Results 1 to 5 of 5
Thread: compatible instrument clusters
    PA & MI
    '01 740iL#2,'02 CBR954RR
    What are the compatible instrument clusters for the e38? Specifically the 01' models? I know the e39 is supposed to be and so is the x5?
    What about the e46 (m3) though? Has anyone tried that one? It seems to be similar shape, but I'm not sure of the size.
    "A good scientist is a person with original ideas. A good engineer is a person who makes a design that works with as few original ideas as possible. There are no prima donnas in engineering." - Freeman Dyson
    PA & MI
    Has anyone tried to fit a 3 series cluster into a 7 series?
    (northeast) Indiana
    15 650ix GC & 14 X5 50i
    Initially I had doubts...basically because I don't follow the 3 series...so I'm not that familiar with how they are set up...but I was under the assumption that they use the base cluster (K/KOMBI bus). So I went out on the net and googled the e46 M3 instrument cluster...and every image showed the low/base instrument cluster (uses the Graphic Display instead of the 20 digit alpha/numeric display for check control messages)...which would operate over the K/KOMBI bus.
    All e38s imported to the US market use the high cluster and also use the I/K/M/P CAN/Diagnostic communication bus. So installing an e46 M3 cluster would have to acommodate a retrofit to a different communication bus since the IKE (cluster) is the main gatekeeper of the communication bus in that just about everything runs "to it" or "through it" as modules pass data along the bus.
    If you're looking to upgrade to an M cluster...I'd stick with searching for e39 & e53 high clusters from the e39 M5 or e53 X5 4.6is & 4.8is models.
    {e46 M3 cluster - uses Graphic Display}
    {K/KOMBI Bus vs I/KM/P/CAN/Diagnostic Bus}
    {e39 M5 high cluster - uses 20 digit alpha/numeric display}
    {E53 4.8is high cluster - also uses 20 digit alpha/numeric display}
    PA & MI
    Quote Originally Posted by Qsilver7 View Post
    Good deal. Thanks Q! As usual great pics to show what's going on along with a solid explanation
    (northeast) Indiana
  1. Instrument cluster compatibility.
    By rgordonr in forum 1975 - 1983 (E21)
    Last Post: 01-05-2014, 05:09 PM
  2. Replies: 5
    Last Post: 09-29-2012, 11:09 AM
  3. Instrument Cluster Compatibility with E32?
    By sbeckman7 in forum 8 Series (E31)
    Last Post: 10-08-2011, 06:25 PM
  4. E32 735i Instrument Cluster cross-compatability
    By donaldashworth in forum 1988 - 1994 (E32)
    Last Post: 03-12-2009, 06:52 PM
  5. Need help on compatibility of instrument cluster
    By shaikhshahnaz in forum 1996 - 2003 (E39)
    Last Post: 09-21-2005, 03:00 AM
