Any control arms comparable with the 93 e34 that'll widen my steering for better drifting, or will I have to do welding?
i wanna say that someone on here rigged up s13 arms and tension rods to work on his e34. it might've been audioscience, look him up and ask
Popular engine swap weights & stock engine weights
M42 + trans - 427lbs
302 + t5 trans - 475lbs
m20b27 + g260 - 497lbs
m52b25 vanos + g250 - 544lbs
351w + t5 trans - 572.5lbs
LS, aluminum block + t56 - 609lbs
LS, iron block + t56 - 719lbs, EST.
http://www.bimmerforums.com/forum/sh...60-m42-1jz-2jz
Im pretty sure Sean (SLR) had this all worked out years ago for Harri's car. I'll see if I can get him to chime in
sub'd
13 Grand Cherokee Limited V8 - Daily Driver - Wife
97 Z3 2.8 Roadster
95 325i Sedan - Project #ebayE36
90 BMW 535i/5 - i should probably work on this again...
Bolt in the E34 ix crossmember and then run an SLR mini-kit!
https://www.google.com/search?q=525i...w=1455&bih=656
Disclaimer: I don't know if the ix crossmember fits a standard E34 body, but it at least looks workable.
exactly what he's saying, just remember that when you go to the part store you ask for the crossmember kind of strut
If the ix crossmember will work, then absolutely I'd recommend running E36 knuckles, and if you order coilovers from BC racing, they can supply your E34 kit with E36 front lower brackets instead of the pain-in-the-butt weld-on E34 setup.
Otherwise on a budget setup, an E36 strut+knuckle will work in the E34 if you're using the ix crossmember (rack steering and forward-mounted rack).
Remember this is changing basically everything in the front suspension and steering, so beware of oil pan clearance changes etc. Should work great with a rear-sump LS though!
The reason to go to such lengths on the E34 is to convert the double-pivot setup into a single-balljoint system which won't bind at big steering angle.
SLR parts can be found at www.SLRspeed.com
Also I have a good idea in mind for an E34 kit, but how much as you looking to spend? We've had several questions over the years, but the number of E34 inquiries in 7 years has honestly been the number of E36 kits we sell in a few weeks, so it's tough to justify a kit unless you can get 5+ people on board to get it rolling.
Cheers,
Sean
