Results 1 to 7 of 7
Thread: ZF transmission problem
    Fort Wainwright, AK
    e34 BMW 525i
    Hey guys I have an issue with a ZF-5HP-18 transmission in a 95 530i with 167k. I have searched the forums relentlessly for the past few weeks and I can’t seem to find the specific problem I’m having.
    Whenever I am going more than 10 miles per hour and come to a stop the transmission has a hard time down shifting and drops in into neutral for a few seconds and if I push the gas and let off real fast it will go into gear faster. It gets worse the warmer the transmission is.
    Any ideas what this might be please let me know.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    when was the last ATF and filter change? Did you check the fluid level? How to check https://www.europeantransmissions.co...MWtechinfo.htm
    Fort Wainwright, AK
    e34 BMW 525i
    I finally got the car on a lift and found that the trans cooler is leaking. It only seems to leak under pressure. The trans fluid is full.
    Jan 2005
    Japan
    Hmmmh, if it is leaking, the ATF level could/should be down/too low
    Fort Wainwright, AK
    e34 BMW 525i
    It’s within the full and low marks and still hesitates going in and out of gear when coming to a stop
    Fort Wainwright, AK
    e34 BMW 525i
    And the bulletin, it doesn’t seem to go away. It seems to get worse the hotter it gets.
    Oldham UK
    '00 330i Sprt '92 525i
    Quote Originally Posted by m107gunner View Post
    The 5HPs do not have a dipstick. You check the level as per Shogun's link above. Maybe advise where you found those marks and if the filter has ever been changed?
  1. Replies: 43
    Last Post: 09-20-2004, 10:09 PM
  2. Transmission or clutch problem or both?
    By Dinan330ic in forum 1991 - 1999 (E36)
    Last Post: 03-23-2004, 04:19 PM
  3. problem with GM transmission need help ASAP
    By joe325i in forum 1991 - 1999 (E36)
    Last Post: 05-18-2003, 04:02 PM
  4. 325 transmission problem
    By jac2003 in forum 1991 - 1999 (E36)
    Last Post: 03-01-2003, 07:24 PM
  5. TRansmission Problem???
    By JazzeZ in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-08-2003, 10:02 PM
