Here is the problem....
Whenever I driver with the sunroof open, even when it hasn't rained for weeks, and I accelerate to around 80 mph or higher, I get a shower of random drops that comes out of the sunroof into the cabin....nothing put just a sprinkle. The thing I don't understand is why these drops haven't evaportated or drained with the rest of the water?
I want to check the drain holes and see why I keep getting water on me! How do I go about inspecting these?
1997 Arctic Silver/Black M3
1999 Techno Violet/Dove M3
put a long steel wire through the tube to clean it mayby...
Currently:
95 318is, 71k original km...
Sold:
96 316i Compact
95 M3 :'(
87 190E 2.6
95 C280
82 240D
89 735iL
85 318i
95 Opel Astra 1.4
93 Lada Niva 1.6
more specific please....which tube? where?
Check my sig for the sunroof removal diy...it shows the drain tubes...hopefully none have come loose...that would be a nightmare.
I would assume that the water would have drained or evaporated as well...you may have to get in there and try to diagnose the problem...good luck
To argue with a person who has renounced the use of reason is like administering medicine to the dead. ~ Thomas Paine
You can safely assume you've created God in your own image when it turns out that God hates all the same people you do. — Anne Lamott
Custom watch straps for sale
FOR SALE: watch straps!!
E36 DIY: My articles are now located in the E36 DIY page
open the sunroof all the way. look down at the opening from outside the car, there are 4 drains, 1 in each corner of the sunroof opening. use compressed air or a long sowewhat thin flexible metal rod to get rid of any debris in the drains. be careful, you dont want to push the drain hose off and down into the a-pillar or 1/4 panel.
Similar problem to yours.
Even if it hasnt rained for a few weeks, if I open the sunroof fully slid back then close it I notice water droplets a few only drop onto my head \ shoulder when I brake hard.
I didnt recall having this problem on my previous ride.
i hate sunroofs
I miss her, back in a BMW for the time being
bump.
If the drain holes were plugged then I would suspect leak inside car? which there is not.
Did the original poster find a solution for this problem. Any ideas?
Well I just checked my 4 drain holes.
Used a jug of water on the front 2 and the it drained out all well . Tilted the sunroof ( my cars parked on an angled incline ) pouted some water in each rear corner and it drained out behind the rear wheels at edge of bumper.
Although after doing the last test when I closed the sunroof from its tilt position I noticed some water on the edge of the sunroof cassette lining. Maybe some of the water I poured in the left rear corner when it was in tilt caused this at it did all appear to drain from all 4 points properly.
nope, I never figured it out. I just try and make sure my car doesn't see rain anymore and the sunroof stays closed until I completely dry the car.
Pull the sunroof, clean out the pipes that run to all 4 corners. Then when you put it back on, use some zip ties to go around the rubber hoes, over the metal piping to help hold it in place.
'94 325is #94 IP/GTS3 Mauritius Blue Metallic
"And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high." - Ayrton Senna
