cluster has been replaced at some point with used one but nort coded to the car. is there any way to tell the true mileage of the car ?
I believe the ECU records the mileage. Should be able to 'pull' the mileage from the ECU and 'update' the cluster.
Light Control Module records the mileage, not the ECU (DME). You will need software such as INPA to pull it though.
lcm was replaced too and not coded i believe
both these parts were stolen from the car so the PO bought lkq parts to replace them and never coded them
On the e38 the IKE (Cluster) and the LCM store mileage.
Mine is about 22,000 off from running a bad ABS cable. Wondering how to add miles.
---- Processing Individual ----
Z1XX Upholstery
Seats front and back in Epingle / leather englishgruen,
As Schl.Nr. B9EG.
Front seat backrest in Montana Englishgruen (No. 8 174 861)
Other interior equipment as for Volleder Nappa englischgruen,
Schl.Nr. P5EG
