- x20 pinout?
x20 pinout?
So im in the middle of swapping my 86' 325e with an obd2 m52. The preivous owner of the engine cut the wiring harness in order to take it out so i built a custom harness with only the neccissary items. Im looking for the x20 pinout so I can have the cars orginal cluster working properly. Does anyone have the pinout for the 1998 328i x20 connector? I have a diagram but its for a 94' m50 x20 connector and im not sure if there is a difference between the two. If someone also has the pin out to the c101 from the 86' 325e that would be great!
- You may not post replies
- You may not edit your posts
Forum Rules
