2009 E93 with GM transmission. I dropped trans pan and drained into an under lift catch pan so I don’t know how much drained out. (Stupid I know)
Installed new filter and gasket reattached pan. Went to refill system and was only able to put in 3 quarts. Everything I’ve read said it should take 5-6 but it drains out the fill port at 3. Should engine be running and warm? Odd that where I went wrong?
Yes to your question, and within a certain temp range. And running, at a certain point. You should look up the procedure steps. You may need to start over.
Using Tapatalk
see here transmission fluid level check GM and ZF without dipstick, and also there is the info to check fluid after transmission repairs https://www.europeantransmission.com...MWtechinfo.htm
Got it solved. Thanks for the info!!
