My ABS light went on my 635csi, how does the ABS affect the driveability of the car? Should I tow it to the shop or still okay to drive?
"Simply looking at a Shark is the same as buying one " - R. Carter"I have to stop looking at Sharks" - RokuMado
In Desire Of: 1985 M635CSi (Alpine White) OR ALPINA Model
1985 Euro 635CSi CR 5-Spd (Schwartz/Buffalo Anthracite)
1985 Euro 635CSi CR 5-Spd (Polaris/Napa Schwartz)
1985 Euro 628CSi Auto(Zobelbraun/Buffalo Nutria)...Rehomed
2002 540iT Sport Auto (Schwartz/Napa Black)
2019 740i M Sport (Carbon Black/Napa Black)
(pics) Nori • Yume •Hime • Saiko
I will be prepared for the slamming.
All will be fine, no problem driving unless you are trying to stop too hard/quickly on slick road. ABS will not affect drivability, and these cars are without traction control, so fewer issues.
Do have ABS checked and check tire pressures, uneven rotation of the wheels on the ground will trip the light . Check fluid level in the master cylinder . If all was well before, one of the wheel sensors has gone wacky or the toothed wheel on the hubs have picked up too much crud, or a broken wire, bad connector, blown fuse etc.
Sent from my SM-T337V using Tapatalk
Thank you for your response! All has been well. I only drive car around once a month and I don't even open her up enough to keep the brakes clean (bad of me). I drive easy so the car doesn't get any hard stopping. She is my baby so I stop/brake well in advance. Maybe I baby her too much. I have staggered wheel set so no rotation there. I will still have her checked out once I get my Polaris 6er back this week.
I've been driving mine for a while with it on. It's on my list. Soon...
My E24s airbag light has been on since I got it and have no idea how to get it off
Thanks. Will look into it. Hopefully I can find one that can do it because most shops around me seem to shy away from these cars.
Roku,
I feel like a total redneck if I drive around with warning lights on.
Ohm the wheel sensors. Just did my rears - piece of cake.
Process of elimination - start with the cheap parts first. By putting Multimeter on the ABS sensor connects, you can verify if it's functioning. My passenger rear had gone out and was causing the fault. Go to BigCoupe for the full write up on diagnosing your ABS fault.
