Hi all, noticed my car left quite a large fluid spot coming from the rear. It smells like oil but my engine oil and differential is fine.
There is fluid on my shocks.. but I thought they were filled with gas?
They are Bilsteins, sports I think. So my question is, do shocks leak fluid?
If that is the problem, I just need to replace them right? Or do I need to check for anything else? (just replaced RSM's last week)
Yes. One of my yellow Konis are leaking after 200K miles. Replace them.Originally Posted by mole
...steven BMWCCA 146825
http://318ti.org | http://bmwcca.org/forum
1995 318ti Club Sport - 1996 328ti Sport - 1991 325iC - 2003 Mini Cooper S
Leaky Bilstein's is normal. Check out this link...Originally Posted by 1996 328ti
http://www.bilstein.com/warranty.php...9b7b60afae3387
From the site:
Coating of film on shock body or piston rod. A completely normal occurrence, not defective.
yea I hear konis leaking alot
Cosmos - Black l l Lux l HK l OEM clears all around l Depo HID's 55W 5000K l Strut bar
But. . .Originally Posted by SF E Thirty Six
A film would be normal. I guess one needs to define a large fluid spot.Originally Posted by mole
200,000 miles, car has been tracked 4-6 weekends a year since 2000.Originally Posted by qidm67
Yea. What a POS Konis are.
Yes, it's quite a large spot of a one foot diameter, and it seems to be getting worse.
I guess now I need to find the best place to order two more bilstein shocks
Or replace the whole set. But yeah, those are blown, not leaking. If they leak they should be replaced.Originally Posted by mole
Formerly 328i, now 332i : Debadged, Cosmos Black/Black, '99 s52 motor, custom short ram intake with ITG maxogen filter, Dinan springs, Koni adj sports, Rogue Engineering LTW flywheel clutch kit, UUC swaybarbarians, HMS oil pump, Fan Delete mod, Mishimoto alum radiator, UUC UD pullies, upgraded water pump, BBS RK2's w 235-40-17 Yoko S-drives for summer, the Shaahhhk, passport x50, Scorpion cat back exhaust, BSW midrange speakers, Recaro knock-off child safety seats by graco...
WOAH!!! thats pretty good. But I still have read about leaks from Konis. That is impressive though.Originally Posted by 1996 328ti
update: installed bilstein sport shocks from bavauto.com.
Problem fixed.
