is closest to your model year. There isn't that much difference between the model years that you can't extrapolate.
Like Qsilver7 said, you can circumvent any heresay or conjecture by going straight to the source: the owner's manual. The information presented here is in it. If you don't have one, you can download one at www.e38.org/e39/. Scroll down to the extreme bottom of the page to the section titled Owner's Manuals and download the owner's manual for a 2003 e39 5-Series. Since the manual is a PDF, you can search for text with great ease and much faster than in a printed manual. What follows is the pertinent information from the manual; if you download the 2003 5-Series manual, this is from page 155:
I considered myself mechanically challenged when I first took out my fog lights, and in fact it was one of the first DIY repairs ever on my car. Sure it's intimidating at first, but it's so easy that really all you need is the owner's manual. The DIY for a 1996-2000 bumper to which joyfret linked are applicable, because the only difference in the 2001+ bumper is the shape of the lights; the plastic trim piece still comes out the same way, the fog light still has two screws and a nub, and it sill swings out the same way. Just get to it, it's a lot easier than you think.
so apparently my dad had replaced one of the fog lights when he was driving my car (bad choice by me!) but anyways the front driver side fog is "loose". anyone else having this issue? i can basically push it in an inch or two/it doesn't stay in place
any suggestions before i go and re-install it?
i noticed it because i was looking at my car and i saw a small gap between the grill and the light, maybe a half inch
Last edited by sirsameernoff; 07-02-2009 at 02:51 PM. Reason: Automerged Doublepost
Looking for a DIY? Parts? Check this out, it might be your ticket
Stable: e92is, e53 N62, e46M54B25, Tribby & e39 M54B30 R.I.P.
Everyone has already posted excellent info so all I have to add is that it's a piece of cake...the plastic expansion clips/pins are the toughest part IMO but once you've wiggled those suckers free, it's smooth sailing.
'00 540iA Sport w/235k+ Original TCG's, Vanos and transmission.*Trans failure at 244k+...FS Now
hey good timing on this thread haha, i have the facelift fogs, like in the picture 2 posts above mine (round fog lenses)... anyway i just bought http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=320567388328&viewitem= &sspagename=STRK%3AMEWNX%3AIT
these, and i kindof just assumed there would be some instructions with them, guess not. anybody know where i can find some? i mean, i just need to know which wires go where. thanks to anyone who can help
This is the only HID fog light retrofit I have in the DIY section. It might help, but it is on a pre-facelift E39. Wiring may differ from the facelift version.
HID Fog Lamps for the 1996-2000 BMW E39 5-Series (Excluding M5)
For pre-facelift fogs, the tabs that you run the screws through to mount the fog lights in the bumper cover break very easily, particularly the top tab. They may be broken on yours. I recommend removing the top screw first and reinstalling the bottom screw first because the top tab is weaker than the bottom tab.
Awesome post! Thanks! It solved a damaged headlamp and with the help of Importec and the replacement unit at a cost of $100.83 for PN# 63 17 8 360 575 the problem has been resolved. I figure this is 1/3 of what the stealership would have charged.
