Results 1 to 25 of 29
Thread: DIY: Replacing Door Handle Trim
    Sep 2003
    Athens, GA
    2K M Roady, '86 944T
    Recently I have noticed that a lot of people are asking how to remove the old nasty door handles either to replace them with new ones, replace the cracked rubbers, or to just repaint them to make them look nicer. Anyway, after finding out myself, I decided to create this DIY. It was hard to take pictures of the inside of the door, so bare with my on the pictures.
    What you need:
    - Flat head screw driver
    - Some type of hooking device, coat hanger whatnot
    First things first, open the door of choice, and you will notice a little grommet. (Yes, e36 door panels blow )
    Remove the grommet with the screw driver to be able to access the "Slider".
    Here are a few more pictures of the "Slider".
    To help people understand the purpose of the slider, I drew the slider's location based on looking at the door. For instructions, push the slider towards the front of the car to release the old door handle piece. To install the new one, place your hook in the proper position to pull back on the slider and hold in the new piece up against the car (you could also grab a friend to hold it in for you). Pull towards yourself (or towards the back of the car) to lock the slider and hold the new piece in place.
    I hope all this helps.
    Last edited by shogun; 01-26-2017 at 06:26 AM. Reason: non working pic links removed
    Rob - 2000 BMW Z3 M Roadster | 1986 Porsche 944 5.3L LM4
    Sep 2004
    Miami FL -> Raleigh NC
    1987 M6, 2014 M5
    Luck with a 'vert (coupe too?)
    I finally got lucky finding the "slider" on my 'vert. There is a "gasket" hidden behind the rubber trim on the door, but it's pointless to bother with b/c there's a piece of sheet metal that blocks access to the slider anyway.
    After screwing with the gasket access I finally gave up and took the trim and soundproofing off the door from the inside. I tried looking with flashlights and mirrors and couldn't find the hooked end of the slider, but could easily locate the other end (towards front of car).
    I was able to cram my hand into the hole and felt above and aft of the lock mechanism. You can just feel the hooked end of the slider and with some effort, push it forward. After that the hardest part was holding the trim on with one hand outside the door while working the slider from inside.
    For some reason the driver's side was harder to do - not sure if the parts are different (why would they be) as I'd already reassembled my passenger door. Luckily a buddy came over and helped by holding the trim in while I futzed with the slider. I ended up using a screwdriver to pry it into place from the "front" (non-curved) end as that area is easier to see.
    It was a minor pain but much better than taking the door apart...
    BigBilly
    1987 M6 Cinnabar Red (I think) / 2014 M5 Alpine White / 1998 328iC - sold
    Hey everybody - it's been a while. Glad to see BF.com is still thriving.
    Any pointers on care and feeding of an E24 are appreciated.
    New Zealand
    328i E36
    E36 Coupe Rubber Door Handle Trim Replacement
    I own a 328i coupe and recently changed the rubber trim. What a mission. There is a slider behind a gasket, but it is very difficult to find and move. If you lift the rubber seal on the top edge of the door (where the window meets the sill just above the latch) you will find a very small gasket (see picture). If you look inside this gasket you will see a lever that moves down when you lift the door handle (a curved grey dull colour).
    The slider is directly behind this (a few millimetres towards the front) against the outside panel. The slider itself has gold/yellow appearance and is in the shape of an "L" with the bottom of the "L" sticking out from the panel. You can just see the tip of slider. Use a flexible LED torch that you can poke it into the gasket and light up the area. It’s hopeless shining an ordinary torch into the gasket and trying to find it. You can’t look in and shine the torch at the same time.
    The best way to slide it forward (towards the front of the car) is to use an Allen key. The Allen key allows you to get in behind the handle lever. If you can imagine the slider being an “L” shape and the Allen key being an “L” shape, then the idea is to push the bottom of the Allen key (tip of the “L”) against the tip of the “L” of the slider. Be careful as the locking mechanism is in very close proximity to the slider and you don’t want to damage it.
    I my case the slider was difficult to move. But a few taps on the Allen key with the handle of a rubber grip screwdriver did the trick.
    Once you get the trim off and replace the rubber use the Allen key as a hook to pull the slider back.
    The best thing you can do is to find/make and LED flexible torch that will poke through the gasket. Once you do this and get a glimpse of the slider you will see how it all works.
    There is no need to pull the door apart. I hope this helps you guys. It’s difficult to explain and even more difficult to photograph (even though I tried).
    Cheers, Marty.
    New Zealand
    328i E36
    OK, I just took another look and tried to take some better pictures.
    I made a mistake in the previous post. The Slider tip is just in front of the door handle lever (see the pic for details). It’s between a small piece of painted sheet metal on the inside of the outer panel (just visible through the gasket) and the door handle lever.
    Hope these pictures explain things a bit better.
    Marty.
    Jun 2005
    WNC, USA
    Boston Green 1995 325is
    Quote Originally Posted by Casebrius
    So where is a link to replacement rubbers for a Coupe?
    here...... http://forums.bimmerforums.com/forum...4&postcount=12
    and here... http://forums.bimmerforums.com/forum...4&postcount=13
    ...its correct, i just replaced mine yesterday.
    Oct 2003
    Walnut Creek, CA
    318ti, 330ti, 911S, Honda Element
    Quote Originally Posted by spsinha
    Does anyone know how to remove the exterior door handle and lock cylinder? Bastards broke in and smashed it all to pieces? If you have a used drivers side door handle, please let me know.
    I just replaced my door handles on my ti.
    http://bimmerboard.com/members/clex2...ndle%20DIY.doc
    '95 330ti Club Sport w/sun roof delete, S50USB30, Schricks, 24# inj, BBTB, Conforti SW, Euro HFM, Samco Silicone Intake Boot, Euro oil cooler, JTD Cold Air Intake Duct, RE DMS exhaust, RE Tranny mounts, CF Valve Cover, LTW flywheel/Kevlar sprung hub clutch, RE SSK, 3.46 Finned LSD (M6) , M3 tranny, Brembos, RE Wheel Studs, SS brake/clutch lines, CF interior, Tilt Steering retrofit, 13.5 lb DynaBatt in rear, LED interior/footwell lights, 4500K ZKW HID, Headlight Aim Control, Rear fog light w/cluster indicator, BMW Traffic Pro/Alpine MP3-CD Changer, Staggered LTW wheels, '95 M3 steering rack, VIS CF Hood, M3 LTW Strut Bar, Aluminum M3 Coilover Front/M Coupe Rear suspension, Red LTW Motorsport Seatbelts, OEM Fire Extinguisher, Z8 Starter button, Auto dim rear view mirror w/Homelink, PDC, Rear Sun Shade, Euro Gauge Cluster w/oil temp/shift light , Headlight Washers, BMW MS Door Handles, CF Grills, French ZKW Fogs, Bimmer Mag 8/2007
    Oct 2001
    Camarillo, CA (Ventura)
    '05 Ram 1500
    OK - one more than I asked for, very grateful.
    Mike - Please DO NOT pull out your window.
    Here is what you do (coupe)
    Windows on these cars are a PITA to remove, so, FDS. With the door panel off, you will find that the window slides on this yellowish, orangish thingie (yes I'm kinda coming down from major drinking right now, bear with me) and what you need to do is remove that. I know your issue is the door handle trim slider, I'll get to that soon. OK - There are 6 bolts/nuts that you need to remove here. The guide that is farthest to the rear of the car needs to come out. The guide is held on by two allen bolts at the bottom of the door, two bolts at the top near the door handle, and two nuts that connect the window to the slider. Whatever you do, do not loosen a bolt that goes through glass. The last two nuts I mention hold the glass holder thingie to the slider (you will know what I'm talking avout when you're in there).
    OK, now pop the window off the plastic slider clip thingies that attach to the window regulater arms. These plastic clips should be replace anyways since they are a failure item anyways, so just kill em. The clips I am talking about are white plastic, slide a bunch, are covered with grease, and have a metal clip on them. Pull the metal clips with a screwdriver and get the window off of them.
    You will need to mess with the window a bunch to get this far (up, down, etc), so, what you wana end up with is a window that is loose, that you can pull away from the door handle so that it can be brought in and out no prob. With all of this stuff out of the way (the window still in the car btw), you are able to move the window enough to change out the door handle, and not go through the hassle of removing the window entirely which is WAY too much work for such a simple job (granted I have done it 3 times now, but trust me, this is much easier).
    OK, so now the window is far enough out of the way to do the door handle job, and you have saved a buncha time. Great. The slider. It's a PITA I know. I just helped knightryder whatever his username is do BOTH his door handles the other dai I know wtf im talkig abou.t.
    OK -- te slider, if you cannot get it through the tiny hole which IS possible rust me, get a hook tool and you can slide it inside the door. You gotta somehow grab it, and pull it towards the front of the car. On the passenge r side i was able to get it through the hole, but for some reason the frivers side was much easier inside the door. There is this metal plate thingie that gets in the way and you gotta deal with this thing when putting the new door ahndle in there . You gotta kinda tucj k the new door handle in there under this metal plate in order to have enoug threads around the lock sylinder to get the nut on there.
    ANyways, that slider is a beeeeyotch, and I highly suggest going to sears and getting a tool that has a hook on the end (will post a pic of mine when im coherent enough to do so).
    Hey man, if this didnt help PM me your cellie and ill give u arin g and talk u through it.
    Night.
    Honolulu, HI
    1998 M3 coupe
    98 coupe
    I replaced my door trims this past weekend. The coupe's design is the same as the sedan, but work will need to be done almost blindly because there is a piece of metal that blocks the view of the slider from the access hole. While the slider is in the forward (open) position, it is possible to see a glimpse of the hook end of the slider, but it is not visible while the slider is closed. Using a tool shaped like a larger allen wrench is ideal. Taking apart the door is not that much of a help because the area is blocked by the bottom part of the window (even with the window rolled all the way up), and you will probably find that you will need to fix your door panel because the adhesives have broken down. All you need is the wrench, a flashlight, some patience, and a third hand.
    Austin, TX
    1998 323is
    Quote Originally Posted by Mike 01Hawk View Post
    SUPER Easy w/ a Paint can opener
    Thanks for the tip!!! I had almost given up, but finally I figured it out after reading your suggestion.
    I was using an allen key and blindly fishing around behind the sheet metal tab. I had no idea what size the mythical retaining clip was, and I was using an allen key that was WAY too big...
    I actually used the slotted end of an offset screwdriver since I couldn't find a paint can opener in my garage, but same principle.
    After completing the swap, I am convinced that BMW hired Erno Rubik to design that thing!
    Coeur d Alene, Idaho, U.S.A.
    1993 BMW 325is
    dear god almighty. I definitely did not expect that to be so hard. Contrary to what a few other people have said, it IS possible to do the coupe door trim without removing the door panel. I used a flat head screwdriver to push the tab into the 'unlock' position, and then used a coat hanger with a loop bent in it to pull it back. It's frustrating and takes some patience but it can be done.
    Jeffum17
    "Do not put cheap eBay crap on your German Stallion!" -Bimmer323is
    Satellite Beach
    530i, 328is
    The slider on the 328is is has a slight L shaped bend in it. NO HOOK or HOLE to insert the allen key into. It is just a little back behind that little sheet metal tab. An allen key held in vise grips moves it back and forth easily. You will not find it with a flashlight so give up. Use feel instead. It's way easier than it seems. After fighting with the first door for two hours I finally realized to simple "slide" the L shaped bend bac and forth. Push it forward to release the trim. Adjust the allen key and hook the back end of the L shaped bend and pull forward to lock it in place. The second door took 10 seconds. It's easy to over complicate this one. Don't.
    Satellite Beach
    530i, 328is
    Pictures won't help with this one
    Pics would not help. You can't see anything through the hole and what you need to see is visually blocked by the sheet metal tab. Like I said I struggled for two hours with a tiny flexible flashlight to "see" the clip and it was pointless. I gave up and might as well as closed my eyes becuase it's all feel.
    Just between after sheet metal tab (maybe 1mm at most) is the L bend in the retainer clip.
    You "push" it back (towards the front of the door) with your allen key (held in vicegrips) It only goes back about 1/4 inch.
    Pop the old trim off and then hold the new trim in place. Then "hook" the end of the allen key over the L bend in the retainer clip and puul it back towards you.
    Done.
    Once I got the "feel" of it I was mad at myself for making it so hard at first. Second door literally took 10 seconds to do.
    Jun 2008
    Perth, wa, australia
    94 318is coupe
    Just changed the door handle on the drivers side in my coupe, was worried how hard it would be after reading some of the posts, but found it really easy.
    I removed the gold window guide chanel to give some more hand room, and the bottom bolt of the lifting arm to allow the window to tilt forward a little. Had the new handle in front of me, so just looked where the slide was, and reached around till i found it,and slid it across using my fingers, no screwdriver needed.
    To get the handle out i had to push the window outwards a touch. Only prob I had was when re assembling, the handle didn't want to sit flush. Turned out to be that little bit of sheet metal that blocks access to the slider catching on the very end of the handle.... whats it even for?? just to annoy people?
    Mar 2004
    FL
    97 M3
    I was intimidated but I did it in like 15 mins! Sedans really are better than coupes
    Using an allen key held on with grip pliers makes it easy.
    Feb 2009
    RDU, NC
    98 M3 CS
    Exclamation
    Ok here it is for the coupe. I was pretty confused but hopefully this will condense everything that others were saying that, added together, makes this like a 45 second job.
    I have a 98 M3 coupe. My slider is black just so it's better camouflaged. PIC!!!!
    You can see the tab quite well, this is because it's already been pushed. It sits right in front of the foward edge of the "blocking tab" and you can squeeze a paint can opener (thanks for the tip) between the two and just push. You'll find it after a couple of tries and mine wasn't hard at all to push. replace the trim, holding it against the outside of the door, and just pull the tab back. done faster than you read this lol.
    May 2009
    australia
    97 328i Convertible
    Hi, I just followed the instructions provided by Mmineham to replace the rubber seal around the door handle trim and it worked perfetcly however, a few tips from what I learned.
    - dont use the eBay rubbers they do not fit correctly and while, with some effort, I have been able to get mine to fit, its not perfect so defeats the reason I replaced them in the first place. I will probably go to a dealer and get genuine replacements and re-do them
    - while I tried an alen key, it was a bit short so I bent the end of a cheap flat head screwdriver to 90 degrees and it was very easy
    - follow Mminehams pictures and description it works. While I couldnt see the slider, following the instructions was simple and can be done with your eyes closed (after 2-3 min getting the infernal eBay rubbers to fit, it only took a few seconds to unslide and re-slide the trim back in place)
    - I read a post somewhere that suggested the slide went in different directions on each side - mine were both forward to undo and back to clip back in.
    - and absolutley no need to take your door trim off and play with windows! Unless you are one of the unlucky ones who reported stuck sliders (mine slid really easily)
    FYI - my car is a 1997 328 convertable
    Good luck all
    Oct 2008
    Coos Bay Oregon
    09/95' 325ic
    Quote Originally Posted by blackmancer View Post
    hi, just wondering where the original pictures are for this thread?
    I'm struggling to find this slider thing and I've even got the door trim off. looked up into the door, got my fingers in and slid them around, but couldn't find a trace of anything.
    will post pics later
    Perhaps this will help?
    [ame]http://www.youtube.com/watch?v=gGE7ncBE_vQ[/ame]
    CT, United States
    1999 M3 Coupe MT
    The new DIY I posted up in the e36 M3 section should replace this, no offense to the OP or contributing members. I don't have privileges to post up a new DIY, so here's mine:
    The current DIY for this is discouraging at best and the images are no longer viewable, so I thought I would update with a clear, simple way of tackling the job. This is more a compilation of different people's ideas than my own, but having them all put together should make this a less than 5 minute job as opposed to the multiple hours I've read about.
    Disclaimer: This procedure was performed on my coupe, so I can't confirm that it applies directly for sedans. According to what I've read though, the sedan is easier to do; you can actually see inside. Also, don't come to me if you hurt yourself doing this. It's your own fault.
    Tool required:
    That's right, you only need one. Go to your local hardware or paint store and pick up a paint can opener; they just give one to you since they have about 498745398 of these:
    If you really are too lazy to go to the hardware store, you can try bending a piece of metal wire into an L shape, but I didn't feel like wasting my time with the wrong tools. If you do make it, try to form this kind of shape:
    Parts:
    "Door Handle Cover Outer includes Sealing Gasket, Left Front, E36 3 Series, All 1992-99": 51-21-8-122-441-M9
    "Door Handle Cover Outer includes Sealing Gasket, Right Front, E36 3 Series, All 1992-99": 51-21-8-122-442-M9
    Optional Equipment:
    Back to Black or equivalent
    Clean rag
    Procedure:
    1. Open your door of choice and look at the rubber cover on the top half of the door.
    Pull the outside lower corner of the rubber sheet up to pull the rubber grommet out of its hole.
    This will reveal the access hole that you will be using to release the handle trim.
    2. Since you can't actually see what you're doing inside the door, it's going to be pretty much all feel. Take the paint can opener, point it towards the front of the car, and aim the L shape to the outside of the door. In that orientation, aim the tool at the crotch of that little metal arm of the door handle assembly shown below.
    Push it forward to release (this shouldn't require an incredible amount of force).
    To get a better idea of what you're working with, check this out: you're just going to be sliding a little knob forward:
    YouTube - E36 Drivers Door Handle Trim Removal.
    3. Once you've felt the knob slide forward, you can get a fingernail under the trim and pull it off, top side first.
    4. Now that you have the trim off, you'll see quite a bit of dirt buildup under there. Clean it off, and if you have some Back to Black on hand, get the actual handle completely covered since you can access more of it while the trim is off.
    5. Installation is the reverse of assembly. The hook shape of the paint can opener makes it a good tool to pull the knob back into place, securing the trim. Another thing to watch out for is that the new rubber seal isn't bunched up on the plastic trim.
    Instead of this:
    It should look like this:
    And you're done! The whole process took me about 15 minutes including going back and forth to the house to grab some back to black and stopping every 5 seconds to take a picture.
    It's a nice improvement. Went from this:
    To this:
    Seattle, Washington
    2011 128 Convertible
    Yes, on the 2 door, that slider is a pain! It's behind a metal tab that protects it from being seen through the hole as mentioned above. Photos are attached showing it removed from the car. The side photo shows how it fits on the handle. It holds the trim because the trim pokes a couple little hooks through a couple little holes that the slider catches. The second photo shows the slider from the view you would see it through the viewing hole if that metal piece were not in your way.
    Nov 2007
    Central IL
    E36
    best DIY!
    This job was a PITA though, I used the paint can opener method as described. The slider tab isn't as far forward as you'd think, it's more 'over' towards the outside of the door.
    Either way, happy it's done
    BMW CCA Illini Chapter Vice President
    1995 M3
    - My Favorite DIY's and FAQ's
    Oct 2008
    Coos Bay Oregon
    09/95' 325ic
    After discovering my cellphone actually fits between the door and the handle while also being in-focus (mostly) - I decided to make a quick DIY. Maybe it can be of use to someone.
    Jan 2014
    Mocksville, NC, USA
    1996 318is Coupe
    http://blog.bavauto.com/bmw-e36/bmw-...acement-e36-z3
    No it's not an easy job. It's a PITA. I've got 25 years of working on vehicles whether I want to or not, and I have had my BMW door apart now for 2 weeks trying to get it right. If you grew up working on them and knew nothing else existed, I could see how you might have that perspective. Changing out the driver's side door handle is harder to do than rebuilding a manual transmission, or the replacing the heads of an engine. I suppose it's all about perspective though. I may not be any sort of expert, but I have rebuilt over 20 transmissions, and every single one of them was easier than replacing the door handle for my e36 that STILL is not done yet... The clip you have to slide is probably the easiest part of this job, and that isn't easy.
    South Carolina
    2004 330 vert 2004 X5
    I'm sure someone covered this but just in case. I've replaced the trim on lots of handles. The eBay parts never fit quite right. I just picked up the trim pieces from the dealer a couple days ago. Definite difference in quality and the rubber gasket is included. $13 per handle.
    Sep 2010
    PNW
    E34 525iT, '99 M Coupe
    I just did this repair on my M Coupe and would not have been successful if it hadn't been for all the good folks who contributed to this thread. I read virtually every post, watched a few YouTube videos, read Shogun's DIY and more. It took some time but eventually I was able to remove the covers and old gaskets and attach the new gaskets to the handle covers. The gaskets were sourced from Shogun- they fit perfectly BTW. They are rubber, not like the ill-fitting junk I got from Thailand.
    But what was even more perplexing to me than getting the parts off the car was reattaching them.
    Then came the epiphany- BINGO! I realized that the slider was not spring-loaded, and as someone said, it was a "push-pull" situation. Because you cannot see what the hell you're doing it is a matter of gently probing. The video and pictures that give you an idea what the slider mechanism looks like were invaluable.
    It's only after I spent a few hours figuring things out that I now can say it's a 5 or 10 minute job. The tool that a few guys suggested, made from a paint can opener, worked brilliantly for me. A hex wrench in a vise-grip should work equally well.
    Next I'm going to replace all these gaskets on our venerable E34 Touring.
    This board is a phenomenal asset to our community of car nuts. Thank you all.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Here are good pics from a Z3 DIY http://bmwz3diys.weebly.com/door-han...4-m50-m52.html
    That site has BTW some more good DIY for mechanical, exterior, interior, suspension, trouble codes, FAQ (with for example belt routing), how do i unlock my car if the battery dies?, diagnosis tips
    http://bmwz3diys.weebly.com/diys.html
    I have the outer door handle gaskets available ex stock, see for sale forum
