typebigiz,
If you get a chance, can you check a code for me?
S/N S0915634
'98 328is
bump
typebigiz:
Can you help with the code for AL 4610 4 06 22350
typebigiz:
S/N S1091466
'95 325i
only correlation I can find is dropping the first digit and adding a "1" between the last two digits..Originally Posted by cush111
last 4 of serial number: code:
33134 - ----------------- 31314
93366 - ----------------- 33616
and 33616 would work too...
1991 | black | SE-R
bridgestone potenza RE-11's | hypercoil gen ii springs | shortened koni struts | ST front sway bar | (WTB progress rear sway bar) | octotat 3 point RSTB | octotat 2 point FSTB | ad22vf calipers | carbotech pads | blowed up DE, sr20ve on the way | hotshot cai | ssac header | 2.5" mandrel bent exhaust | wrx STi muffler | jwt motor mounts | B&M short shifter |
2004 | graphite | g35coupe 6MT
borla cat-back | Injen pop charger | brembos
SR20DEEP MidWest Chapter
I miss my E36 and E38; they were The Ultimate Driving ///Machines
someone give me about 3 or 4 other serial number/pass code combinations and I'll see if there is a correlation. But I need the ENTIRE serial number. The numbers before the last 5 digits could be significant.
OK vqman and other code crackers:
My Blaupunkt code is 51113 based for a serial number BP0273 1 9958100.
I’m having the same radio code problem myself. BMW ‘97 328ic (E36). I had to change out my battery and then the radio started asking for a 5 digit code. I pulled it out and looked for the code on the back to no avail.
<o:p> </o:p>
If someone could tell me what my code is it would be much appreciated.
<o:p> </o:p>
Model:
C33 DIN US
<o:p> </o:p>
S/NO.
<st1:State w:st="on"><st1:place w:st="on">AL</st1:place></st1:State> 68DU V 02 11568
<o:p> </o:p>
E-mail sent.
The dealer told me it would after about 45 minutes. It did not, so I did a search and came up with this forum. In looking through the “Code Wait” thread I discovered that you need to turn the ignition on but not start the car. The dealer never told me that. It also took two hours, not 45 minutes.
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p>
This message was most helpful.
Originally Posted by mbadger
Just bought a 2000 323i and was told that the battery had been disconnected and that I needed dealer to reset. Took it to several dealers and all I get is a WAIT on the stereo and it has never asked for my code. I am about to replace the stereo with an aftermarket stereo but I just wanted to find out if anyone has any suggestions. We've tried resetting it and disconnecting the battery again. I've read alot on these forums about wrong codes but does anyone have experience with 'dead' radios? There was a CD in it when I bought it and the phone, clock, and wait codes all come up -- just no tunes! Please help !?!
typbigiz can you check a code for me pls.
model: c33 din us
sn:To344313
thanx
Hello typbgiz,
Would you mind providing the code for the following radio?
Brand: Alpine
Model No: C43 US DIN
P/NO: 65. 12-8 375 949
S/NO: AL 8BDU W 10 30056
Thanks!
You guys actually getting codes from this guy, this is an old thread.
Anyway, I can always supply codes.
Could you please look up the code for S/N AL 6BDU W 01 13372Originally Posted by JPWheelr
Thanks,
pm me, I don't check threads.
Hi, I had the same problem, to replace the battery and now I need the code to activaty the Alpine Radio.
The radio S/N is VO655531. Could you, please provide me the code?? Many tahnks in advance.
Had to do this in my Passat. Also in my Mitz. My comment; Is there a world-wide problem with thieves stealing FACTORY radios??? Am I missing something?
Just another PITA imho.
Don
Hi there:
Could someone help me out with the code for a model C33 DIN US, s/n AL 6BDU T 12 96589? Thanks!
need help for car stereo code, model c33 din us. serial t0780953. PLEASE HELP ME !!!!!
PM JPWheelr, he can provide the codes.
NOT just on and off, read carefully below (already posted in this thread)
To clear the code wait:
- Turn key to ON position without starting the engine for two hours to get rid of the code wait
OR
- Leave the car off for 24 hours and it will reset itself for code input
turn key off an on and it should just say CODE _ _ _ _ _
Input code using station presets.
PM JPWheelr to get your radio code
FOR SALE: 1995 325 BMW Convertible - Black/Black
http://www.bimmerforums.com/forum/sh...haust-and-More
Hi, i need a code for my 1997 bmw 328i...the s/n on the radio is TO671517
My e30 is waiting for 2 hours in the parking lot so I can try to input my code and get my e30 to have tunes
Halston Pitman | sales@bavsound.com
BAVSOUND | BMW Audio Upgrades, Made Simple
www.bavsound.com | 404-381-1800
Plug & Play BMW Speaker Upgrade Kits | BMW iPhone, iPod, Android & SirusXM Integration | BMW Subwoofer Upgrades
