[IMG][/IMG]
Hey all, I recently did some stuff to my car, and have some parts available, if anyone is interested. Bottom to top, I have new powerflex street control arm bushings, used lollipops, Used front and rear brake lines (Less than 1000 miles) Used powerflex rear subframe bushings, Used rouge engineering Trans mounts, and Used stock engine mounts. $100 for the lot. I will ship.
Any chance you'd sell just the lollipops?? If so, I'm interested.
"You don't win silver....you lose gold."
Kind of just wanting to get rid of everything at once. Are you wanting the bushings as well, or just the housings?
...just the lollipops. :-)
...yes, no, maybe???
I am really just wanting to sell the whole thing really. If someone buys it, they will probably want those, so they don't have to press their stock bushings out.
They have them on rock auto for pretty cheap.
Bump for you. Just curious why you replaced the Powerflex subframe bushings? What did you replace them with and how do they compare?
I did solid stuff from Condor bushings. The power flex stuff is great, they really sharpen the car car up over stock. But, my car is slowly progressing to track only, and once I put R-comp tires on, I started to feel a bit of play. I did solid motor/trans mounts, solid rear subframe bushes, and Condor's treehouse eyeball arm replicas. Would not recommend for DD, but they are honestly not uncomfortable, just a little more noise and some vibration. Not intolerable to me. I really only drive to the track, and on the track though, although some of my drives are 10+ hours.
FYI-I helped a friend work on his 330 (2002) last week, and his driver side motor mount was original, and had evolved into a two piece unit. You might not want to fit all these parts at once, but they will all need replaced eventually. Save a little cash, and buy this set, replace what you want, when you want.
Also, open to offers/fun, interesting trades.
One last bump.
Another evening bump...and hopes that you'll sell a fellow Couper those lollipops...pleeeezz?
Just buy everything, and win at everything.
how much for FCAB + lollipops? Assuming these fit a 97 Z3 roadster, correct?
I'll bite on the whole package. Total shipped to 75052.
100. (I'll ship it) I honestly just want them to go somewhere they will get used.
Sold. Thanks all.
Danomite, you can get the lollipops for as little as $20 each. Example: https://www.ecstuning.com/b-vaico-pa...121139790~vai/
I know, I'm just being lazy. LOL. I don't wanna push out/remove the old ones for my buddy...but he's being cheap. Plus it's always good to have an extra set of LCAB brackets!
